Old 12-14-2008, 12:35 PM   #331
360rcspeedway's Avatar
BTW
Have local racer Alex Valdes running my car today
In the first round:
Fast lap 9.32
Ran a 9.37 at the 7 min. mark.
finished 9.5/9.6 with a couple mistakes.
Not bad.
360rcspeedway is offline   Reply With Quote
Old 12-14-2008, 01:10 PM   #332
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Ive seen a few of these Novak boosters and from what I could tell was it was only for bringing up voltage for the transponder... nothing else. I don't believe it is engineered to take the current needed to run the servo and reciever. and its $25 or more.
John St.Amant is offline   Reply With Quote
Old 12-14-2008, 01:13 PM   #333
Company Representative
Danny/SMC's Avatar
Novak will be releasing info shortly on the single cell Booster. It's not the same as the transponder booster currently available.
Danny/SMC is offline   Reply With Quote
Old 12-14-2008, 01:17 PM   #334
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Hey 360
Oops. Skimmed right over the part about the motor.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 12-14-2008, 01:39 PM   #335
Kewl... I hope that Bob comes up with a great product for us . Even with my 4 cell packs in my 12R5 I had to run a flight pack as the voltage was too low for my Futaba Fasst2.4 , it was shutting down durring hard acceleration. Once I wired a 5 cell pack to it my problems were solved.
Old 12-14-2008, 01:50 PM   #336
I'm running FASST receiver in my DB12RR no rx pack 4 cell 17.5motor. I've never had any problems with shut down during acceleration. What motor are you running? ESC? What kind of batteries? I'm also not the only one at my track running FASST in 4 cell without problems. Installing the 5 cell may only be covering up the problem, not solving it.
Three words...
Old 12-14-2008, 04:31 PM   #337
I have the Novak GTB 4 Cell , a Hacker 17.5 rolling 3.1 inches, and Orion 5300 SHO cells. I do have to admit that I didn't really set up the speedo fully . I just ran the factory settings . Perhaps one of the settings was for cut off that i havnt set yet . Gotta check that out too
Old 12-14-2008, 04:45 PM   #338
You definitely should check your settings. If you are running 4cell NiMh, make sure you have the voltage cut off turned off completely. The voltage cutoff is for LiPo use only.
The other thing I've seen ppl do is set the throttle EPA too high when programming the ESC to their radio. The throttle forward and brake EPA should be at 100%, not maximum. Most radios throttle EPA can be turned up to 125% or more, these higher values are for servos in situations where more throw is needed. Going higher than 100% EPA when programming their ESC can confuse the ESC so to speak.
If your EPA is higher than 100% turn them back down, then reprogram the ESC to your radio.
Hope this helps.
Three words...
Old 12-14-2008, 04:53 PM   #339
Novak dirrections suggest otherwise.. "set to max"
only the speed passion wants to set it at 100... no higher.
Old 12-14-2008, 05:04 PM   #340
In that case double check with Novak as to what they mean by Max. Make sure they are clear to what numerical percentage they want you to use.
Three words...
Old 12-14-2008, 05:49 PM   #341
I haven't found a radio yet that has a problem with full expo during set-up on a Novak.
If you're having a problem running 4 cell on a Novak it's probably the receiver. I can run my KO stuff until the car is pretty much dead but some of the other 2.4 stuff has a minimum working voltage.
Unregistered is offline   Reply With Quote
Old 12-14-2008, 05:57 PM   #342
EPA not expo.
Myself along with another driver are both running 4 cell 17.5 with FASST 2.4, no receiver pack, no issues. We're trying to figure out why John needs an rx pack, and covering all possibilities.
Three words...
Old 12-14-2008, 05:57 PM   #343
CraigM's Avatar
Trader Rating: 34 (100%+)
anyone tried this pack in mod yet?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 12-14-2008, 06:10 PM   #344
EPA is what I ment, never had a problem with it on a Novak. If it runs and then cuts out it's probably not the speedo. It probably is something to do with the receiver.
Old 12-14-2008, 06:17 PM   #345
Danny/SMC's Avatar
Donny Lia will be trying it in the next few days. I think it will be fine and I think a 3.5 or 4.5 should be good but we will see what he finds out.
The future of 1/12 scale Roland S Electric On-Road 1004 06-16-2017 02:04 PM
SMC 5700mAh 25C Single Cell Lipo Danny/SMC Electric On-Road 352 05-14-2009 04:03 AM
Trackside 1/12th scale racing Ike Wisconsin & Illinois Racing 41 03-31-2009 11:42 AM
ROAR 1/12 weight limit miller tyme Electric On-Road 171 01-09-2009 04:14 PM
Why choose LiPo? wingman2 Electric On-Road 16 12-17-2008 06:51 PM
1/12 lipo the mighty thor Electric On-Road 7 12-07-2008 03:01 PM
