Old 11-15-2008, 10:29 PM   #1
rcaddict02's Avatar
Exclamation newbie whats the best brushless system for top speed runs
Hello all, im an electric newbie, i have a tamiya tb-02, i want to put a brushless system in it, but only want the fastest just for speed runs. can any one help me with a set-up, also the best in-expensive battery to use with this system,,
also does any one have a list of parts i will need to convert from tub chassis to the evo III chassis, i have main frame, upper chassis , and front and rear towers. what else will i need to make it an evo III
rcaddict02 is offline   Reply With Quote
Old 11-15-2008, 11:39 PM   #2
Drifting101's Avatar
Well first of all what ever you do dont cheap out on a battery.....the best on the market are SMC Lipos IMO
Then just buy a cheap rolling evoIII because your TB02 wont stand up to speed runs
The fastest motor esc combo is probally a LRP 3.5 combo
Regards
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 11-16-2008, 07:16 AM   #3
You could always get a Team Tekin 9000kV motor and a Tekin R1 Pro ESC.
9000kV*11.1V=...enough
But yeah, a lot of hop-ups would be needed.
Tamiya TL01
Tamiya TA05 (ish)
Associated B4 3.5r
Limerick91 is offline   Reply With Quote
Old 11-16-2008, 08:00 AM   #4
Juanchoyo's Avatar
What about a Mamba Max??? It can handle 14.8V.... but use an external BEC or it'll heat up too much.....
Now... motors... I dunno how it will go with a Speed Passion 2.5....
FoxRC Hobby Club
http://foxrc.foroactivo.net/
"Mas que un hobby, un estilo de vida. Algo que corre en los circuitos de mis venas"
.....ChOoJuAaAnNnn, Sebastian, Juancho... como quieran XD.... o Sebastian Oviedooo...
Juanchoyo is offline   Reply With Quote
Old 11-16-2008, 08:31 AM   #5
lutach's Avatar
Sent you a PM. See if you like my ESC.
http://www.youtube.com/watch?v=BikJALhTd8s
http://www.rc-monster.com/forum/showthread.php?t=8651
http://www.cnn.com/2008/HEALTH/conditions/04/01/autism.ireports/index.html (My daughter's video is the last one)
lutach is offline   Reply With Quote
Old 11-16-2008, 08:48 AM   #6
todd8603's Avatar
Default in case
If you want a 2.5 for this purpose. I have one for sale at www.fastcats.ca and www.durhamrc.com. This 2.5 was used by me for about 6 packs, was beating the nitro cars for straight speed regularly. IIF I could keep it on the track.
todd8603 is offline   Reply With Quote
Old 11-16-2008, 09:36 AM   #7
rcaddict02's Avatar
thanks for the help. what hop ups do i need to get i have a few allready,
Some of the Tamiya Hop-ups added are:
Lightweight suspension
Aluminum steering system
Rear CF brace
Center CF brace
Full bearings
Aluminum rear uprights
Aluminum toe adjusters
Rear lightweight (blue)CV shafts and joints
Front CV shafts and joints
TRF Blue shacks
Sway bar set
Aluminum motor mount
Aluminum wheel hexes and nuts
Aluminum motor heatsink
i just bought this car, i would really like to use it, im only looking to do around 80 mph
Old 11-16-2008, 12:39 PM   #8
rcaddict02's Avatar
bump
Old 11-16-2008, 01:09 PM   #9
At 80mph speeds I think your going to need a high down force body, and some serious skills. I hope you know it's not "only looking to do around 80 mph" it's HOLY COW I HIT 80MPH! just a few years ago people were having a hard time hitting 100mph on 24.0v+ systems. I understand brushless was just coming around back then, but to hit 80mph is no small feat in a TC.
A few mods I would think we help... lock your diffs, if do move to the Evo III set up I would tape up any holes in the bottom of the chassis, to prevent any air get up in there and lifting your car making loose traction. Also I'm not sure if going as light as possible will work out for the best. At those speeds you need a ton of traction, and the extra weight will help. Most of the time it's crazy gearing and crazy power that will get you to crazy speeds
Take a look at RC Car Actions speed challenge for some of the things that those guys did. I know a couple of people had their cars "fly" of the track they were going so fast. I'm sure someone on here is going to throw in the whole Traxxas Rustler VXL going 70+. RCCA did a review to see if it really would go 70+. They had to gear it to the moon, change parts, and throw in a HUGE 3s lipo and I think it only got up to 68MPH IIRC.
Good luck and let us know how it all works out
Jay
~ Jason Kennedy ~
~ Sweep Racing Tires ~
~ TQ Wire~Wire~
pyro18t is offline   Reply With Quote
Old 11-16-2008, 05:49 PM   #10
trailranger's Avatar
Castle Creations would be a good start for all out speed.
No Matter what ESC or MOTOR, keep the RPM under 65,000 for 540 (36mm) motors. Most rotors will blow after that. Some make take the stress beyond that, but not for very long.
Hopefully if you go with a higher voltage setup (14.8+) less amperage is needed so less burned up ESC's and Motors. High voltage requires BEC moduals to keep the ESC from cooking.
"If everything seems under control, you're just not going fast enough." - Mario Andretti
trailranger is offline   Reply With Quote
Old 11-16-2008, 07:33 PM   #11
tomt2's Avatar
Originally Posted by pyro18t View Post
A few mods I would think we help... lock your diffs, if do move to the Evo III set up I would tape up any holes in the bottom of the chassis, to prevent any air get up in there and lifting your car making loose traction. Also I'm not sure if going as light as possible will work out for the best. At those speeds you need a ton of traction, and the extra weight will help. Most of the time it's crazy gearing and crazy power that will get you to crazy speeds.
I don't think you want to lock both diffs, have you ever driven a mod TC with a spool in the back? it's near impossible to keep straight when you give any throttle. You'd be better of with a really well built ball diff or a gear diff if you can get one for it.
tomt2 is offline   Reply With Quote
Old 11-16-2008, 08:12 PM   #12
rcaddict02's Avatar
thanks , tom
Team Durango DNX408v2, Reds racing R5 , Alpha 2090, Savox, Protek, Spektrum.
Tamiya TB-02
Hobao hyper 7
Losi mini sct
Traxxas Slash
Old 11-16-2008, 09:34 PM   #13
Accaully NO. I've only run a spool in the front. It seemed to help with my straight line squirt.
Jay
~ Jason Kennedy ~
~ TQ Wire~Wire~
Old 11-18-2008, 07:17 PM   #14
rcaddict02's Avatar
bump
Tamiya TB-02
Hobao hyper 7
Losi mini sct
Traxxas Slash
Old 11-18-2008, 08:11 PM   #15
rcaddict02's Avatar
Rear CF brace
Center CF brace
Full bearings
TRF Blue shacks
Sway bar set
any one ,any one
Tamiya TB-02
Hobao hyper 7
Losi mini sct
Traxxas Slash
