Dying SMC battery >
Dying SMC battery
Dying SMC battery
Old 10-01-2003, 07:39 PM
Regional Moderator
disaster999's Avatar
Default Dying SMC battery
got a pack of matched smc battery for about...1.5 years old, at first it charged out fine 3-4 months ago, but recently, the cell seems to die on me! the peak volt of the pack was around 10 volts and only have about 2500mah in it!
anyway i could revive it? or its a goner?
disaster999 is offline
Old 10-01-2003, 08:14 PM
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Try discharging it as low as it will go, then dead short each cell individually. Should erase any memory that the pack has, and may work to revive it.
Randy Caster is offline
Old 10-01-2003, 08:27 PM
Regional Moderator
oops i forgot to mention that its 3000mah batt...not nicd!
Old 10-01-2003, 08:36 PM
Not sure in that case, that worked for me with NiCD batts, never tried it on a NiMH, but I guess it couldn't hurt the cell anymore than it already is.
Old 10-01-2003, 08:50 PM
boner's Avatar
what kind of 3000? GP or SANYO? your cells are old. just use what you brought over from your home.
boner is offline
Old 10-01-2003, 09:20 PM
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
i know dead shorting is commonly used for nicad but i had tried with a dying gp3300 with good result. I have a set of dying 3300 , peak around 10V and only about 2800 mah when fully charged. Just like Ranman suggested, discharge the pack and put them on a tray for a few days ( deadshorting the batt individually) , followed this method i was able to bring back my old 3300 to peak about 9.3+- and had about 3100-3200 in the batt..
Tag is offline
Old 10-01-2003, 09:54 PM
lee82gx's Avatar
Tag:
forgive the obvious ignorance but i wanted to be sure:
Were u suggesting the Nicad(dead shorting 0V) tray or 1.2V-cut off try?
how long did the revive last?
lee82gx is offline
Old 10-01-2003, 10:02 PM
I saved the money on a discharge tray, and just soldered a wire from the positive to negitive terminal on the battery
Old 10-01-2003, 10:17 PM
lee82gx's Avatar
Right,dead short it is.
i have to discharge the cells to 0.9V first right?
lee82gx is offline
Old 10-01-2003, 10:18 PM
Whatever the lowest voltage you can get is, discharge it to that, otherwise the cells will get real hot when dead shorting them, and may cause more damage than good.
Old 10-01-2003, 10:24 PM
lee82gx's Avatar
Ok.thanks.i think i'll parallel a coupla resistors and then discharge it that way
and then put on dead shorting wires.
thanks.
lee82gx is offline
Old 10-01-2003, 10:27 PM
Regional Moderator
ive always been told all my live that its a bad idea to dead short nimh batteries! you guys really sure that its a good idea to dead short nimh?
and just to make things clear here...the pack that is giving me problems is sanyo 3000 matched by smc
Old 10-01-2003, 10:28 PM
I've never done NiMH personally, but Tag seemed to have good results...
Old 10-01-2003, 10:32 PM
Regional Moderator
guess ill wait for more responds and more ppl to agree with Tag then
Old 10-01-2003, 10:35 PM
lee82gx's Avatar
i wouldnt do it to new cells,but for those dilapidated ones i wouldnt mind trying just for the heck of it.
doesnt really require a lot of money too.
another thing:
it might be a good idea to zap ur old sanyo's disaster999.
lee82gx is offline
