Old 12-24-2008, 09:27 AM   #391
Moderator
Clegg's Avatar
Originally Posted by Danny/SMC View Post
I'm the one who asked Novak to make the Booster and now I'm waiting on them to release the info on the specs and date it will be available. Hopefully they will have this info real soon. I will get in touch with them to see if there is any updates.
Thanks for the reply Danny!
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 12-24-2008, 09:27 AM   #392
Company Representative
Danny/SMC's Avatar
Originally Posted by Josh Keller View Post
Danny,
what brand and gauge wire is used on the SMC 1C LiPo? I'm trying to find the same wire for my speed control. You know it all has to match to be fast LOL!
Thanks,
Josh
It's 14 gauge. No specific brand.
Danny/SMC is offline   Reply With Quote
Old 12-24-2008, 01:08 PM   #393
Regional Moderator
kumpol's Avatar
Originally Posted by 360rcspeedway View Post
The one major thing I have noticed is the window of getting a car to work with lipo is HUGE. You can take a car thats tweaked a lil and has chuncked or peeling rear tires and just never know it with a lipo car. Another real benefit for the class to attract newbies.
+ better tire wear!
kumpol is offline   Reply With Quote
Old 12-26-2008, 06:43 PM   #394
Moderator
Clegg's Avatar
So I got my SMC pack in hand, and am looking at how to get it to work with the battery position system in the BMI 12RR. How much material is the case (Thickness) in the center valley between the two center cells and the battery itself? Just currious if I could take a dremel or a file and carefully just extend that valley to let the back sit better over the battery bar.
Old 12-26-2008, 06:57 PM   #395
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Wouldn't it be easier, and safer, to modify the battery positioner instead of the battery case?
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 12-27-2008, 12:36 PM   #396
Danny/SMC's Avatar
Not sure what your trying to accomplish but it's very easy to damage the cells. The case is 1.5mm thick and the cells should be very close to the wall of the case.
Old 12-27-2008, 01:28 PM   #397
Moderator
Clegg's Avatar
Ahh thats a bit thinner than I thought it may be. I was simply looking for a way to use the SMC LiPo pack in the same chassis configuration as 4 cell to make going back and forth easier. But I think its pretty clear that I cant use the O Ring cell retainer, or the battery holder with the SMC pack. Which is fine, I just need to buy a roll of tape
Old 12-28-2008, 08:15 AM   #398
sportpak's Avatar
Trader Rating: 26 (100%+)
In my DB12 I had to completely remove the battery positioner and make little aluminum locators to position the battery. It let the battery sit lower in the chassis and clear the shock.
I run a 2007 Sphere Comp speedo, 120 nimh receiver pack, all wires intact., and speedo switch OFF. I'm using micro Spectrum receiver, a JR3550 servo, and aHigh Velocity 13.5. 8 minute run I'll use 70mah on the receiver pack, no dumping or spongy feeling, plenty of rip the entire time. I'm currently rolled out about .15 less then I was with a 17.5 on nimh. I'm still getting a feeling for the gearing, but the power is nice.
My setup has evolved quite a bit. Just changing batteries made the car real darty and inconsistent. I've been working on mellowing the rearend yet trying to keep the new level steering. I think I'm getting faster because I'm learning to handle the car with each run.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 12-28-2008, 12:45 PM   #399
Danny,
I had the chance to run 1 Cell in my 1/10th oval car (standard oval pan car). It worked great.
For what it's worth:
Weight 34 oz with no lead and with a receiver pack. Speed similar to 17.5 4-cell using a 13.5 motor in the car. Rollout was slightly higher than 17.5 4-cell but there may be a better number with more trial & error. The car was my 13.5 car which is a middle of the road ride. I changed almost nothing except tires (softer right front and harder right rear).
Motor temperature never went over 125 and recharging took 1800 maH into the 4000 maH pack. I charged @ 6 amps. I used a 5-cell receiver pack and each run it took 30 - 40 maH to replenish it. I never tried without it but the pack voltage after a 4 minute run was 3.8 so I think you need one.
I realize this is the onroad thread but it looks very viable in oval to me.
ntron1 is offline   Reply With Quote
Old 12-28-2008, 02:05 PM   #400
ben73's Avatar
Trader Rating: 40 (100%+)
I know there has been some testing with mod motors - any update on which setup is making 8 minutes?
ben73 is offline   Reply With Quote
Old 12-28-2008, 02:12 PM   #401
Moderator
Clegg's Avatar
I am also curious what kind of parity there is with 10.5T BL/LiPo and a 13.5T BL/4cell. Can the 10.5 make it reliably 8 minutes? (preferably 10 or 12 minutes in order to ensure no dumping and none of that stupid drama from years past where you couldnt take a hot lap before a race because you may dump before the end.)
Old 12-28-2008, 02:45 PM   #402
Matt Howard's Avatar
I thought the reason SMC went with "only" a 4000mah capacity is to get back to where you couldn't drive a mod 1/12 car strapped the whole 8 minutes. Myself being a long time 1/12 driver long for the days when there was strategy involved in mod 1/12 racing and the cars didn't go 100mph. How in the world did we race 1/12 back in the day with 1400SCR's and 1700SCE's
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-28-2008, 02:54 PM   #403
Moderator
Clegg's Avatar
I understand that, but since NiMH cells offer a certain level of performance already, if LiPo cant equal it - its going to be very handicaped to capture the market. Wanting the racing to go back to the old days just by limiting the advancement of technology and causing the same BS from back then isnt really effective. Also since most of us dont have LiPo cut offs for 1 cell packs... making a pack that will run dangerously low in a mod class is just asking for cell damage to happen.
Old 12-28-2008, 02:57 PM   #404
If I remember reading right it was Josh Cyrul that asked Danny to limit the pack to 4000mah, but what does he know
RCTech #361
Old 12-28-2008, 03:03 PM   #405
Danny/SMC's Avatar
Read post 381 as a 4.5 has been tried and worked for 9 minutes. A 10.5 will have no issues running 8 minutes as Donny Lia ran 14 minutes with a 13.5
Yes our goal was to slow mod down and keep the price lower. There is room left inside the case to bring up the runtime and C rate.
On the ROAR weight limit thread I mentioned that maybe we should do 17.5/1 cell Lipo and 8.5/ 1 cell Lipo as the expert class. So for those who think 17.5 would be to slow for them should race in the 8.5 class.
The future of 1/12 scale Roland S Electric On-Road 1004 06-16-2017 02:04 PM
SMC 5700mAh 25C Single Cell Lipo Danny/SMC Electric On-Road 352 05-14-2009 04:03 AM
Trackside 1/12th scale racing Ike Wisconsin & Illinois Racing 41 03-31-2009 11:42 AM
ROAR 1/12 weight limit miller tyme Electric On-Road 171 01-09-2009 04:14 PM
Why choose LiPo? wingman2 Electric On-Road 16 12-17-2008 06:51 PM
1/12 lipo the mighty thor Electric On-Road 7 12-07-2008 03:01 PM
