Old 01-12-2004, 01:29 PM   #901
Default Re: Re: HEY HOWIE
Originally posted by howard hudson
HOUSE
The BIG RED TENT BABY>!!!!
Mark Barden .
mb racer is offline   Reply With Quote
Old 01-12-2004, 02:22 PM   #902
howard hudson's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: HEY HOWIE
OH that house !!! yup we was pimp'n hard with that new crib
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 01-12-2004, 02:24 PM   #903
Default Re: Setup
Originally posted by R.Fenstermacher
Howard, could you post your setup for the D2 thanks!
Ill put it up latter 2 night at work right now
Old 01-12-2004, 03:40 PM   #904
Default Where to get?
Can you buy these kits in a store or is there an online store? Chicagoland area.
If I already have a FTTC3 so all I need is just the conversion kit?
For foam carpet racing do I get the D1 or the D2?
slow is offline   Reply With Quote
Old 01-12-2004, 04:42 PM   #905
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Slow, yes all you need is the conversion kit. It seems that for carpet the D1 is the better of the two cars...even more so when the traction comes up. Send an email to Victor @ [email protected] to contact him for pricing and to order.
BTW, are you the one guy Nexus (Anthony Isla) was telling me about that was looking for a Demon? If so, PM me, I have another kit I'm not using. It is in great condition, if you are interested.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 01-12-2004, 04:44 PM   #906
The D1 is going to be easier to drive. The D2 is very sensitive, but very fast if you can control it. Most popular setups fpr the TC3 will apply better to the D1. Contact Vic at [email protected] for local distributors.
Art Jensen is offline   Reply With Quote
Old 01-12-2004, 04:46 PM   #907
Oops, must have been typing at the same time as you Brian.
Old 01-12-2004, 05:18 PM   #908
tmunno's Avatar
Ok Ray, we will have to meet down at the Snowbirds. Thanks to Art for all the extra time and help on Sunday. Your advice and help was appreciated . Also found one old style steel outdrive set for you! see you at the State race on Sat.
Tony Munno
Munnograffix
CFX Paintworks,
tmunno is offline   Reply With Quote
Old 01-12-2004, 06:00 PM   #909
Sweet! Thanks Tony. I will be there Friday night to practice. I will cut the outdrives for the d-rings for you then if you like.
Old 01-12-2004, 07:01 PM   #910
Default D2 set up
here is my D2 set up
Surface med bite asphalt outside
FRONT
#2 pistons
40wt
blue springs
4.5mm ride hight
rear tower up front
upper shock mount 2nd hole from outside
lower outter hole on ver II arms
camber link
tower inner lower
front losi steering knuckles
60 thousands shim under ball stud (bump steer)
front block F-0
stock steering rack with ball studs spaced out parralle with front arms
front stock sway bar
REAR
#2 pistons
35wt
silver springs
upper shock mount tower outside
verII arms outter hole
camber link tower upper inner
at hub outside
rear hubs long setting
r-3-2 rear block
no sway bar
5mm ride hight
Tires
36 sorex w xenon blue inserts
tire additive simple green allowed to air dry
the car was very drivable and was able to put in any where wanted it to go very good rotation
removing the nitro rack hepled the car dramaticly the akerman on it is all wrong and is just to aggressive
Old 01-13-2004, 07:20 AM   #911
rayhuang's Avatar
For those of us going to the Snowbirds-remember to start practicing at 5mm ride height!! AT the Gate last weekend the bite came WAY-up and I had to drop my car from 5mm to 4.5 to keep from tipping in two corners. But I will run at 5mm from now on and make it work.
Old 01-13-2004, 08:19 AM   #912
rayhuang's Avatar
Also-GREAT job guys at the Novak Race.
Doseck in the A-Main of Mod and in stock class Jason Cheng running a Demon was in the B, Brian McGreevy in the C and Seth Turner won the D (running the new Parma Alpha too!!).
Old 01-13-2004, 08:45 AM   #913
Fuzzy's Avatar
Ray,
What is Parma's Alpha body?
Fuzzy is offline   Reply With Quote
Old 01-13-2004, 08:54 AM   #914
rayhuang's Avatar
Fuzzy-check out the thread on the NOvak race and see the pic of Tosolini's car!! Its one of he last posts if you check it soon.
Ray
Old 01-13-2004, 02:58 PM   #915
Ray, cheng wasn't running the car
BTW, for those of you who don't know this, the Stock Foam class at this race was TIGHT...I'd say more so than cleveland probably. My best time was 4 sec from making the show. It's too bad though, I was on a pace in 2nd qual that had I not tapped a board or two late in the race would've put me in the A . Oh well better luck next time, at least I know for myself that the car was good enough and fast enough to run with the front runners. PM me if you want an awesome setup for really high bite carpet w/ foams for stock (D1 3mm)
USVTA Member #211
Warpspeed Demon II FT TC3 R.Fenstermacher R/C Items: For Sale/Trade 21 10-29-2004 04:40 PM
WarpSpeed Demon Chasis for TC3 rc10gt R/C Items: For Sale/Trade 0 07-27-2004 03:21 PM
Warpspeed Demon TC3 R/C HEAT R/C Items: For Sale/Trade 3 05-11-2004 04:05 PM
warpspeed demon for trade burbs R/C Items: For Sale/Trade 0 04-19-2004 07:08 PM
warpspeed demon rcdave4 R/C Items: For Sale/Trade 7 04-14-2003 08:31 PM
