SMC 4000/25C/3.7V single cell Hardcase pack. >
Old 11-17-2008, 06:21 PM
  #31
Having the pack go soft isn't really an issue as long as everyone has it. When the speedo's start to get updated to run on low voltage it might be an issue for a bit but it's not that big of a deal.
Having a speedo that can download updated firmware is going to be a good thing with the lower voltage packs.
Fred_B is offline
Old 11-17-2008, 06:28 PM
  #32
Matt Howard's Avatar
Losi already has downloadable firmware updates for their esc
Matt Howard is offline
Old 11-17-2008, 07:37 PM
  #33
Company Representative
Danny/SMC's Avatar
I think the issue as that most speed controls have a cutoff that is set around 3.3 volts that when the voltage dips under that it cuts power back to the motor to save it for the reciever. I think this is more a hardware issue than a firmware issue.
Donny Lia has been testing the Novak booster circuit and he told me it works very well.
Danny/SMC is offline
Old 11-17-2008, 08:26 PM
  #34
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
posted on the tekin thread:
Code:
Using the Hotwire there is a custom voltage profile.
You can adjust it down to 3.0v which would be perfect for the 1/12 lipo.
Dayton
Cain is offline
Old 11-17-2008, 08:30 PM
  #35
Danny/SMC's Avatar
I'm sure this will help but I think it's not low enough. The problem is under hard acceleration the voltage will drop under 3 volts for a fraction of a second and the speed control may cut the power when it sees this.
Old 11-17-2008, 08:33 PM
  #36
Tech Legend
Cain's Avatar
if its a software thing, maybe they can go lower?
Cain is offline
Old 11-17-2008, 08:42 PM
  #37
Danny,
how low should it be 2.5??
byron.s is offline
Old 11-17-2008, 08:45 PM
  #38
Danny/SMC's Avatar
I'm not sure how low it needs to be set at. At the moment I think the reciever priority circuits are set at 3.30 volts so I'm not sure how much lower it needs to be set at. I know Novak should have a prototype real soon and from what I was told the new KO can go down to 2.1 volts.
Old 11-17-2008, 11:19 PM
  #39
Ike
Ike's Avatar
Any chance you can confirm that the KO and possibly the new Orion which is based on the KO will work?
Ike is offline
Old 11-18-2008, 05:34 AM
  #40
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
Is it a problem for the lipo to be discharged below 3 volts? I thought the reason for the cutoff was to keep the lipo from over discharging. 3 volts per cell is the limit, right?
andrewdoherty is offline
Old 11-18-2008, 07:03 AM
  #41
buffalobill989's Avatar
Trader Rating: 50 (100%+)
danny you have email
buffalobill989 is offline
Old 11-18-2008, 07:19 AM
  #42
Danny/SMC's Avatar
I will send a pack to Josh Cyrul as he has one of the new KO units and see what he figures out. If the current speed controls have a 3.3 or so cutoff I'm pretty sure 2.1 should be fine.
Old 11-18-2008, 07:21 AM
  #43
Danny/SMC's Avatar
Actually Lipos can be discharged down to 2.8 volts per cell. The voltage will drop a bit lower only under acceleration so it's not a constantly under 3 volts.
Old 11-18-2008, 08:40 AM
  #44
I have a quick Q I bought a 5000 lipo with 7.39 volts and IR 6.2 and after about 4 runs the volts went down to 7.2 volts and the IR up to 7.2 I ran the pack back to back 3 qualifing and the main and then store the pack at 7.8 volts for a week I then did 1 cycle and the number was change from what was first on the pack, why is this?
Mutabarucka is offline
Old 11-18-2008, 08:48 AM
  #45
Danny/SMC's Avatar
Where are you attaching the voltage sensing leads ?
Also storing the pack with 7.8 volts is to high. As were getting use to Lipos in high end racing I have noticed that storage charge seems to affect the packs performance. So the key is to use very little storage charge as Lipos don't selfdischarge real fast. I have left packs discharged at 35 amps down to 6 volts and then they sit for 6 weeks and the voltage really hasn't dropped. In one of my tests I kept a pack fully charged for one week and that packs dropped 10 seconds in runtime and the IR went up a bit. So we still are learning as to what keeps the pack in top condition.
