Old 04-20-2012, 06:57 AM   #631
Getting an X12 17.5t for my TC6.1. What FDR should I run for 17.5 boosted? The track is fairly small 80x30. Also any suggestion for esc set up (using Tekin RS Pro)?
MySlowZ is offline   Reply With Quote
Old 04-20-2012, 07:54 AM   #632
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Default Max temps
Good day,
I was wondering what is the max temps and ideal temps for running a x12 13.5t in a Losi 22 with ssx stock spec. V2?
Thanks for your advice,
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 04-20-2012, 09:05 AM   #633
Buckaroo's Avatar
Originally Posted by BlackStarRacing View Post
Good day,
X12 instructions say max temp of 210F. They're not even close to smoking at that temp. Usually they come alive above 170.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 04-20-2012, 09:05 AM   #634
daleburr's Avatar
Good day,
Ideal temperature would be 0 Kelvin, as then the wire would have no resistance and the bearings would have no friction. Since that isn't possible, you just want it as cold as possible for maximum efficiency.
Unfortunately that's at conflict with getting maximum power, which makes the motor hot.
Keep it at 100degC or below (measured externally) and the X12 will be fine. I'd be suprised if you can get it that hot with a 2wd buggy anyway, so it's not likely to be a big issue.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 04-20-2012, 09:12 AM   #635
Thank you both for your timely manner in replying.... Want to be safe!
Old 04-22-2012, 05:45 PM   #636
So I ran my 17.5 yesterday. Ran real strong and barely got warm after each packs (40 mins rest between each pack). Don't know what happened..., but while driving 3 mins in, the car felt strange, almost as if there was no brakes. So I kept going for maybe another 2 mins, before finally decided to pull the car in. That's when I noticed the motor was extremely hot!!! Tested it again today, motor seems to run fine but braking feels weak. Anyone know what I may possibly screwed up and might have to replace to fix this problem?
Old 04-22-2012, 06:05 PM   #637
Also I notice a humming squeaking noise when braking hard, is this normal?
Old 04-22-2012, 10:42 PM   #638
Pro10noob's Avatar
Check bearings and if the rotor is shimmed ok(to little play).
This happends even with new motors(bad shimming)
The LRP X12 motors need there bearings lubed rather often
Weak brakes on a X12 point to a rotor being to hot.
You also loose power in the lower rpm range.
If this is the case, you have to replace the rotor to get brakes and power back.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 04-23-2012, 01:58 AM   #639
daleburr's Avatar
It's possible that the magnet has come loose from the rotor shaft (not totally loose as you'd have no drive; but not 100% attached). You'd normally notice this under acceleration, but maybe in 17.5 blinky the braking force is higher than the acceleration force.
This does sometimes happen on the X12, my 10.5 did it last year and I know of others it's happened to. You can superglue the magnet to the shaft, or just buy a new rotor.
Team Xray
Old 04-23-2012, 06:57 AM   #640
Thanks for the reply guys. I'll try replacing the rotor this weekend and hopefully this solves the problem. Is there an upgraded rotor for 17.5t (like a rotor for more rpm or torque)?
Old 04-23-2012, 07:43 AM   #641
Buckaroo's Avatar
I've alway known the 12.0mm rotor as being the RPM rotor, the 12.5mm as a slight torque boost over the stock, and the 13.0mm rotor as the torque rotor.
The green/gray 1S rotor is 12.25mm
Tom Keith
Old 06-16-2012, 02:10 AM   #642
brent701's Avatar
Trader Rating: 8 (90%+)
Sorry to bring this thread back up but I got a few problems with a LRP Vector X-12 motor 13.5
What is the average operating temps for these things?
I can not get the damn temp under 180.
I have gone from a 30/69 gearing to 26/72 gearing.
It's killing me. I want it a little cooler if possible.. Do these motors like to be ran hot? It doesn't seem to be effecting power at 180 but I would rather not smoke this motor I just got it.
thanks for any help
Setup is a B4.1 Buggy with a Viper VTX10 ESC in blinky mode stock timing on the motor. Current gearing is 26/72 came off the track after 5 min at 178.
I am going to try a high Spur tomorrow. and see what happens
Yeah,..........
brent701 is offline   Reply With Quote
Old 06-16-2012, 07:26 AM   #643
Buckaroo's Avatar
X12 runs hotter than all other motors. If you apply the temp limits of other conventional motors, you're going to be slow. X12 doesn't come alive until 160. 180 is more than fine, it's about perfect. Instruction sheet says it's good up to 210*F. Believe it. Only motor I know of that can easily go hotter than the instruction sheet and live.
Tom Keith
Old 06-16-2012, 09:35 AM   #644
brent701's Avatar
interesting,
my manual that came with it says 160 degs and to stay at a 7 FDR
I have tested 7, 7.5, 5, 6, al all in between
I guess I will just leave it where it is at then
thanks
Yeah,..........
Old 06-16-2012, 09:38 AM   #645
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by brent701 View Post
interesting,
thanks
Motor temp can & will vary depending on Ambient temp
180+ is nothing to worry about for an X-12
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
LRP VECTOR 8 1/8 SCALE SYSTEM B.A. Racer Electric Off-Road 25 09-27-2010 10:12 PM
Hacker Brushless Motors 4.5, 6.5, 7.5, 17.5, 10.5, Tekin 10.5 hemi4me R/C Items: For Sale/Trade 15 06-22-2009 08:43 PM
Futaba Servos (BLS451, S9351, S9451) and Hacker, Novak and Tekin Motors hemi4me R/C Items: For Sale/Trade 10 06-13-2009 05:49 PM
