Lipo "C" difference >
Lipo "C" difference
Lipo "C" difference
Old 04-21-2011, 06:33 PM
  #31
The key to choosing a Lipo battery pack is getting one that has the highest C rating and capacity you can afford. Not only will the car be faster, but the battery will be under less stress with a really good pack meaning it will last a long time.
Also I recommend not choosing the really light Lipos that look a little like the old stick packs we used to use as these are really light weight making balancing of the car a problem and also are not as powerful probably due to how they have been made to be the same size as the old stick packs.
For me the IP5600 50C and IP6200 60C are awesome for any application.
Mike
ixlr8nz is offline
Old 04-22-2011, 04:14 AM
  #32
kcunamay's Avatar
Trader Rating: 20 (100%+)
Mike
I've experienced the same thing.
I have done back to back testing with a T3'11 running boosted 17.5 equipped with a 3400 25c orion pack and then my thunder power 50/100c 5200mah pack. With the 3400 25c, the car was much slower everywhere on the track and after a 5 min heat motor temps were above 180. During the next qualifier, I swapped in my TP 5200 50/100c and not only was the car MUCH FASTER, motor temps were much lower as well. In the 140 range.
The only swap was the battery and there was 0 binding on the car.
kcunamay is offline
Old 04-22-2011, 05:15 AM
  #33
Skiddins's Avatar
It doesn't explain that there is no standard for measuring the 'c' rating so you can't compare between manufactures.
The reason we want all the numbers as high as possible is so that we finish a run with as higher voltage as possible.
In theory, it would be ideal if the voltage at the end of a run was exactly the same as at the beginniing.
Skiddins is offline
