Old 11-11-2008, 03:34 PM   #1
Default 7 Cell Xcelorin?
Anyone know how many cells a Losi Sensored Xcelorin ESC can take?
Tamiya TL01
Tamiya TA05 (ish)
Associated B4 3.5r
Limerick91 is offline   Reply With Quote
Old 11-11-2008, 06:03 PM   #2
RCGaryK's Avatar
Straight from Losi:
Battery –Select NiMH, or Lithium-Ion / Lithium Polymer batteries
Cutoff Voltage – This is a critical option to understand and used to protect Lithium or M1 batteries from being over-discharged, which will shorten the life, cause damage to the battery, or even result in Fire or Personal Injury.
When using NiMH batteries you do not need to set a cut of voltage to protect the batteries. NiMH batteries typically stop operating your vehicle before any damage occurs. If you are using more than 6-cell NiMH batteries, you must adjust the cut of voltage, for example if you are using an 8-cell pack of NiMH batteries you would use a cutoff of 5.6V volts (8 x 0.7V = 5.6V). If you are using fewer cells of NiMH batteries, a cutoff voltage of 4.0V will provide power for your radio system to operate and reduce the chance of losing control.
v No Cutoff The choice for racing used along with quality NiMH battery packs.
v Customize Voltage Cutoff (for NiMH Batteries) you can select a starting cutoff voltage of 4, 5, 6, 9 or 12 volts. Then using the up/down to the right of the voltage you can increase the voltage stepping up 0.1V between the selectable settings. Following the above example for an 8-cell NiMH battery, you would select 5.0V and then increase 6 steps up to 5.6V.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 11-12-2008, 10:04 AM   #3
Cool, explains it
Thanks a lot!
Tamiya TL01
Tamiya TA05 (ish)
Associated B4 3.5r
Losi 1/8 8ight E 4wd Thread tyhodge07 Electric Off-Road 8898 11-17-2015 06:31 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
New to 1/8th scale electric!!!! For newbies Jerseyboy Electric Off-Road 16 05-29-2009 01:09 AM
LiPos opinions nerdling Australian Racing 30 04-01-2009 12:33 AM
2008 ORRCA Qld 1:10 EP Off-Road State Titles 2blackdogs Australian Racing 363 08-24-2008 06:38 PM
12cell/14.4 volt nimh xcelorin? matthewh Micro and Mini Scales 8 05-07-2008 02:25 PM
