Warpspeed Demon and Demon 2
#767
lol.
#768
uhh...a radio? where?
Oh! oh...the radio....right...
#770
#771
Originally posted by MartinSorlie
Ole C will also be attending, so I guess all of "Team Warpspeed Europe" will be there, if we can call it that....
#772
SNOWBIRDS coming up. if you Demon1 drivers want a set-up to try (Works best in Med to very high grip) for running on Carpet with Foam tires, this is a good one. At Champs I got a lot of people coming up saying how well my car was handling and carrying corner speed. I run a D1 2.5m chassis and 3mm top deck.
This set-up MIGHT be loose on low grip (green Track) and demands a slightly different driving style. If you can Roll throttle into corner you'll like this set-up.
First the stock and 19t set-up.
Anyways-I think shocks are a personal thing (preference), but I like 50 wt AE oil in all 4 and #3 pistons. Purple springs front and copper or IRS silver in back.
FRONT
middle hole on tower and innner hole on arm for shocks. Camber link short and up.
Losi 4* c-hubs with Losi spindles. Ball studs down 0.040" on spindles. NTC3 rack w/ bearings. F-O block. 3mm uptravel for droop (~0 on gauge). Stock sway bar.
Jaco Orange Purple at 2.30" to start.
REAR
Outer hole on tower and outer hole on arms. Camber link long and up with AE hubs. F block in front raised 0.030" and r+2+2 block (lots of kick-up). 2mm uptravel for droop (~5 on gauge).
Jaco purple.
Ride height was ~4.5mm front and back.
Go with Jaco dbl pink/Orange fronts and dbl pink rears in back for Full mod and also go to the r+3+2 rear block and a Buds 0.078" sway bar or IRS Black front springs (32.5 lbs)..
Do the whole set-up-not just what looks easy to do!!
FRONT
REAR
Jaco purple.
#774
Ray i have the adjustable d1 where do you set your rear arms to?
#776
Hey, just wanted to let everyone know I changed my AIM screen name...im getting sick of bab00n14 lol!! new one is wheelmanST
MERRY CHRISTMAS EVERYONE!
#777
Merry X-Mas everyone and thanks for the warm welcome!!!
#778
Merry Christmas and a Happy New Year to Warpspeed.
#780
brian are you coming down for the new years day race at trackside??
