Old 06-29-2011, 01:34 PM   #451
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Hi Guys
Im looking for fdr for x12 13.5t with 4 dot incert for 20x30mtr tight carpet track
runnind hw xtreme stock
Craig W is offline   Reply With Quote
Old 06-29-2011, 02:37 PM   #452
JayBee's Avatar
Trader Rating: 31 (100%+)
Has anyone teamed up an X-12 17.5 w/a SXX StockSpec Version2 in BLINKY MODE running TC's? Whats the best motor/rotor/endbell timing combo w/that speedo?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-30-2011, 06:58 AM   #453
would one of the K4's work?say 10.5t?
iamahuman is offline   Reply With Quote
Old 07-03-2011, 10:40 AM   #454
CLK@racing's Avatar
Default X12 Sintered Rotor WorksTeam - 12.0mm
Hi Burito,
Does the X12 Sintered Rotor WorksTeam works in a normal X12 - non Octa Wind?
Also, the 12.0mm will help to reduce torque in the motor?
Thanks.
Real man races Modified.. simple.
CLK@racing is offline   Reply With Quote
Old 07-03-2011, 11:55 AM   #455
MeBeMikey's Avatar
Originally Posted by Daniel W View Post
I`ve been trying to find some information on these worksteam rotors.My motor currently has the standard 12.5mm rotor.I`ve been looking into buying one of the 12mm worksteam rotors(LRP50636)wondering if there would be much difference in performence.I know they say the 12mm rotor will increase RPM and reduce Torque.
I`ve proberly left information out
Cheers Dan
Stick with the rotor that came with the motor. I tried a 13.0 rotor and spent all sorts of time to get it to work on the SS v1. I found that no one cold help me as they all were on the stock rotor. You need to gear up for that rotor. It doesn't like to rev high and causes a motmot heat if you want to rev it high. Especially on that V1 speedo.
Stick to the 12.5 rotor. When I needed help w/13.0 rotor there wasnt any. And I run at one of the top tracks in the UK and still no one was there to help me.
Xray T4'18, HW XR10 pro, R1Wurks 13.5 V16 - Indoor Carpet
Xray T4'17, HW XR10 pro, Fleta ZX V2 13.5- Outdoor Tarmac
Xray T4'16, HW Extreme Stock, Actinium V2 13.5 -Wet Racing
RcDisCo.com
Last edited by MeBeMikey; 07-03-2011 at 12:00 PM. Reason: Excuse misspelling I'm on my iPhone!
MeBeMikey is offline   Reply With Quote
Old 07-09-2011, 04:46 PM   #456
Originally Posted by Jammin23 View Post
Thanks for the quick replys it's not the lipos I was worried about it was just the fact the input voltage for the 3.5 is 4.8-6 and the my 2s lipo is 7.4! Does the esc regulate the voltage the motor receives? Sorry again for the simple questions!
3.5t is most definetely not recommended for a beginner like....you.
You should worry about your battery pack, I have blown 2 packs with a 4t, start to cost...and I know what I am doing.
Your friends will be most imprest to see your car going in flames
Happy birthday thought
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 07-14-2011, 08:34 PM   #457
Default Boomerang shims, apart from shim/o-ring/shim
Hi
I was in the process of changing the Std to ceramic bearings. Upon opening the motor casing there was 2 pieces of shims fell out from. They are in the size of 1/4 circumference of the motor case and very thin,about 0.49mm.
Still have the,teflon/o-ring/teflon set-up on the rotor.
Anyone knows anything about it as to where it should go probably?
Many Thanks
MobileSuit is offline   Reply With Quote
Old 07-15-2011, 03:39 AM   #458
Default AHHHHHHHHHHHHHHHHHHHHHHHHH
My 13.5 motor is winding me up.
When it's fast at the top end - the bottom has no grunt and vice versa.
I know this should be the best motor, but is it an esc issue - I use the Hobbywing with this esc - does anyone have a better recommendation?
Lohan is offline   Reply With Quote
Old 07-15-2011, 03:42 AM   #459
Craig W's Avatar
They seem to work well with lrp tekin and gm
Old 07-15-2011, 03:44 AM   #460
Craig W's Avatar
Still need fdr help for 13.5t on tight 20x30 mtr track can any 1 help
Old 07-15-2011, 04:29 AM   #461
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
Originally Posted by MobileSuit View Post
Hi
Many Thanks
stock motors -- shim, shim
mod motors -- shim, o-ring, shim
this goes over the shaft on the rotor on the pinion end
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 07-15-2011, 05:02 AM   #462
My motor is 4.5T Octa Wind. I will upload a picture ASAP.
Old 07-15-2011, 05:04 AM   #463
Craig W's Avatar
Just took new 13.5t to bits and there no shims in it
Old 07-15-2011, 05:18 AM   #464
I have read around that not all windings have shims in the X12
Old 07-15-2011, 05:26 AM   #465
Craig W's Avatar
thank you olly
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
LRP VECTOR 8 1/8 SCALE SYSTEM B.A. Racer Electric Off-Road 25 09-27-2010 10:12 PM
Hacker Brushless Motors 4.5, 6.5, 7.5, 17.5, 10.5, Tekin 10.5 hemi4me R/C Items: For Sale/Trade 15 06-22-2009 08:43 PM
Futaba Servos (BLS451, S9351, S9451) and Hacker, Novak and Tekin Motors hemi4me R/C Items: For Sale/Trade 10 06-13-2009 05:49 PM
