Old 11-25-2008, 05:39 PM   #166
sportpak's Avatar
Trader Rating: 26 (100%+)
Originally Posted by KHoff7 View Post
13.5 geared correctly and no dumping feeling at all.
The dumping feeling then may come from over gearing? Or is it the speed control? Was your gearing the same? And this is with a 300mah lipo?
It sucks I just fell in love with my Tekin RS, and now may have to go back to the GTB.
Wow....
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 11-25-2008, 05:46 PM   #167
reenmachine's Avatar
Originally Posted by TVMRocket69 View Post
And if U would've my post here U would have nothing to say. Now U sound like someone else I know that only wants to start trouble. Learn to read I'm agreeing with what they are trying to do. Do U understand. or do I have to use smaller words for U.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 11-25-2008, 05:47 PM   #168
PM me if you want to sell the RS
Really.
Pete Waydo
Old 11-25-2008, 07:15 PM   #169
sportpak's Avatar
Really.
Vulture.
Old 11-25-2008, 07:21 PM   #170
KHoff7's Avatar
Wow....
Here is the best way I can describe my setup. (you may not need a gtb (I have no idea if you do or not))
Take the gtb and plug it into the receiver as normal
Use a receiver pack and plug it into an empty slot on your receiver (I used a 160 mah pack and I was only taking about 50 mah off per run)
Plug the Lipo single cell into your gtb as normal
Do not turn on the speed control (sounds weird but works)
use a 13.5 to equal stock speeds
There you have it it will provide equal stock speeds and have NO dumping AT ALL during an 8 minute run.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 11-25-2008, 07:23 PM   #171
KHoff7's Avatar
Wow....
And no the dumping feeling was not from over gearing, I was actually undergeared previously in order to preserve the pack. Just gear to best suit your track as you would normally. Gearing seems to be correct around 2-4 teeth under usual 17.5 gearing.
Karl Hoffmeister
Old 11-25-2008, 08:05 PM   #172
Company Representative
Danny/SMC's Avatar
From what I was told by Novak is that not all speed control have the same layout so not all speed controls will act the same. So far the GTB with a reciever pack and the switch turned off seems to work but I know that a Tekin will not as Donny Lia has tried it. Nexus Racing seems to have had good luck with the LRP and I know that the new KO should work but we will only have tests done in a few weeks.
Danny/SMC is offline   Reply With Quote
Old 11-25-2008, 08:29 PM   #173
RCSteve93's Avatar
Speed Passion?
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 11-25-2008, 09:21 PM   #174
Thumbs up
I put new gearing and now no dumping feeling for the whole 8 mins.
onroaddude is offline   Reply With Quote
Old 11-25-2008, 11:48 PM   #175
Just got back from running it with a gtb with all wires intact and not turning the gtb on. It worked for the whole 8 minutes and did not drain the receiver pack anymore than usual. This is the setup im running from here on out.
Which GTB esc are you using?
RoyU is offline   Reply With Quote
Old 11-26-2008, 07:31 AM   #176
R/C Tech Charter Subscriber
Send a message via AIM to acyrier
I was told by Tekin, if I wanted to run the RS and the single cell lipo to cut the red wire from the esc if I wanted to use a reciever pack. They (Tekin) does not recommend NOT cutting the red wire, as you are then backfeeding the power into the ESC instead of the path it is supposed to take (got a little too technical for me)
by running a reciever pack (I use the losi micro lipo) I'm feeding my servo, Receiver and personal tranpsonder with 7.4 volts. I have been running my stuff this way (with the exception of the RS) for over a year and havn't had any problems. I'm waiting on my single cell and plan on running it the same way. so the single cell will be running the ESC and motor, while the receiver pack will be running the servo, reciever and PT.
acyrier is offline   Reply With Quote
Old 11-26-2008, 07:44 AM   #177
KHoff7's Avatar
The regular 6 cell version but I took the heatsink off.
Karl Hoffmeister
Old 11-26-2008, 05:19 PM   #178
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
I didn't cut the red wire in the "J" connector on the RS. Just use an x-acto blade to gently lift the retaining tab, pull the red wire out, and tape it off. If you ever need to use the Hotwire, simply re insert the red wire.
Basically the Tekin ESC dosen't seem to care where it gets voltage from. If it sees voltage at all, either through the "J" connector or the main power leads, it will try to send the voltage to the motor.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 11-26-2008, 06:03 PM   #179
protc3's Avatar
Wow, THis is pretty cool. Im going to need to get one of these packs and mess around with it. I would like to find a way to make the cars work really well without adding the weight. I will be ordering one up next week.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 11-26-2008, 06:09 PM   #180
Like I said, Tekin told me to do it the way I described, so that's what I'll be doing. I would suggest, if a manufacturer says to do it a particular way...probalby good idea to do it that way. I was doing it the way you described until I had that conversation with Jim (tekin prez). And it did act "normal" but though that conversation, I changed the way I was doing it.
The future of 1/12 scale Roland S Electric On-Road 1004 06-16-2017 02:04 PM
SMC 5700mAh 25C Single Cell Lipo Danny/SMC Electric On-Road 352 05-14-2009 04:03 AM
Trackside 1/12th scale racing Ike Wisconsin & Illinois Racing 41 03-31-2009 11:42 AM
ROAR 1/12 weight limit miller tyme Electric On-Road 171 01-09-2009 04:14 PM
Why choose LiPo? wingman2 Electric On-Road 16 12-17-2008 06:51 PM
1/12 lipo the mighty thor Electric On-Road 7 12-07-2008 03:01 PM
