Old 11-10-2008, 10:05 PM   #1
CMB21's Avatar
Default Which car for 540 Pro class?
I am running in a 540 Pro class, currently with a ta05 and i thought it was time to upgrade. I considered buying hop up parts for the ta05, like alloy and carbon fibre parts, but i decided it would be throwing money away.
On a tight budget and i was looking at the following cars (both are 2nd hand and in very good cond) I will give you prices in both Australian and US dollars, but exchange rate is terrible for us atm. These are both rollers and i already have all electrics.
Schumacher Mi2ec - (AU$150 or US$100 roughly) Comes with the following spares: Tyres, wheels, c-hubs, hubs, driveshafts, shaft blades, belts, pivot balls, springs, swaybars, body posts, carbon fibre set up shims.
TAMIYA TRF415 MRE - (AU$300 or US$200 roughly) Comes with 19 turn Komodo motor by Brood, some spare belts and some different sway bars.
Which would be the better car and value for money????? Or is there anything else that would be around the US$200 mark as i dont want to spend much over that. This is just for racing at my local club so there to have fun but i still want to win
Thanks for the help!
CMB21 is offline   Reply With Quote
Old 11-10-2008, 10:10 PM   #2
Send a message via AIM to dennyboy424
I have both cars... The tamiya is better overall car
dennyboy424 is offline   Reply With Quote
Old 11-11-2008, 01:01 AM   #3
Drifting101's Avatar
YGPM
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 11-11-2008, 04:12 AM   #4
mac853's Avatar
Between these 2, i think MRE is better. As i know, not only in Brazil, also in our zone which 415 is competitive in silver can races.
But i hope you could find more choice, how about if you could find some shaft drive cars, which has more advantage, ex:TBEVO5 or MS.
mac853 is offline   Reply With Quote
Old 11-11-2008, 04:18 AM   #5
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Get the one who has better support (in parts and setup) in your area
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 11-11-2008, 05:53 AM   #6
tc3team's Avatar
Having used my trf415msxx for the first time on sunday I think you know what my answer is going to be
I had no problems with the car all day, it performed flawlessly.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 11-11-2008, 11:06 AM   #7
reenmachine's Avatar
Trader Rating: 26 (100%+)
I was in almost the exact same situation a month ago. I bought a used Mi2EC and enough spares (from a couple different sellers) to more than build an entire spare car. I've got about $160 in all of it and the car is an amazing performance upgrade from the TA05. I'm running 13.5 though, so the differences may be more obvious.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 11-11-2008, 12:10 PM   #8
MarkBrown's Avatar
What are the rules for the 540 pro class? What surface are your races run on?
If the class has a reasonably high minimum weight, and the motors aren't too powerful, and the traction is not too high, then you won't necessarily get a significant performance gain from abandoning the TA05. This assumes you are comfortable exploring setup changes on the TA05 to make it work better for you.
Moving to a new car does give you a new place to start from in exploring setups, and that might help you find something.
MarkBrown is offline   Reply With Quote
Old 11-11-2008, 02:53 PM   #9
tomt2's Avatar
TT-01, thats all you'll ever need for 540. That or a shoebox with wheels, depends what parts you can get easier.
tomt2 is offline   Reply With Quote
Old 11-11-2008, 03:21 PM   #10
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
TB03. shaft drive. more efficient and no worries bout tq steer with the low power motor
R
UltegraSTI is offline   Reply With Quote
Old 11-11-2008, 03:52 PM   #11
raffaelli's Avatar
+11tybillion
24ITA
raffaelli is offline   Reply With Quote
Old 11-11-2008, 04:09 PM   #12
CMB21's Avatar
relatively new to the whole onroad thing, so setup wise i really dont know much. And i dont have a setup board either. 540 rules, well its a VORTEC class, rules are about as simple as silver 540 can motor and rubber tyres. And we run on some netball courts so asphalt and its not the smoothest surface in the world. And it would be good to have a decent car if i decided to move outside of 540 class.
Old 11-11-2008, 05:51 PM   #13
MarkBrown's Avatar
Originally Posted by CMB21 View Post
... 540 rules, well its a VORTEC class, rules are about as simple as silver 540 can motor and rubber tyres. ...
Sounds like there is no minimum weight for the class. If so, the lighter cars you are considering will have a performance advantage over the TA-05. The main thing is, be sure to have fun with whatever you get.
Old 11-11-2008, 07:43 PM   #14
CMB21's Avatar
Sorry there is a minimum weight, but the ta05 is over that straight away. One of the guys has 415 at my track and with a lipo in the car he has to add weights to get the minimum limit, which means you cna get the weight where you want it.
Old 11-11-2008, 08:13 PM   #15
mild seven's Avatar
Trader Rating: 63 (100%+)
Send a message via MSN to mild seven
For those that dont know, 540 Pro is pretty much any chassis and unrestricted gearing and must use a mabuchi/johnson 540 silver can motor. Weight limit of 1500 grams w/o transponder.
Im happy with my 415. very easy car to setup. Ive never had a car this good before. And parts are pretty easy to get which is good. The hot bodies cyclone S would be another good car to look at. That would be just as competitive as the others up to the 19t class i believe.
Cheers
Tom
mild seven is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
KNOX Offroad Vic The Fuhrer Australian Racing 15670 08-29-2017 05:20 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 09:15 AM
Bending Corners Raceways, Carpet, Asphalt, We got it! TireShredder California Racing 7617 10-07-2013 11:37 PM
Castlemaine trophy dash nitro + electric RACER12 Australian Racing 1421 11-08-2007 03:51 AM
general 540 class chat djrfan Australian Racing 90 04-21-2005 04:56 AM
Chargers RC - Yeronga Onroad Havago Racing Australian Racing 2133 02-27-2005 01:09 AM
