Old 03-07-2011, 10:05 AM   #391
Xpress's Avatar
Originally Posted by olhipster1 View Post
I'm actually in the same boat.
I'm running a oo insert in the motor
my setup is Tekin Pro/2cell - nonboosted
final gearing is 3.84
and around 4 minutes mark motor starts to fade.
motor temp is around 130 f.
any ideas which way to go
At Snowbirds (100 x 40ish?) ran a 4.10 with min motor timing. I'd say pull all the timing out and start around 4 flat.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 03-07-2011, 12:05 PM   #392
Default inserts
4 dot is -10 degrees
3 dot is -5 degrees
2 dot is 0 neutral
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 03-07-2011, 12:07 PM   #393
Buckaroo's Avatar
3 dot is -5 degrees
2 dot is 0 neutral
Then flip 'em around to get +5 and +10
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 03-07-2011, 01:37 PM   #394
wingracer's Avatar
Trader Rating: 24 (100%+)
But what do you get if you flip the 2 dot?
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 03-07-2011, 01:59 PM   #395
louielou's Avatar
Trader Rating: 16 (100%+)
Default lrp
i am running it in boosted, with insert they came already in motor. temps were around 170-190 degrees. this should not be a problem for the LRP should it?
Luis
[email protected]
Ebay account LOU840
louielou is offline   Reply With Quote
Old 03-07-2011, 03:34 PM   #396
Xpress's Avatar
You're not even close to smoking it, but anything over 200 and it will fade pretty bad. I've seen peeps run the LRP motors over 250 without smoking, but they fade really bad when getting that hot. The reason I like the motors is that you can be off on the setting, get the motor too hot, see the car is fading, and pull off/slow down etc...without damaging the motor. Every Epic motor I've run lets you know its getting too hot by smoking. Yeah the epic motors run cooler say 150ish, but they smoke at 175. The LRP motors run at 200, but don't smoke until over 250 and there is plenty of warning before they let go.
My $.02
-Espo
Old 03-07-2011, 09:19 PM   #397
The first thing I would do is change the timing insert, reducing the motor timing as much as possible. Then try it again. If the temperatures are still over 160, reduce the ramp of timing in the speed control. Continue reducing the ramp until the motor runs the entire run without fading. Good luck.
davidl is offline   Reply With Quote
Old 03-08-2011, 12:55 PM   #398
louielou's Avatar
Default fading
thanks for the input fellas.
Luis
[email protected]
Ebay account LOU840
Old 03-26-2011, 09:55 PM   #399
big_alex39301's Avatar
I am running a X12 17.5 with a tekin rs in blinky light mode. I tried it with the two and four dot inserts and the motor was around 175 both times. I am geared at 96/47 in a Xray T3 2010. Any suggestion what I am doing wrong.
big_alex39301 is offline   Reply With Quote
Old 03-27-2011, 09:51 AM   #400
Xpress's Avatar
175 is perfectly safe with the X-12.
-Espo
Old 03-27-2011, 05:09 PM   #401
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
+1
I run mine into the high 180's/low 190's.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 04-01-2011, 06:58 AM   #402
Default X12 10.5
Which is the best combination 1s 12.25 rotor or the 12.5 rotor. Using this with the new SXX stock esc. corrected
Old 04-01-2011, 10:16 AM   #403
Which is the best combination 1s 12.5 rotor or the 15.5 rotor. Using this with the new SXX stock esc.
Clarification: The motor comes with a very strong 12.5mm diameter rotor. The 1S rotor is not as strong and is 12.25mm diameter. I think you have a typo there.
Old 04-02-2011, 07:59 AM   #404
bigz's Avatar
has anyone been experiencing fading of there motors. i run 17.5 with a Tekin/ 2 cell, touring car. motor has lots of power, but after about 4mins i notice the motor fades drastically. What can i do to prevent this or does this mean the motor is going bad?
sounds like your undergeared.
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 04-04-2011, 03:18 AM   #405
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Can anyone give me the bearing dimensions in the x12 motor?
Thanks,
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is online now   Reply With Quote
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
LRP VECTOR 8 1/8 SCALE SYSTEM B.A. Racer Electric Off-Road 25 09-27-2010 10:12 PM
Hacker Brushless Motors 4.5, 6.5, 7.5, 17.5, 10.5, Tekin 10.5 hemi4me R/C Items: For Sale/Trade 15 06-22-2009 08:43 PM
Futaba Servos (BLS451, S9351, S9451) and Hacker, Novak and Tekin Motors hemi4me R/C Items: For Sale/Trade 10 06-13-2009 05:49 PM
