Old 01-18-2009, 04:28 PM   #616
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Originally Posted by buffalobill989 View Post
i think stanton is
This is true, it's been working great.
brians11 is offline   Reply With Quote
Old 01-18-2009, 04:56 PM   #617
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by andrewdoherty View Post
Anyone running 1 C/ 13.5 in an 12R5 yet?
uhh.. where have you been?
John St.Amant is offline   Reply With Quote
Old 01-18-2009, 04:57 PM   #618
PartTime's Avatar
My car is a missile with a novak at 3.2 roll out and the motor comes off the track around 112 deg. Cant really tune with temp on these light 2wd cars.
DK
PartTime is offline   Reply With Quote
Old 01-18-2009, 05:22 PM   #619
DK
I assume that is 3.2 inches???
Which would be 80mm for the rest of the world, who has adopted the metric system!!!
Thanks for the info, what ESC are you running?
Grant
XRAY T3'12 17.5, Spec R R1 13.5, CRC GenXL, Grant Galloway Designs ( Painter )
lifeguy is offline   Reply With Quote
Old 01-18-2009, 05:36 PM   #620
PartTime's Avatar
Grant
LRP sphere.
DK
Old 01-18-2009, 05:48 PM   #621
Moderator
Clegg's Avatar
So tonight was the first run of the SMC pack with a 13.5 at the local track.
My car weighed in at 730 running a BMI12RR with a Novak 13.5 and a HK Voltage Booster running off the BEC on the Novak GTB.
The car ran STRONG all 8 minutes, no drop off, no dumping feeling. The car was so light on the tires that the traction didnt drop off at the end of the race. After ther qualifiers and race, I used 2680 mAh out of the pack.
I was running with 5 other 1/12ths running 4 cell 17.5. Some of the guys gave some flack about the speed the 13.5 had... it was a screamer down the straight. Fast time of the day (for all classes including 13.5 Rubber) was set by my BMI DB12RR at a 9.005, The average 5/10/20 laps were nearly a 1/2 second faster than anyone else in the class. The times from the 17.5's came in at fast laps of 9.4 as the closest one to me.
I had the TQ for the race by 8 seconds, but due to some traffic issues came in 3rd.
The car was easy to drive once setup, and gained a good deal of attention from everyone. I think this class will take off fast. But I do think it may be a bit too fast to run with the 4 cell 17.5's It just ate them up on the straights and how much speed was maintained through the corners. I may switch to running a taller gear on a 17.5 next week to see what that does... unfortunately... this chassis is so hooked up right now, I am afraid the Associated folks at the track are going to blame the LiPo and 13.5 for the speed instead of the chassis. With a 4 cell last week I bested everyone by .2 on the track for fast lap and beat by .5 in the averages.
I am selling my remaining 2 HK Voltage boosters to fellow racers to get some more people testing.
Attached is the setup sheet for the BMI that was run tonight.
SMC 4000/25C/3.7V single cell Hardcase pack.-liposetup.gif
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 01-18-2009, 06:06 PM   #622
jrp
jrp's Avatar
Trader Rating: 18 (100%+)
Default 1S Lipo
Been running 1S Lipo/13.5 in my GenX with NO weight added. Car drives like crap... Skatey, darty, ... Curious what setup changes others have made on their cars to get them dialed in. I can turn quick laps, but car is a major handful to drive, and scrubs alot in the corners, thus falls off about .5 sec start to finish.
Tried going to softer front and rear springs. Verdict still out for me on setup...
jrp is offline   Reply With Quote
Old 01-18-2009, 06:09 PM   #623
Moderator
Clegg's Avatar
Dont know how to help with the GenX, but for my BMI i kept the front as I ran it for 4 cell on our track, and softened the rear only in side to side transition and kept it more or less the same for the center shock. Also kep the lipo mounted as far back as possible.
And try different tires, they made a world of difference for me. Lilac fr and Yellow rear.
Its hooked, fast, consistent and glides through corners with ease.
Old 01-18-2009, 06:40 PM   #624
Try softer side springs and harder front tires.
Old 01-18-2009, 07:27 PM   #625
level-4's Avatar
Send a message via AIM to level-4
I was running with 5 other 1/12ths running 4 cell 17.5. Some of the guys gave some flack about the speed the 13.5 had... it was a screamer down the straight. Fast time of the day was set by my 1/12th at a 9.0, The average 5/10/20 laps were nearly a second faster than anyone else in the class. The times from the 17.5's came in at fast laps of 9.4 as the closest one to me.
THe car was easy to drive once setup, and gained a good deal of attention from everyone. I think this class will take off fast. But I do think it may be a bit too fast to run with the 4 cell 17.5's It just ate them up on the straights and how much speed was maintained through the corners. I may switch to running a taller gear on a 17.5 next week to see what that does... unfortunately... this chassis is so hooked up right now, I am afraid the Associated folks at the track are going to blame the LiPo and 13.5 for the speed instead of the chassis. With a 4 cell last week I bested everyone by .2 on the track for fast lap and beat by .5 in the averages.
can you post your set up, the pdf is giving an error when i try to open it.
thanks
X6 | X60 | SC10 | Ve8
level-4 is offline   Reply With Quote
Old 01-18-2009, 07:53 PM   #626
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I feel the love . . .
Anyone besides JSA have experience with lipo in a 12R5?
Old 01-18-2009, 08:07 PM   #627
Moderator
Clegg's Avatar
thanks
Here is the Gif of the setup. I didnt want to re-type it all.
Old 01-18-2009, 08:37 PM   #628
PartTime's Avatar
I have a crc V3 here, not gen x but some of it should carry over. Heres my setup.
Frt
spring asc .020
just a touch of droop so I know there not preloaded
7,000 lube on king pin
5deg reactive caster and a shim in frt and back on upper arm.
servo sitting flat BEHIND the linkage. Tie rods are dead stright frt back and up down. Took 2mm of bump steer spacer to get them level.
rear
blue side springs
7,000 in tubes (diffrent than yours)
crc red shock spring with 30wt oil
shock in long position
I race at two tracks. One has tons of traction and the other no so much.
High traction Black frt with gray rear
low traction lilac frt with pink rear
The car has good onpower steering but could use a touch more off power. Next time out gonna try moving front arm back for a little more caster. The car carries tons of corner speed !!!! On high traction the black grey combo really smoothed the car out and made it easy to drive.
Let me know if you try it and what you think.
DK
Old 01-19-2009, 12:00 AM   #629
PutAwayWet's Avatar
I'm running lipo/13.5 in my R5 now.
Jaco Dbl Pinks 45/43mm (I start 'em fat and run 'em down for club racing)
CA'd front sidewalls
Jack
0.18 front springs
1 mm droop
CRC white lube on the pins
blue center spring
30wt center, 20wt side
green side springs
4.5 mm ride height
740g full up
LRP Sphere TC w/fins dremeled off
160 mah RX pack
One thing that has made a big difference is that I mounted my body (Proto 12) about 5mm forward. Getting more downforce over the the nose has really helped lock it in. Before, the nose would lighten up and the car would go straight when I wanted to turn. Not just push, but straight. Our track is a little bumpy, so my car may be softer than some other guys are running.
It's been working really well, and it's definitely faster than 17.5 4 cell. I think we'll see the lipo and 4 cell times getting closer and closer. I'm really gearing it up--like a 17.5, basically--and it keeps calling for more.
PutAwayWet is offline   Reply With Quote
Old 01-19-2009, 12:50 AM   #630
Jack
0.18 front springs
1 mm droop
blue center spring
green side springs
4.5 mm ride height
740g full up
160 mah RX pack
Thanks . . .What kinda grip carpet are you running on? Where do the Dbl pink rears fall in terms of grip in Jacos line up? I can't find 'em on Jacos site.
The future of 1/12 scale Roland S Electric On-Road 1004 06-16-2017 02:04 PM
SMC 5700mAh 25C Single Cell Lipo Danny/SMC Electric On-Road 352 05-14-2009 04:03 AM
Trackside 1/12th scale racing Ike Wisconsin & Illinois Racing 41 03-31-2009 11:42 AM
ROAR 1/12 weight limit miller tyme Electric On-Road 171 01-09-2009 04:14 PM
Why choose LiPo? wingman2 Electric On-Road 16 12-17-2008 06:51 PM
1/12 lipo the mighty thor Electric On-Road 7 12-07-2008 03:01 PM
