Old 11-10-2008, 05:50 PM   #16
poochy's Avatar
threadlock did it!
poochy is offline   Reply With Quote
Old 11-25-2008, 05:44 PM   #17
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
Originally Posted by RCSteve93 View Post
Put O-Rings under the ball cups.
WHAT KIND OF O-RING AND WHAT SIZE?
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 11-25-2008, 05:53 PM   #18
Trader Rating: 20 (100%+)
is there a better ballcup that will reduce the slop?
Try cutting a very thin piece of fuel line (RC Fuel Line) and put it under the ball cups, I've tried the O-Ring method but its too thick and the steering won't center properly, with the fuel line you can atleast cut to the thickness that you require.
Hope that helps.
bee200sx is offline   Reply With Quote
Old 11-25-2008, 06:43 PM   #19
RCSteve93's Avatar
THE SOFT TEFLON ONES THEY USE ON SHOCKS.
Internet Courtesy 101... Don't type in caps.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 11-25-2008, 07:54 PM   #20
poochy's Avatar
the majority of the slop is from the gap between the steering post and bearing that holds it upright, at least for me and 3 other tc5's ive seen in past 2 weeks. threadlock will cure most of the tc5 steering slop problems. its not easy to tell that the steering post and bearing is the source of the majority of the slop. the only way to tell is to just apply threadlock and compare the slop before and after. try it-should be a night and day type of result!
Old 05-18-2009, 09:22 AM   #21
6Venom's Avatar
Trader Rating: 44 (98%+)
Where should the threadlock be applied exactly? Thanks!
6Venom is offline   Reply With Quote
