Old 11-08-2008, 07:25 AM   #1
jono mad racer's Avatar
Send a message via MSN to jono mad racer
Default 12th Scale Pan Car
Hey,
I wanna get into the world of 12th scale and EP. I have raced EP Buggies in the pasted but i went back to my true love 1.8th buggy nitro.
I just want to know what size motor do you need for a starter?
Also is there a special motor or can you one that will fit a 1/10th scale?
Thanks for your help!
Jono
Volkswagen Australia
jono mad racer is offline   Reply With Quote
Old 11-08-2008, 07:27 AM   #2
FOXY923's Avatar
Same motor's as 1/10.
Paris Junction Hobbies ~ RROL.ca ~ Lou's Speedway ~ SCAR
XRAY X10 Link ~ CVTA Sakura Zero S ~ XRAY X10 Custom Oval ~ Caster Fusion F18
RACE 4FUN
FOXY923 is offline   Reply With Quote
Old 11-08-2008, 07:42 AM   #3
Ok thanks a lot.... What about ESC and Servo??
Sorry for the newbie questions
Old 11-08-2008, 07:51 AM   #4
FOXY923's Avatar
esc is the same but servo's are smaller. There are a few brands you can chose from but I don't know the part numbers.
RACE 4FUN
Old 11-08-2008, 07:56 AM   #5
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
For speed control I'd choose the Tekin products. Tekin speed controls have some of the smallest footprints, very important in 1/12 scale. I've run the FX Pro when running brushed, and now I run brushless so I have the RS Pro in my 1/12 scale. As for servo, I currently run a Futaba 9602 servo. It's reliable and durable. I'm going to switch to a digital servo, so the Futaba 9650 is going to be my next servo purchase. The best advice I can give you is don't nickle and dime yourself into a corner. I've seen too many racers buy some really cheap equipment to "just get started" only to be disappointed in the performance of the product. One of two things happens next; they upgrade to the better product they should have bought costing more money in the long run, or they get discouraged and sell the car. Hope this helps.
SpraydbySprague is offline   Reply With Quote
Old 11-08-2008, 08:17 AM   #6
Thanks a lot for that... Helped me a lot!
I have been in RC for 5 years now i and remember when i started my buggy racing i did what you said don't do... Got a crappy car and stuff and now 5 years later racing one of the best buggy's around and motor etc. Waste of money at the start, but hey learn from your mistakes.
I was looking at a D12 or Yokomo... But i wouldn't mind seeing how much the new Xray will cost. I love xray products.
Thanks again!
Jono
Old 11-08-2008, 10:38 AM   #7
cyclone speed's Avatar
Hi , i also would like to get into 12th but i have a TC EP car ( HB cyclone )
And are the servo the same size , can i put my TC servo in my 12th car .
Wich car would be god to get.
Also , are the rollout the same on evry car , im going to run a lrp 5.5 , what rollout should i use , wich pinion with wich gear .
What can you adjust on 12 th , toe camber caster roll center , sorry for all these question but im new to 12th .
Thanks in advance
cyclone speed is offline   Reply With Quote
Old 11-08-2008, 11:24 AM   #8
bs6ef's Avatar
Thanks in advance
A TC Servo is just to big to fit in a 12th so you need a Futaba 9650 or KO 949, roll out on a LRP 5.5t depends on which armature your using.
5.5t Bonded 31 - 32mm per rev
Sintered 12 - 12.5 - 13mm vary i'm running a 12.5 at 37.6mmpr on a full sized national track.
hope this helps
You have to watch the TechnoViking http://www.youtube.com/watch?v=_1nzEFMjkI4
bs6ef is offline   Reply With Quote
Old 11-08-2008, 11:27 AM   #9
bs6ef's Avatar
Thanks again!
Jono
there is no crappy 12th car, they are all capable of winning an A final in the right hands. "12th scale is all about setup and ability and not about equipment"
BMI DB12R probably the easiest car to setup and race.....
Old 11-08-2008, 12:42 PM   #10
So , it means that i have to get a new servo ?
Will a GTB with heatsink and fan fit in any 12th car?
Could you tell me everything you can adjust on a 12th car , like in TC you can adjust ride height or toe or camber or caster or roll center or ....
is it possible to do all this in 12th scale ?
Old 11-08-2008, 01:40 PM   #11
EricF's Avatar
Yes, you'll need an new mini servo not a standard size servo. The GTB w/ fan, etc. will not fit because the heatsink/fan is too tall to fit under the body. So you'll need a new esc aswell or you could remove the hs/fan (at your own risk), better to buy a new esc. Yes you can adjust all of those things on a 1/12.
E
EricF is offline   Reply With Quote
Old 11-08-2008, 01:52 PM   #12
E
I dont understand why you said " at your own risk to take off the h/s " ?
is droop adjustable ?
How can i adjust roll center in front and rear ?
or how can i change ride height ?
Old 11-08-2008, 02:02 PM   #13
EricF's Avatar
the hs/fan can be removed but you'll need to put an alum plate back for the heatsink. some people have done it but it's not my cup of tea.
droop is adjusted by the length of the rear shock for pod droop and in the front it's adjusted by adding or removing shims from the top of the kingpin. ride height is changed by adding spacers under the front suspension arm and in the rear it's done by changing the cham(sp) blocks that place the axle lower or higher relative to the surface.
E
Old 11-08-2008, 02:08 PM   #14
E
But, whats the kingpin ?
If i ad spacers under the front spacer, will it change roll center ?
Is roll center adjustable in the rear or front ?
Whats the champ , do you have any pics?
Sorry for all these stupid question .
Old 11-08-2008, 02:57 PM   #15
Kingpin is the pin that goes through the suspension pivots and the steering block.
Some cars have an adjustable roll center in the front. The Speed Merchant front end can adjust the roll center by raising or lowering the upper suspension links. Most don't have that adjustment though. I guess doing a long upper arm conversion would change the roll center in the front as the relative angle of the upper arm to lower would change. At the rear you can change the roll center by changing the height of the pivot points.
1/12 forum ovalnator Electric On-Road 46170 Today 06:29 AM
E-Team Hobbyplex and Raceway revolution31 Colorado Racing 1537 02-11-2017 10:59 AM
1/10th pan car Taz_S Oval, Larger Scales and More 16138 09-25-2014 10:03 AM
Items for sale or trade Fastburn R/C Items: For Sale/Trade 9 01-16-2007 01:23 AM
Tracks around NYC or Westchester rcburner Track Locator Forum 91 03-10-2004 11:55 AM
