Old 04-07-2004, 07:25 PM   #1921
Default Re: Re: Re: Re: Re: Re: D2 ROCKS!!
Originally posted by howard hudson
yup I know they arnt running cuz of that egg laying rabbit but no worries mate Gives you another week to get ready I AM READY
Oh....I'm ready...La Mirada just isn't having a race this weekend.
DOTMAN is offline   Reply With Quote
Old 04-07-2004, 07:32 PM   #1922
howard hudson's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: Re: Re: Re: Re: D2 ROCKS!!
sweeeettttttttttt!!! gona have me some fun
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 04-07-2004, 07:34 PM   #1923
It's sounds like Charlie is pushing the race back one week so it's on next Sunday.
Old 04-07-2004, 07:59 PM   #1924
Old 04-07-2004, 09:24 PM   #1925
Send a message via AIM to R/C Anonymous
second racing night on the D1 with Foams....i went to the other local track in the city and won by 6 laps....very nice chassis indeed
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 04-08-2004, 10:46 AM   #1926
Trader Rating: 15 (100%+)
Default asphalt setups
IF ANY ONE HAS ANY SUGGESTIONS THEY COULD EMAIL ON SETUPS FOR THE D1 ON LOW BITE ASPHALT IT WOULD BE HELPFUL... I HAVE BEEN RUNNING ...
FRONT
BLUE SPRINGS
40 WT 2 HOLE PISTONS
OUTER HOLE ON ARM AND 1 IN ON SHOCK TOWER
O KICKUP 4 DEGREES CASTER.. UPPER INNER HOLE ON CAMBER LINK ALLTHE WAY AROUND WITH A ONE WAY...
REAR
SILVER SPRINGS
35WT 2 HOLE PISTONS
OUTER HOLE ON BOTH ARM AND SHOCK TOWER
LOSI 0 DEG REAR BLOCKS
AND 1 DEG. CAMBER ALL THE WAY AROUND
CAR IS A LITTLE LOOSE
AARON YOUNG is offline   Reply With Quote
Old 04-08-2004, 12:04 PM   #1927
Your setup is similar to mine however I don't use the Losi rear hubs. I found it made my car a little loose. You may also want to try a spool or locked diff. I just ran my car this weekend on a low bite track (kinda dusty) and it handled very well.
Old 04-08-2004, 07:32 PM   #1928
Default WARPSPEED RACING
R/C:
CONGRATULATIONS! Six laps.......EXCELLENT.
Mr Warpspeed is offline   Reply With Quote
Old 04-09-2004, 08:48 AM   #1929
speedxl's Avatar
Aaron I drive for mr warpspeed! and your set up is similar to mine. I dont know if you are using a diff or oneway! but I also dont know if your car is loose comming in to the corner, in the middle, or the exit .
i do suggest gong back to associated rear to blocks and start with the r-3-2, and if not enough try the r-3-3 blocks. if your are
running a oneway ditch the one way and run a diff up front tighter then the rear if not locked or a spool it make for a more stable car. good luck!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 04-09-2004, 08:50 AM   #1930
Send a message via AIM to True R/C Racing
YO Hector can you email me Your TQ Hobbies Setup? it would be Nice. It will be my 2nd time running asphalt
True R/C Racing is offline   Reply With Quote
Old 04-09-2004, 08:51 AM   #1931
Ariel, are you racing at TQ tonight?
TC3er is offline   Reply With Quote
Old 04-09-2004, 08:52 AM   #1932
At this point No, I have no FREAKIN! RIDE. Been 2 months no racing because cant get a ride no where. THIS SUCKS! I will Try my hardest get myself over there. BUt i need a Setup for TQ Hobbies.
Old 04-09-2004, 08:56 AM   #1933
Cool
Here is mine, I am using a stock chassis, but it is a good starting point.
Front
Shocks in middle hole on tower(using rear tower), outer on the arm
Gold Springs
30 wt oil
-2 camber, 0degree toe
5mm ride height, 6 droop
Rear
Shock set-up is same, except use silver springs
-2 camber
5mm ride height, 4 droop
Also I am running a locked diff in the front
Hope this helps you out.
Old 04-09-2004, 09:02 AM   #1934
ummmm, Camber link, shimming?, Toe-in, Mount on Rear Hub, What hub you using AE or Losi? Etc Etc
Old 04-09-2004, 09:29 AM   #1935
Whoops ,forgot about that, the camber link is the inner bottome one on the tower, stock AE hubs all around, one the rear hubs the outer hole, not shims, 3-degree toe-in in the rear.
Warpspeed Demon II FT TC3 R.Fenstermacher R/C Items: For Sale/Trade 21 10-29-2004 04:40 PM
WarpSpeed Demon Chasis for TC3 rc10gt R/C Items: For Sale/Trade 0 07-27-2004 03:21 PM
Warpspeed Demon TC3 R/C HEAT R/C Items: For Sale/Trade 3 05-11-2004 04:05 PM
warpspeed demon for trade burbs R/C Items: For Sale/Trade 0 04-19-2004 07:08 PM
warpspeed demon rcdave4 R/C Items: For Sale/Trade 7 04-14-2003 08:31 PM
