Old 11-07-2008, 05:06 PM   #1
Juanchoyo's Avatar
Default Yeah Racing Lipo .... 0.5C charge rate??
Hi guys, i was reading at rcmart adn found this about their 3200 Lipo batts...
It says that for the first 8-10 charges, they should be charged at 0.5C...after that 1C normal charge...
Is this real??? Or should I just stick with the 1C charge rate.... as any other Lipo??
Thanks!!!
FoxRC Hobby Club
http://foxrc.foroactivo.net/
"Mas que un hobby, un estilo de vida. Algo que corre en los circuitos de mis venas"
.....ChOoJuAaAnNnn, Sebastian, Juancho... como quieran XD.... o Sebastian Oviedooo...
Juanchoyo is offline   Reply With Quote
Old 11-07-2008, 05:08 PM   #2
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Thanks!!!
This is very interesting indeed. I say go with what they say for performance as well as safety purposes.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 11-07-2008, 05:12 PM   #3
blee's Avatar
Exclamation
Thanks!!!
Interesting concept...... the battery need to be activated by low amp charging???..... never heard about that....
blee is offline   Reply With Quote
Old 11-07-2008, 05:30 PM   #4
RCSteve93's Avatar
Thanks!!!
They clearly know the LiPo so go with what they say. That is the problem with buying cheap LiPo's. The way I look at is that with LiPo you only need one or two, so you might as well buy something halfway decent because they last a few seasons. For another $10 you could have bought a Trinity. As much as I hate trinity, I would take them anyday over a Yeah Racing.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 11-07-2008, 05:54 PM   #5
Juanchoyo's Avatar
Well in fact, Im not the owner hehehe... it a friend of mine... but interestingto know about the Trinitys.... can u posta a link pls?
FoxRC Hobby Club
Old 11-07-2008, 06:17 PM   #6
RCSteve93's Avatar
http://rcmarket.com.hk/product_info....mt4mc9utk0upo2
rm -rf /windows
Old 11-07-2008, 06:24 PM   #7
crazy4wdracer's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to crazy4wdracer
From what i've heard the Trinity LiPO is no good. It has a built in cutoff which will cutoff under hard acceleration of a low turn brushless motor.
crazy4wdracer is offline   Reply With Quote
Old 11-07-2008, 06:25 PM   #8
Juanchoyo's Avatar
Thnks!!!!!!!
FoxRC Hobby Club
Old 11-07-2008, 06:36 PM   #9
ottoman's Avatar
R/C Tech Charter Subscriber
I think you heard wrong
Run both Trinity and SMC Lipo's and realy cant tell the difference between the two on the track.
I watched Pauly working on his mod setups running Trinity Lipos with out any problems.
ottoman is offline   Reply With Quote
Old 11-07-2008, 06:41 PM   #10
76nova1's Avatar
Trader Rating: 62 (98%+)
The problem with the Trinity with the built in cut off is true, it happens with mine if I run anything lower wind than 13.5.
Team Pit Racers-Fastest Guys In The Pits!
76nova1 is offline   Reply With Quote
Old 11-07-2008, 08:08 PM   #11
slakr's Avatar
Trader Rating: 31 (100%+)
This may or may not be the case for some...
Some drivers found that if the battery strap was too tight and applied too much pressure to the battery, the LiPo cutoff would activate. Guess excess pressure on the battery case somehow connects the cutoff circuit. I don't have a Trinity LiPo, but this was posted by a driver or two on the Carolinas RC forum quite awhile back. FWIW
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 11-07-2008, 08:32 PM   #12
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
Is this only with the Trinity 3200 packs? or does it apply to their other packs?
Reason i ask is because the 3800 is the Intellect pack and carries a differently formatted part number than the rest of Trinity's packs.
I have run the IP3800 with 3.5T and the ESC cutoff triggered 1/3 lap after the end of a 5 minute run on a rather large track. I know this to have been the voltage cutoff on the ESC and capacity wise I also used 3800+ mAh from the pack during the race.
Curious as to what other lipos have built-in protection circuitry and what exactly it does... like my LRP 5300 Comps I use, nice circuit board inside but what does it do, if anything?
mok is offline   Reply With Quote
Old 11-07-2008, 10:26 PM   #13
hanzo3's Avatar
Trader Rating: 55 (100%+)
I heard that lipos are made in 1 of 3 factories. Is this true?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 11-08-2008, 12:17 AM   #14
Born2Run's Avatar
Im running the Intellect-Trinity 3800mAh with low turn brushless but i never had a cutoff under hard acceleration.
Whatever
Born2Run is offline   Reply With Quote
Old 11-08-2008, 12:39 AM   #15
Drifting101's Avatar
The cut off is use less and the trinity has a high internal resistance
The battery that RCSTEVE posted is actally interlect and they are some of the best on the market
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
