Old 10-20-2003, 06:00 PM   #226
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Ok i know i've done this before, but just want to find out again.
What Warpspeed Team drivers are attending the Cleveland Indoor Champs?
I know we got me, ray, and of course chris doseck going, who else?
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 10-20-2003, 07:24 PM   #227
What do you mean who beat me, Everyone b/c I just took my car off the track b/c I was upset.
stephen Baker is offline   Reply With Quote
Old 10-20-2003, 07:30 PM   #228
wheelmanST's Avatar
Send a message via AIM to wheelmanST
Default Setup for D2
Here is my setup I ran last Sunday, stock foam on a tight carpet track. I will try the one way again this weekend, as well as some other slight changes, but the setup is very close. Has a great balance of steering and traction, but my traction compound was gumming up (or at least thats what me and axiom concluded) making the car stick mid corner. Even with that (and me forgetting to add forward roll after I shortened the wheelbase) the car was tearing everyone up in the corners. I will also try the F block in place of the R block in the rear to get 1* of toe in. I think the car will be just flat out nasty with the one way All I have to say after the first race day ( more of a practice day...but it was the last day for asphalt racing so its carpet from now on!) is I couldn't ask for a better car or company to run for. Victor makes excellent products and it really shows on the track. Ok, enough talking, heres the good stuff .....
FRONT:
Yellow springs
60wt with #3 pistons
Front tower - outer hole
Arm - inner hole
F-0 block
Camber link inner upper
Losi hubs with AE 4* carriers
BRP .078 swaybar
1* camber
1.5* toe out
NTC3 steering rack
Diff set extremely tight, maybe 1/4 turn from lock
Ride - 4.5mm
Droop - 1mm
Tires - Jaco Plaid 28mm trued at 60mm - inner half sauced
REAR:
Purple springs
50wt with #3 pistons
Middle hole on tower
Outer hole on arm
R-2-0 block
Camber link upper inner
Losi 0* hubs
Camber link on the outer hole on Losi hub
Hubs all the way forward (short wheelbase)
.063 swaybar
1.5* camber
Diff set just slightly looser than front
Ride - 4.5mm
Droop - 2mm
Tires - Jaco Purple 28mm trued at 60mm - full sauce
Monster stock geared at a 25/100 (64p)
Gp 3300 cells
Hitec 5925mg servo
Novak gt-7 and XXL with an M8
Transponder mounted in the front bumper.
Protoform Alfa 2.0 - wing mounted forward
Most of the credit for this setup should go to Axiom...basically his with some of my changes. He gave me his setup to start with and I really only changed a few things. Trust me this setup is fast Let me know if I left anything out.
wheelmanST is offline   Reply With Quote
Old 10-20-2003, 08:32 PM   #229
Thank you for the kind words Seth. Only difference on mine is the front diff is set to normal tightness (not tight, not loose, in the middle), about the same as the rear. I also had 1 mm droop all around and ran a Losi Alfa.
25/100 Seth??? Man that is a small track . You sure you're not undergeared? I was running a 32-33 tooth pinion, same spur with those size tires, and my more local track is 70x40...
I went back to a .063 bar in the front and no bar in the back, it feels more consistent that way, and if it lost any corner speed, I sure can't tell on the track or by lap times.
USVTA Member #211
Old 10-20-2003, 08:46 PM   #230
wheelmanST's Avatar
undergeared...hmm
My track is around 80x40 if I remember right....maybe I should try a larger pinion. I was getting killed in the straight but I just thought that was my motor...need new motors and batts. Motor came off the track around 130...actually I could be too small on pinion, that will get the motor just as hot as having it overgeared. Ill try something in the thirty range this sunday. Thing that didnt make sense was I didnt really have much punch out of the corners...
Old 10-20-2003, 09:15 PM   #231
If you gear higher you'll have more punch and more top end. Motor's max torque is at 0 rpm. Only 130 degrees? For stock foam that is cool, 160-170 is where you wanna be approx. Mine are about that with a fan on the car (helps a TON). I would say go w/ a 33 tooth pinion to start. Remember...gear for 5 minutes, not the whole pack. Gearing higher like that will get more into the meat of that motor's powerband...it likes to be geared.
USVTA Member #211
Old 10-21-2003, 06:29 AM   #232
wheelmanST's Avatar
Ok, ill try a 33. Gear for 5 min eh? So you want me to dump 1 min before the race is over? We are running 6 min...ran that for stock rubber, maybe we will change to 5 for foam. Ive seen pics of your fan...maybe ill see what I can come up with. How do you power the fan?
Old 10-21-2003, 09:25 PM   #233
RBLove's Avatar
Trader Rating: 72 (100%+)
This is a big weekend coming up for Warpspeed Racing. Chris Doseck will make his debut with the car and Ray Huang will be running his as well. Not sure if there will be any others..... Chris has spent a lot of time on his car machining things more, etc... I will try to get a pic out here for you guys when he is complete. Will be done tomorrow evening.
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 10-22-2003, 10:02 AM   #234
rayhuang's Avatar
Default Dosecks car
Heres just a couple pics of his car so far. Its almost done.
Hes says its the baddest TC he's ever built!!
Ray
Old 10-22-2003, 10:03 AM   #235
rayhuang's Avatar
Another quick pic. notice his sweet milled screws he has!! Awesome-eh??
Old 10-22-2003, 10:24 AM   #236
CypressMidWest's Avatar
Dosie's a pimp. That car looks fantastic, and you can rest assured that he'll be VERY VERY FAST with it.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 10-22-2003, 10:25 AM   #237
Doug D's Avatar
Trader Rating: 54 (100%+)
Ray,
What kind of drive shaft is Chris running?
Also, if you could be so kind to get his set-up, I'm sure all would appreciate it!!!!
Thanks!!!!
Doug D is offline   Reply With Quote
Old 10-22-2003, 10:30 AM   #238
rayhuang's Avatar
Doug D
The drivehshaft is probably the standard kit one-But Dosies a milling maniac!!! If you look closely you'll see he has even milled the threaded shocks parts and deeper countersunk all the screws!!
I will try to get his set-up-but to be honest-I/we am so busy right now getting ready for the Halloween Classic-it might not be till weekend is over!!
210+ entries, non stop from Thursday night (Club race) till Sunday!!
Ray
Old 10-22-2003, 11:18 AM   #239
Doug D's Avatar
Ray, Who makes the standard drive shaft "IRS"?
Man I wish I could attend the race, good luck!
Thanks!
Old 10-22-2003, 12:58 PM   #240
Trader Rating: 37 (100%+)
Default d or d2
which car will Chris Doseck run....
is that the Demon or Demon 2 in the pic?
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Warpspeed Demon II FT TC3 R.Fenstermacher R/C Items: For Sale/Trade 21 10-29-2004 04:40 PM
WarpSpeed Demon Chasis for TC3 rc10gt R/C Items: For Sale/Trade 0 07-27-2004 03:21 PM
Warpspeed Demon TC3 R/C HEAT R/C Items: For Sale/Trade 3 05-11-2004 04:05 PM
warpspeed demon for trade burbs R/C Items: For Sale/Trade 0 04-19-2004 07:08 PM
warpspeed demon rcdave4 R/C Items: For Sale/Trade 7 04-14-2003 08:31 PM
