Old 01-20-2009, 12:26 PM   #646
PartTime's Avatar
Originally Posted by KE4PJO View Post
John has NEVER been a saint of any sort. LMAO
Darryl
BWAAAAHAHAHAHAHA
DK
PartTime is offline   Reply With Quote
Old 01-20-2009, 12:41 PM   #647
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Laugh it up Fuzzball !
John St.Amant is offline   Reply With Quote
Old 01-20-2009, 01:27 PM   #648
ben73's Avatar
Trader Rating: 40 (100%+)
Originally Posted by Fred_B View Post
I ran a 4.5 a couple weeks ago and it was pretty good. If whatever set-up you're running is going flat it's either geared wrong or the speedo is limiting power. If you run a receiver pack (or booster) and leave the speedo switch off it shouldn't power limit with the low pack voltage.
As long as you have a decent speedo and you don't drive like Jo Jo the circuis clown a 4.5 Novak will make time pretty easy. It's not quite as fast as 4 cell but it's pretty quick.
Almost forgot. You will feel the voltage curve of the pack during the run in mod but it won't fall off much. Just feels different.
I have a 4.5 for my 12R5 - how much mah are going back in to the pack after the run? I am interested to see how close we will be getting to dumping the lipo as we cant run the esc cutoff to protect it.
ben73 is offline   Reply With Quote
Old 01-20-2009, 01:53 PM   #649
Originally Posted by CCH1978 View Post
would this be a good alternative for a booster
http://cgi.ebay.com/Novak-5485-4-Cel...3%3A1|294%3A50
That won't have enough power to work but they do have a new booster that will be available soon that will. It's on Novak's website.
Fred_B is offline   Reply With Quote
Old 01-20-2009, 01:56 PM   #650
If you drive hard, it will dump. If it dumps you'll know it. Just stop and charge it back up. You're only going to really hurt the pack if you keep trying to drive it around once the pack dumps.
Old 01-20-2009, 03:26 PM   #651
Company Representative
Danny/SMC's Avatar
Originally Posted by John St.Amant View Post
I would suggest to wait till someone decides to make the 5700 pack for us they said they were going to make before the 1c 4000 came out. hopefully it will have barrel connectors out of the top like we want it.
From what I understand ROAR will freeze the current case size and 5700 will not be possible as that was with the original case that was to high. For those looking for higher capacity and C rate for mod it will be possible for us to make such a pack as there is room left inside the current case.
As far as barrel connectors go it will not happen as there are to many disadvantages to this style connection. Barrels can come apart of the circuit board, Extra solder points due to the circuit board and wear and tear of the of the barrel can increase resistance. Out board connectors can be changed plus can't be plugged backwards.
Danny/SMC is offline   Reply With Quote
Old 01-20-2009, 03:29 PM   #652
Danny/SMC's Avatar
As soon as you notice your car slowing down stop right away and the pack will be fine. With the Novak Booster circuit it will have a built in cutoff.
Old 01-20-2009, 03:45 PM   #653
Default 10.5
I ran a 10.5 on the weekend, 12 minutes till it dumped, speed didnt fall off till 11 min+. ran no added weight, 715g, 730mah lipo rec pack (overkill, but I had it from a plane). If it feels like its dumping it could also be the rec pack falling off.
I'll throw my opinion out there on weights and capacity just to add to the unofficial vote. Keep it light, 700 is achievable easily using common equipment, and lighter is less breakage and tire wear. Limit the lipo case size, there is no way to police capacity once there is more than one supplier.
A big thanks to SMC for taking a risk with this pack, I'm finishing a few races with old round cells, then goodbye to nimh.
You know you love the tape, Sturley...
snowyelan is offline   Reply With Quote
Old 01-20-2009, 05:22 PM   #654
havnt you been paying attention? guys are taking your 4000 packs appart and making them into top loader barrel connector packs.
Like I said b4... I think some one ows me an appology...
Old 01-20-2009, 05:55 PM   #655
sportpak's Avatar
Trader Rating: 26 (100%+)
Can we forget the barrel connectors. He has said at least 5 times that it ain't going to happen. He just gave his reason for not doing it. Learn to love the Deans or buy a different battery.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 01-20-2009, 05:58 PM   #656
Anchors Aweigh!
Old 01-20-2009, 06:18 PM   #657
Moderator
Clegg's Avatar
Or just go and mod the battery like I did and like another dude did.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 01-20-2009, 06:49 PM   #658
sportpak's Avatar
I like that, take matters into your own hands.
Old 01-20-2009, 09:59 PM   #659
Danny/SMC's Avatar
Packs that are taken apart and altered will not be ROAR legal and it voids the limited warranty we have on our packs.
Old 01-21-2009, 06:16 AM   #660
I have bullet connectors on my pack and I didn't have to hack it all up. It's not rocket science to solder a couple of connectors on and shrink over them.
If I were running single cell all the time I would hardwire the pack directly to the speedo and have it done with. There's really no need for the connectors if your speedo has solder tabs.
The future of 1/12 scale Roland S Electric On-Road 1004 06-16-2017 02:04 PM
SMC 5700mAh 25C Single Cell Lipo Danny/SMC Electric On-Road 352 05-14-2009 04:03 AM
Trackside 1/12th scale racing Ike Wisconsin & Illinois Racing 41 03-31-2009 11:42 AM
ROAR 1/12 weight limit miller tyme Electric On-Road 171 01-09-2009 04:14 PM
Why choose LiPo? wingman2 Electric On-Road 16 12-17-2008 06:51 PM
1/12 lipo the mighty thor Electric On-Road 7 12-07-2008 03:01 PM
