Old 11-14-2008, 02:11 PM   #1
Low_E's Avatar
Send a message via MSN to Low_E
Default brushless brands
I drive a 416, mostly in stock competition.
I used to drive brushed motors but switched my EC to a nice Tekin R1 Pro and want to drive brushless now.
I allready have an Orion 17.5 BL motor which runs very nice (aldough I noticed a slower topspeed when driving against my mate who runned a 416 as well, with a LRP 17.5)
I'm thinking about buying a 10.5 and a 13.5 brushless motor.
As I said higher, I really like my actual Orion 17.5 ... Nice black coloured, runs without heating...
but what brand should I buy: Orion, LRP, ... when deciding to buy a 13.5 and/or a 10.5 BL motor. I know LRP is decent quality, but so is the price
Are there some brand-related pros and cons?
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 11-14-2008, 02:24 PM   #2
Adam?'s Avatar
I've been extremely pleased with my Trinity DUO 13.5. I'm not the biggest fan of Trinity, but I can't deny the motor has been outstanding. Supposedly, they have a new "Pulse" motor coming out in a couple of weeks. I definitely plan to give that one a go.
I've never been terribly impressed with the LRP motors. Maybe the new X12's will be better.
The Orion motors look great, but my 10.5 was quite a bit slower than other brands. Not sure if the 13.5 is the same way. Ran the 17.5 in Vegas, and it was very nice, but it's the same motor everybody ran, so I'm not sure how it compares to the other brands.
Adam? is offline   Reply With Quote
Old 11-14-2008, 02:37 PM   #3
jmcvicker's Avatar
Did you gear-up with the 17.5 when you put it in? It should have a FDR of about 4.2-5.0 depending on track, etc. That would be roughly a pinion of 37 spur of 69 if your internal ratio is 2.5. Otherwise, top-speed will be lower than others who are still brushed or 17.5 with the higher gear.
jmcvicker is offline   Reply With Quote
Old 11-14-2008, 02:49 PM   #4
Foxxrocket's Avatar
Yeah, you have to gear way up to get that top speed. I'm running at 4.1 FDR with a 64p 80 spur, 48 pinion at about 165F. And I keep right up there with everyone else.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 11-14-2008, 02:53 PM   #5
Low_E's Avatar
well I was running the same car, same ratio. Only differences were the setup and the motor.
Now I know a setup can do a lot of things but not really on topspeed on a long straight AFIAK, not since Toe and camber were the same.
Old 11-14-2008, 03:06 PM   #6
Different motors respond differently to gear ratio. Even though both motors are 17.5 motors they are likely to need different gearing to get similar performance.
Carcar Ophidian Canadian R/C Scene 12812 Today 11:29 AM
RC10B4/T4 Forum DerekL Electric Off-Road 14339 12-13-2017 11:20 PM
Caslte Creation Mamba Max VS Novak GTB system MannEdge Electric Off-Road 324 06-20-2010 10:07 PM
Anderson 1/18 Buggy fatboy Micro and Mini Scales 17 12-14-2008 03:42 PM
17.5 Question - Performance across brands? Syber Serulean Electric On-Road 34 09-29-2008 12:39 PM
