Old 10-06-2003, 08:09 AM   #31
rayhuang's Avatar
Default Awesome D1 set-up
Okay-I know thats awful big of me to post awesome-but it really is!! This is for Foam tires, stock motor and Ozite carpet.
FRONT
60 wt oil #3 piston. Yellow Spring or White.
Shock in outside hole on tower, inside on arm.
Camber link up and short or up and long.
F-0 block, 6-degree c-hubs
NTC3 rack w/ Losi steering spindles.
Sway bar-I ran stock AE-but think the Buds 0.078" would be better.
REAR
50 wt oil #3 pistons, Purple springs.
Shock middle hole on top-outer hole on arm.
Camber link as high and as long as possible.
r-2-0 rear block, Losi 1/2 degree blacks on backwards.
JACO OR/Purple front tires JACO Purple rear tires 28mm.
NIftech and or Jack the Gripper traction compound.
Old 10-06-2003, 08:22 AM   #32
Fuzzy's Avatar
Default Re: Awesome D1 set-up
FRONT
REAR
Ray, your last e-mail that you sent to me about the Demon setup didn't mention th rear Losi 1/2 degree blocks. In regards to the rear block, is there a difference between r-2-0 and r+2-0 or is everyone referring to the same thing? How much rear toe will I have with the Losi 1/2 carriers reversed?
Fuzzy is offline   Reply With Quote
Old 10-06-2003, 08:26 AM   #33
rayhuang's Avatar
Default Losi rear hubs!!
Dave-Thats because you said you wanted a set-up that didnt have as much front traction and steering!! So for you I recommended the stock rear hubs. This set-up is 1 degree rear toe in I do believe!!! What I sent you had 2-degrees rear toe in. 2+0-0 is the same as 2-0-0!!!
It s fast-but at the expense of feeling planted while turning in. Cars edgy at turn in like this.
Old 10-06-2003, 08:58 AM   #34
Doug D's Avatar
Trader Rating: 54 (100%+)
Thanks Ray,
If your running the Losi 1/2 degree hubs, and if put on backwards then they will take out a 1/2 degree of toe-in. So by your set-up I think your running 1.5.
Also, are you running six degrees of castor? i.e. Six degree "c-Hubs"?
Thanks!
Doug D is offline   Reply With Quote
Old 10-06-2003, 09:00 AM   #35
Doug D's Avatar
Oh yeah before I forget, are you running the rear tower up front or standard front tower?
Thanks, Again!
Old 10-06-2003, 09:08 AM   #36
rayhuang's Avatar
Doug,
YOur welcome!! Axiom and I are running this basic set-up and love it!! Only difference is Axim is TQ'ng and winning the A!!!
I use 6-degree LOsi C-hubs. I am going to try 4 degree next race. See if car will carry more speed in the longer corners.
And last I run the normal shock tower up front.
Old 10-06-2003, 09:58 PM   #37
speedxl's Avatar
R/C Tech Charter Subscriber
hey guys some company named bmi is advertising on another thread that they are making another tc3 conversion whats up with that! guess we have to show we got the best car.
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 10-06-2003, 10:56 PM   #38
howard hudson's Avatar
its not that big ugly one is it. the one with the side stiffners and the nitro suspension?????
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 10-06-2003, 11:06 PM   #39
R/C Tech Founder
Just don't start a war!
There are, after all, many different conversion kits for many different cars...
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 10-07-2003, 12:02 AM   #40
speedxl's Avatar
sorry the computer doesnt display my sarcasim just making a dry humer point like saying hey guys we got company! i hope you understand futureal i m not trying to start a war. i guess i need a better choice of words!
Old 10-07-2003, 07:30 AM   #41
rayhuang's Avatar
Agreed-more is not always bad. The Barracuda and HPI's-fluorish because of the options available. Same deal with the TC3. This could actually be good for the Demon!!!
Ray
Old 10-07-2003, 08:42 AM   #42
lem2's Avatar
Default Actually
the IRS Side braces on a D1 looks really cool, not that it needs it, but more for the electronics protection.
lem2 is offline   Reply With Quote
Old 10-07-2003, 09:50 AM   #43
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
This had to hurt...........
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 10-07-2003, 09:56 AM   #44
lem2's Avatar
FRONT
REAR
what is the ride height front and rear?
I'm in th eprocess of setting up my d1. Thanks
Old 10-07-2003, 10:16 AM   #45
rayhuang's Avatar
as close to 4mm front and rear as possible. U I usualy set it at 4.5 mm for first run then dot check ride height again till the Mains.
Just to compenste for tire wear and droop settings etc. OH-on droop I can lift the car from ride height about 2.5mm front and rear. I vary that if the car feels lazy or too responsive front or rear.
Warpspeed Demon II FT TC3 R.Fenstermacher R/C Items: For Sale/Trade 21 10-29-2004 04:40 PM
WarpSpeed Demon Chasis for TC3 rc10gt R/C Items: For Sale/Trade 0 07-27-2004 03:21 PM
Warpspeed Demon TC3 R/C HEAT R/C Items: For Sale/Trade 3 05-11-2004 04:05 PM
warpspeed demon for trade burbs R/C Items: For Sale/Trade 0 04-19-2004 07:08 PM
warpspeed demon rcdave4 R/C Items: For Sale/Trade 7 04-14-2003 08:31 PM
