Old 11-08-2008, 10:39 PM   #1
Default Fresh car: foam or rubber?
Getting a new kit in the next week. I run both foam and rubber. Which do you think is more important to have a fresh car in?
JoelV is offline   Reply With Quote
Old 11-09-2008, 12:37 AM   #2
I would personally go for a foam spec car. The thing is that if you run foams a rubber tire car will have too much flex. The thing is that with a very weak Anti roll bar a foam car can run rubber tires fine. I have found that the opposite is not true and rubber tire cars are not stiff enough to run foams, even with stiff anti roll bars and hard springs.
Corinator
Corinator is offline   Reply With Quote
Old 11-09-2008, 10:55 AM   #3
Not sure you understood my question. I'm getting another losi jrxs-r (no foam/rubber spec) and my question was which is more important to have a fresh car.
Old 11-09-2008, 10:58 AM   #4
SammyZ's Avatar
Trader Rating: 138 (100%+)
SammyZ is offline   Reply With Quote
Old 11-09-2008, 11:14 AM   #5
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Foam-
things need to be "nib" fresh in order to have a great handling car.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 11-09-2008, 01:49 PM   #6
mr fit's Avatar
the losi JRXS type-R does not have a rubber or foam spec chassis.there is only 1 chassis. the car works great either way with a stock setup.just change minor things, such as springs, shock oil weight etc.
marc davila aka... marc ups.... drive it like you stole it.
mr fit is offline   Reply With Quote
Old 11-09-2008, 05:41 PM   #7
RCSteve93's Avatar
I say what ever better results means more in. If rubber is the big class, rubber. If foam is the big class, foam.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 11-09-2008, 06:08 PM   #8
Trips's Avatar
Trader Rating: 16 (100%+)
I'd think the new chassis would best serve you in the foam class, with the higher speeds and extra grip available, I'd think the benefit of the fresher car would be most apparent in foam racing.
MARSHAL!!
Trips is offline   Reply With Quote
Old 11-09-2008, 06:49 PM   #9
Thanks a main, steve and trips.
Tamiya Championship Series Neil Rabara Racing Forum 21258 Yesterday 07:49 PM
Will rubber carpet overtake Foam carpet in the future??? dawgmeat Electric On-Road 166 09-21-2007 11:59 PM
Reedy Race of Champions EAMotorsports Electric On-Road 901 07-08-2007 10:13 AM
Why cant foams be run on asphalt with electric? bxpitbull Electric On-Road 116 01-03-2007 06:01 AM
Rubber Tire touring car racing... Nexus Electric On-Road 183 06-18-2006 08:41 PM
Foam Vs Rubber fastolfart Australian Racing 66 07-09-2003 04:04 PM
