Old 02-10-2004, 08:28 AM   #1276
howard hudson's Avatar
R/C Tech Charter Subscriber
Originally posted by ptjonesus
Does anybody have a setup for the D1 on low bite asphalt with rubber tires. I run stock class and my car spins out too easy comming out of the corners.
Go to this thread It the first warpspeed thread it has a lot of set ups for the D1 on itclick me You will have to scroll the pages to find them
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 02-10-2004, 08:42 AM   #1277
IT looks like all the setups are for carpet or for crs using form tires. I need a setup for low bite asphalt with rubber does any have this kind of setup.
ptjonesus is offline   Reply With Quote
Old 02-10-2004, 08:53 AM   #1278
didnt look hard enough
Ashphalt setup
Front
2 kickup
0 castor
1 toe out
ntc rack
copper spring
standard shock tower outer hole
front arm outer hole
camber link lower inner
front swaybar
Rear
no swaybar
red springs
rear shock tower outer
rear arm inner hole
R+3+0
shocks 40 weight oil #2 piston all the way around
tires take off 27
here is one from harley
Old 02-10-2004, 09:00 AM   #1279
here is mine that I run In cali
FRONT
Blue springs
#2 piston
50w oil
rear tower on front
top shock mount third hole in
VerII arms lower mount outside hole
camber link inside upper
stock rack
4degree castor
F-o block
stock steering blocks
front sway bar(standard)
4.5mm ride hight
4mm droop
.5 degree toe out
1 degree neg camber
REAR
gold springs
#2 pistons
40woil
top shock mount outer hole
VerII arms out side mount hole
camber upper inner
rear hubs forward
losi 0 degree hubs
no sway bar
r-3-2 block
5mm droop
5mm ride hight
1.5 neg degree camber
Old 02-10-2004, 09:13 AM   #1280
which Losi rear hubs do you use? I tried the xxxs rear hubs but they are to long where the dogbone doesn't reach. I think I bought the wrong ones.
kevinm is offline   Reply With Quote
Old 02-10-2004, 09:18 AM   #1281
Thank you I will try this setup today
Old 02-10-2004, 09:24 AM   #1282
Thats wierd those are the ones I used and didnt have any problem
Old 02-10-2004, 09:25 AM   #1283
Where do you run at?
Old 02-10-2004, 09:37 AM   #1284
Man I must be losing my mind. I bought three sets of them and they stick out to far and the dogbone doesn't reach. I will take a picture tonight and show you the problem.
Old 02-10-2004, 09:47 AM   #1285
OK and your sure they are for the XXX s and not one of the offroad cars
Old 02-10-2004, 09:51 AM   #1286
Before I answer I'm gonna double check. I can't believe that I ordered the wrong ones twice but anything is possible.
Old 02-10-2004, 09:59 AM   #1287
yup starnger things have happened
should be pn 9854 from losi catalog
Old 02-10-2004, 10:01 AM   #1288
I run at delta raceway asphalt , stockton raceway carpet and hobbytown newark ca. asphalt
Old 02-10-2004, 10:03 AM   #1289
so you are way up north. might get up there some time and race with ya
Old 02-10-2004, 10:09 AM   #1290
we are having the cali state on road carpet championships on march 12-14 come check it out. for more infor check rcracing.com stockton raceway
Warpspeed Demon II FT TC3 R.Fenstermacher R/C Items: For Sale/Trade 21 10-29-2004 04:40 PM
WarpSpeed Demon Chasis for TC3 rc10gt R/C Items: For Sale/Trade 0 07-27-2004 03:21 PM
Warpspeed Demon TC3 R/C HEAT R/C Items: For Sale/Trade 3 05-11-2004 04:05 PM
warpspeed demon for trade burbs R/C Items: For Sale/Trade 0 04-19-2004 07:08 PM
warpspeed demon rcdave4 R/C Items: For Sale/Trade 7 04-14-2003 08:31 PM
