Hudy Wheel Adapter #102342
Am running World GT with Jaco and spec tires.
Have a Hudy lathe with an Integy 1/12th 1/10th combination wheel adaptor that does not work very well with the 1/10th rear wheels.
Is the Hudy Wheel Adapter 1/10th - Associated #102342 the correct adapter to get for truing fronts and rears on my Gen-X 10 pan car?
Thanks.
Thanks.
I think he was thinking of this one...
http://rc4less.com/Tire_Truers_&_Arb...duct_info.html
It's the one I was looking at getting...
Arbor part# HUD 102374. Maybe what you want. It fits all 12th scale except Corally. Try Hudy web and search, or try www.ashfordhobby.com
Regional Moderator
Thanks.
Thanks.
I have tried the one from RC For Less. It will get the job done but its not the best. In fact it is not exactly the right depth for some 1/10th rears. I got lucky and ran across one of the Hudy's. It works perfectly.
The 102374 adapter is 1/12th scale only. I'm 1/10th pan car.
Thanks.
Yes thats the one you want. They are hard to find though as they have been discontinued.
just finished Checking Ashfordhobby.com. He has in stock if you still want Hudy Products.
Good luck!
Good luck!
One more chance for Hudy Arbor. Arbor HUD 102374, 10th /12th scale.
Stormerhobbies.com, One in stock.
Where is Castro Valley located in Ca? Just moved out of SoCal.
bill,
the integy arbor has a removable cone? take the cone and invert it. it will sit in the rear tire and center it on the arbor.
