Old 01-06-2009, 09:52 AM   #511
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
The ENTIRE Industry is diluted....
John St.Amant is offline   Reply With Quote
Old 01-06-2009, 12:39 PM   #512
Moderator
Clegg's Avatar
Originally Posted by Fred_B View Post
Hobby King has boosters back in stock. I have one of these and it's been working fine. I did rewire it to have a switch on the input side and I redid the wire length on the output. Been working like a champ and cheap enough to get a spare or two.
http://www.hobbycity.com/hobbycity/s...idProduct=7884
My Tekin is rather unhappy without the booster also. You'll need some kind of booster or receiver pack to have a reliable personal transponder signal anyway. I would also suspect that some of the systems that "work" are limiting the power some due to radio priority circuits.
I just ordered 4 of these. (being so cheap). I am curious on how long they will last with such a low current of 1.5A as a peak. From my calcs 2A was the min peak for these kind of boosters taking into account digital servos, 2.4ghz receivers, transponders, and the control electronics in a ESC.
I got 4 so If I kill one I can play around with running two in parallel. I think these should be quite light without the heavy shrink wrap an replacing the connectors with something more functional in a 1/12th.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 01-06-2009, 01:14 PM   #513
I haven't had any issues with the 1 amp booster. It doesn't even get warm during an 8 minute run even when I ran modified (makes the servo pull more). You might need something a little bigger for a 10th or oval car but it seems to be fine in 12th.
Just be careful when you rewire the booster because the caps need to be held down by the shrink tube. I think mine weighs about 25 grams or so with all the wires and a switch.
Fred_B is offline   Reply With Quote
Old 01-06-2009, 01:53 PM   #514
Mike Haynes's Avatar
I just wanted to chime in with the difference between 17.5 4 cell and 1c 13.5. They are very similar, and if anything i think the nimh car still feels better, however is much more work to setup and maintain. Here is my basis for comparison: Over the past few weeks i have driven Donny Lia's cars several times during his testing stages. I would say at this point that his lipo car is well dialed in and obviously his 4cell car is good. I have been able to drive both cars back to back, and done the same lap times with both. This past weekend i raced his lipo car, and we were even matched power wise, to the degree that we would go down the straight away within 6 inches of each other. The car i raced weighed 706grams.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 01-06-2009, 02:47 PM   #515
Moderator
Clegg's Avatar
The Caps? as in capacitor? is being held in place by the shirink wrap? I dont quite follow, but I will see whats what when I get mine in hand in a few days.
Old 01-06-2009, 03:23 PM   #516
You'll see what I'm talking about when you get the shrink wrap off. I reshrunk mine and it looks like new.
Old 01-06-2009, 03:45 PM   #517
PartTime's Avatar
Got any pics of that installed??
DK
PartTime is offline   Reply With Quote
Old 01-07-2009, 12:18 PM   #518
Schillaz's Avatar
I would like to see some pix and some wiring diagrams as well.
(lipo and booster and switch)
thanks
Schillaz is offline   Reply With Quote
Old 01-07-2009, 12:27 PM   #519
Trips's Avatar
Trader Rating: 16 (100%+)
Back in 1979 or so, when dinosaurs still roamed the earth, we didn't have ESC's or BEC's... in a 6 cell (7.2v) 1/12 scale car, we ran one or two diodes in line from the battery to the receiver to drop the voltage and not fry the receiver or servos. Seemed to work fine. For 4 cell indoor racing, we just took the diodes out of the wiring.
Losi sells a fairly cheap 7.4 LiPO for the 1/36 scale Micro-T that could make a good rx pack, can anyone think of a reason why simply putting a diode or two in line to the receiver wouldn't be a cheap, easy, effective way to drop the voltage and not have to find a regulator? If it worked in '79 it ought to work now... At least until Novak's booster is available...
I know today's digital servos draw more current than the servos did back in '79, but back then we ran two servos... so I don't think current draw from one small digital should much of an issue...
MARSHAL!!
Trips is offline   Reply With Quote
Old 01-07-2009, 12:34 PM   #520
rcterp's Avatar
Trader Rating: 35 (100%+)
I'm just running a 7.4 volt receiver pack direct into my Spektrum receiver. The servo works great, the receiver works great, and the transponder works great. I'll let you know if I see smoke or anything blows up; but right now I'm just going to keep pumping 7.4 volts into it.
rcterp is offline   Reply With Quote
Old 01-07-2009, 12:37 PM   #521
lol U rock rcterp
Old 01-07-2009, 03:48 PM   #522
Tubaboy's Avatar
Which servo are you using? Spektrum has stated that their receiver doesn't care about the voltage on there site. So i'm not worried about that one.
Thanks,
Paul
www.wyomingrc.com | www.wyomingmodelerspark.com
Tubaboy is offline   Reply With Quote
Old 01-07-2009, 03:55 PM   #523
sportpak's Avatar
Trader Rating: 26 (100%+)
Thanks,
Paul
I emailed JR about that and they said simply that my servo (3550) is safe to 6v. You hear of people running it oK, so it really comes down to who you want to believe. I'm to the point of just needing to blow my own stuff up trying things because there seems to be two sides of the fence on everything. Seeing is believing. Good luck finding an answer you want to hear.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 01-07-2009, 04:03 PM   #524
Moderator
Clegg's Avatar
Well my boosters just shipped from HK... I expect them by next monday or so. to me it seems the safest route to go to not over volt your gear. But to each their own. I think in the end the booster not only will be lighter but remove a major maint headache of needing to charge 2 packs for 1 car.
Old 01-07-2009, 07:29 PM   #525
ben73's Avatar
Trader Rating: 40 (100%+)
just dont do it with an airtronics/sanwa.... it fries them
my KO is fine at 7.2V
I now run two diodes in line on the positive battery lead from the lipo to drop the voltage
ben73 is offline   Reply With Quote
The future of 1/12 scale Roland S Electric On-Road 1004 06-16-2017 02:04 PM
SMC 5700mAh 25C Single Cell Lipo Danny/SMC Electric On-Road 352 05-14-2009 04:03 AM
Trackside 1/12th scale racing Ike Wisconsin & Illinois Racing 41 03-31-2009 11:42 AM
ROAR 1/12 weight limit miller tyme Electric On-Road 171 01-09-2009 04:14 PM
Why choose LiPo? wingman2 Electric On-Road 16 12-17-2008 06:51 PM
1/12 lipo the mighty thor Electric On-Road 7 12-07-2008 03:01 PM
