Old 01-16-2009, 11:22 AM   #601
At RCExitement in Mass. we have more than half of our stock 12th drivers running the SMC lipo. I'm planning to buy a lipo this week. All the remaining drivers plan to switch within 2 weeks.
Most of the recent lipo converts stuck with the 17.5 motors because they already have them. They are not much slower than the NiMh except for a little extra punch down the back straight.
I bought a 13.5 to be ready for the switch from my brushed 27T and now realize that I should have talked to the other drivers about it first. What seemd to happen was that most of them had round cell packs that were falling off a bit from age. The same people have healthy 17.5 motors. Once the first lipos hit the track, change came quickly as most were more than happy to dump thier sad round cell packs, yet few want to retire reliable 17.5s to the junk drawer. When the switch happens at the club racing level, it happens fast.
Eddie_E is offline   Reply With Quote
Old 01-16-2009, 11:29 AM   #602
The Evicerator
The Novak Boost Circuit will output a sustained 6V/3A ... compared to the 5V/1A that the Hobby King unit claims.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 01-16-2009, 12:00 PM   #603
rcterp's Avatar
Trader Rating: 35 (100%+)
No worries here Steve; I'm patiently waiting for the Novak booster (simply because I have trusted Novak since my first Kyosho Raider Pro). Till then it's a 7.2s lipo receiver pack.
Φ
Glitter Lidz - "My driving doesn't shine but my lid does!!"
rcterp is offline   Reply With Quote
Old 01-16-2009, 08:27 PM   #604
The screws that hold the battery plates in the Gen X hit the SMC pack. What needs to be done to get a nice fit ?
-=light=-
Gorden
light is offline   Reply With Quote
Old 01-16-2009, 10:31 PM   #605
PartTime's Avatar
Ok, just got back from my second race with the 13.5/1c. Packs are broken in and the car is a missile !!! 75x35 ft track, fast layout with great traction. Foam 10.5 sedan with very talented drivers pulled a 8.9 fast lap. I got one 9.0 and a couple of 9.1's. Started with consistant 9.2,9.3 and finished with 9.4,9.6's. Cant emaigen how fast it could be with some one like Jeremey behind the wheel.
Most of the drivers were 13.5/1c. I was gonna try the 17.5 to see how slow it is but forgot it at home.
Starting to look like just throw a lipo in and allow 720 grams and call it what it is, stock is 17.5 and super stock is 13.5. Just dont know if it could keep up to the 4cell heavy versions. Or better yet, just dump the 4 cells ??? I bet I get flamed for that comment.
DK
PartTime is offline   Reply With Quote
Old 01-17-2009, 06:41 AM   #606
KHoff7's Avatar
DK
Thats how it should be... more lipo than nimh. Sounds like another class we all race, Sedan.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 01-17-2009, 08:43 AM   #607
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
OH hell yeah .. DK your 12th car looked good! I'm saving up for a pack now. All I need is for you to convert my deans to internal barrels like Danny should have made them in the first place .
Doesn't someone owe me an appology ?
John St.Amant is offline   Reply With Quote
Old 01-17-2009, 09:15 AM   #608
Trader Rating: 26 (100%+)
-=light=-
Remove the battery keepers, locally we have put some weight in the front of the pack and had to shave the antenna mount a little. It aids in keeping the battery locked in place also.
REDLINE RC RACEWAY
ldp787 is offline   Reply With Quote
Old 01-17-2009, 09:16 AM   #609
-=light=-
I took the holder and ground off the bump in the middle. Then I drilled and countersunk new holes in the chasis plate.
Regards,
Carter
darcydawg is offline   Reply With Quote
Old 01-18-2009, 11:42 AM   #610
I tested my single cell Lipo yesterday, running the Team Losi 180mah 7.4 Lipo for a receiver pack, Tekin RS ESC, Novak 13.5, Spektrum Micro Pro Receiver and the JR3550 Servo. ESC switch off!!!!!!!!!!
I was impressed with how it works, I did struggle a little bit with finding the right gearing though, as well as the settings on my ESC using version 1.89 of the hotwire.
I ended up with about a 77 Rollout, and the settings were Motor at zero timing and the timing and boost on the ESC were maxed, I also used Throttle Profile 4......... I added 119 grams of weight to the battery, I can't remember what the final weight number was, but somewhere around 800 grams
I was about 4/10 of a second off of my best laptimes with my 17.5 4 cell
I managed to run 10:30 without any feel of dumping and motor came off fairly cool!
Anyone using a slightly different setup than this????
XRAY T3'12 17.5, Spec R R1 13.5, CRC GenXL, Grant Galloway Designs ( Painter )
lifeguy is offline   Reply With Quote
Old 01-18-2009, 11:50 AM   #611
sportpak's Avatar
Try dropping the weight closer to 700g. That should help with the speed. The setup will vary a little to settle the darty feeling you'll get. Once you get a better handle and get used to it you should be closer to your previous pace.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 01-18-2009, 01:57 PM   #612
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
What temps are y'alls motors reaching when geared for speed running 1c/13.5?
Old 01-18-2009, 02:04 PM   #613
I try to finish at about 140 degrees or so depending on laptimes. If I get it hotter it seems to fall off. My advice is not to get all that hung up on motor temp unless it's getting hotter than what the motor can handle.
Some times it will run better at 120 degrees and sometimes it runs better at 160. Just depends on the track.
Fred_B is offline   Reply With Quote
Old 01-18-2009, 03:27 PM   #614
Anyone running 1 C/ 13.5 in an 12R5 yet?
Old 01-18-2009, 04:09 PM   #615
buffalobill989's Avatar
Trader Rating: 50 (100%+)
i think stanton is
buffalobill989 is offline   Reply With Quote
The future of 1/12 scale Roland S Electric On-Road 1004 06-16-2017 02:04 PM
SMC 5700mAh 25C Single Cell Lipo Danny/SMC Electric On-Road 352 05-14-2009 04:03 AM
Trackside 1/12th scale racing Ike Wisconsin & Illinois Racing 41 03-31-2009 11:42 AM
ROAR 1/12 weight limit miller tyme Electric On-Road 171 01-09-2009 04:14 PM
Why choose LiPo? wingman2 Electric On-Road 16 12-17-2008 06:51 PM
1/12 lipo the mighty thor Electric On-Road 7 12-07-2008 03:01 PM
