Old 01-16-2011, 03:58 PM   #376
pmc
Hello
Someone can help me please, I was wondering what the strength (gauss) of the magnet that comes with the LRP 13.5 T stock spec motor???
Thanks in advance.
Best regards:
Pedro Silva
pmc is offline   Reply With Quote
Old 01-16-2011, 04:11 PM   #377
JayBee's Avatar
Trader Rating: 31 (100%+)
How does these motors compare to the Orion D3 motors, especially the 17.5/13.5 varieties?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-31-2011, 10:10 AM   #378
ROAR has finished the evaluation and approved the LRP 12.25mm tuning rotor for single cell racing in the X-12 motors. The listing has a couple typographical errors, but ROAR provided assurance that those will be fixed soon.
davidl is offline   Reply With Quote
Old 01-31-2011, 01:38 PM   #379
F-1
Hello!
Which gearing will be better for 5.0t motor?
Associated B4.1 - SXX TC V2 - X-12 - Reedy - Proline
Associated B44.1 - SXX TC V2 - X-12 - Reedy - Proline (soon)
Associated TC6 - SXX TC V2 - X-12 - Reedy - Proline
- M11X -
Upgrade Rc 2010 Race Brigade Team
F-1 is offline   Reply With Quote
Old 01-31-2011, 02:01 PM   #380
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Originally Posted by F-1 View Post
Hello!
You'll need to add type of car and track to get help with that.
MarkA is offline   Reply With Quote
Old 02-01-2011, 03:32 AM   #381
bigz's Avatar
if i understand it right, if im using tekin esc i should use 4 dot timing?
currently using regular insert and temps reach 200c and motor has drag brake.
this is for 13.5 stock.
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 02-01-2011, 07:50 AM   #382
F-1
We have medium track size with medium grip. Size of track slightly bigger then at Snowbirds 2011. Also I have TC6 with 87 spur.
- M11X -
Old 02-01-2011, 01:44 PM   #383
rc pete's Avatar
Take a look at the setup sheets on the Team Associated site. You'll notice that most of the guys are running a 20 tooth pinion with the 87 spur on the TC6, and that they're also running the 5.0 Octa wind motor (some run the 4.5 on larger tracks), which runs a little more efficiently (read cooler) than the normal 4-strand 5.0 wind. On the ESC side, the LRP SXX TC V2 also runs a little cooler than the prior models. That, along with the Feel and Boost settings listed, is designed to run at the sharp end of the grid at the international level, so I wouldn't recommend to start there.
Can't recommend a different gearing until you try it, since heat/inefficiency can result from either undergearing or overgearing, so you have to find the sweet spot for your conditions. But detune the ESC to start with, check temps after a couple of minutes to make sure you're on the safe side, and adjust from there.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 02-01-2011, 06:20 PM   #384
Boz
Trader Rating: 23 (100%+)
I have a X12 6.5T Octa in DEX410 and it's getting really hot in about 3min and I can feel it slowing down. (I'm using a SXX TC V2 ESC).
If a motor is on it's way out, can that cause the motor to over heat?
Long story. My first LRP SXX TC v2 brakes started to get soft and it started cogging on my two motor. I order another speedy while this one is being sent back for repairs. Yesterday when I ran the speedy the motor got really hot with gearing on LRP recommendation of 10.8 which is what I ran in my B.44 with no heating problems. I did notice a little cogging yesterday, but not much. (yes i'll check the lead, but it's a new lead)
After the run yesterday I received 1 LED flash on the ESC temp and 8 LED flashes on the motor temp.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 03-07-2011, 04:34 AM   #385
slakr's Avatar
OK... is there anyone willing to explain to me how the whole "insert" thing works for timing?
You know, like this insert gives "X" degrees of timing... and that insert gives "Y" degrees of timing... Etc. Etc.
Thanks.
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 03-07-2011, 07:19 AM   #386
Xpress's Avatar
Thanks.
http://www.lrp.cc/fileadmin/lrp_anle...e-090518fv.pdf
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 03-07-2011, 07:32 AM   #387
slakr's Avatar
Originally Posted by Xpress View Post
Thanks so much. Looked for that on the Associated website, but couldn't find it.
I didn't even think to go directly to the LRP website to look
Thanks again.
Old 03-07-2011, 07:56 AM   #388
louielou's Avatar
Trader Rating: 16 (100%+)
Default fade
has anyone been experiencing fading of there motors. i run 17.5 with a Tekin/ 2 cell, touring car. motor has lots of power, but after about 4mins i notice the motor fades drastically. What can i do to prevent this or does this mean the motor is going bad?
Luis
[email protected]
Ebay account LOU840
louielou is offline   Reply With Quote
Old 03-07-2011, 08:07 AM   #389
I think it means you need to change the configuration of your speedo or change the timing of this motor. You didn't tell us the timing insert you are using on the motor, so we need to know that to help.
Old 03-07-2011, 08:34 AM   #390
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
I'm actually in the same boat.
I'm running a oo insert in the motor
my setup is Tekin Pro/2cell - nonboosted
final gearing is 3.84
and around 4 minutes mark motor starts to fade.
motor temp is around 130 f.
any ideas which way to go
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
LRP VECTOR 8 1/8 SCALE SYSTEM B.A. Racer Electric Off-Road 25 09-27-2010 10:12 PM
Hacker Brushless Motors 4.5, 6.5, 7.5, 17.5, 10.5, Tekin 10.5 hemi4me R/C Items: For Sale/Trade 15 06-22-2009 08:43 PM
Futaba Servos (BLS451, S9351, S9451) and Hacker, Novak and Tekin Motors hemi4me R/C Items: For Sale/Trade 10 06-13-2009 05:49 PM
