Old 12-18-2010, 04:15 AM   #361
F-1
Hello!
I have one question, is the Octa-Wind version faster then standart? What is the difference in running??
Tnanks!
Associated B4.1 - SXX TC V2 - X-12 - Reedy - Proline
Associated B44.1 - SXX TC V2 - X-12 - Reedy - Proline (soon)
Associated TC6 - SXX TC V2 - X-12 - Reedy - Proline
- M11X -
Upgrade Rc 2010 Race Brigade Team
F-1 is offline   Reply With Quote
Old 12-18-2010, 12:50 PM   #362
Default internal stack wind
Has anyone seen this, i pulled my motor apart to check the bearings and when the case came off the stack and i pulled out the rotor there were two inner winds stuck to the rotor. The motor had run well lastnight with no issues other than a slight hesitation going from reverse to fwd drive and after a crash. please advise.
losidrvr is offline   Reply With Quote
Old 12-18-2010, 12:51 PM   #363
mattleegee's Avatar
you should disable reverse to start with
AE ft b4.1 Ballistic 13.5 + SXX comp v2 (3-5-3-8) 1258tg
AE ft b4.1 Ballistic 17.5 + SXX comp v2 (3-7-0-4) 1257tg
BRCR
I pick things up and put them down
mattleegee is offline   Reply With Quote
Old 01-07-2011, 02:53 PM   #364
I used to race in the late 80's. It amazes me on how many drivers have reverse these days.
I'm just saying...
lakerszone is offline   Reply With Quote
Old 01-07-2011, 08:23 PM   #365
Daniel W's Avatar
Thumbs up WorksTeam Rotors
Hey All
Just wondering I run a Associated 12R5.1 LRP SXX TC Spec V1(1 5 0 2) X12 Octa Wind motor IP 5600mah 50c lipo
I`ve been trying to find some information on these worksteam rotors.My motor currently has the standard 12.5mm rotor.I`ve been looking into buying one of the 12mm worksteam rotors(LRP50636)wondering if there would be much difference in performence.I know they say the 12mm rotor will increase RPM and reduce Torque.
I`ve proberly left information out
Cheers Dan
Daniel W is offline   Reply With Quote
Old 01-10-2011, 07:37 PM   #366
Used this motor for 3 days in a SC truck, and blew up the rotor. The magnets popped out from the shaft
anyway, anyone tried worksteam rotor? how's the different?
Wilson Picaldy is offline   Reply With Quote
Old 01-10-2011, 09:04 PM   #367
dsyed1's Avatar
Originally Posted by F-1 View Post
Hello!
Tnanks!
the octa wind definitely runs a lot cooler than the original version... my first one burnt then switched to octa wind a while back and have not had any issues
dsyed1 is offline   Reply With Quote
Old 01-11-2011, 02:00 AM   #368
andrew-01's Avatar
Trader Rating: 22 (100%+)
Buritos post on the new speedo(in the sxxss thread). Looks like the x12 motors and the SXXSSV2 will be the hot ticket.
http://www.rctech.net/forum/8468822-post1186.html
ANDRXW.com
andrew-01 is offline   Reply With Quote
Old 01-11-2011, 11:00 AM   #369
cyclone speed's Avatar
Hello, what is thegearing for lrp x12 13.5 ?
I once had 6 fdr on a medium track, but in the end, the motor was quite cold ... but the weather temp was 1 degree celcius tho ...
cyclone speed is offline   Reply With Quote
Old 01-13-2011, 07:57 AM   #370
The single cell rotors for the X-12 have been submitted to ROAR for approval. Should be up on the ROAR website very soon.
davidl is offline   Reply With Quote
Old 01-15-2011, 08:40 AM   #371
Trader Rating: 45 (100%+)
Default timing mark question
when using the 4 dot in the x-10 degree position, is it actually -10degrees from 0?
Apex is offline   Reply With Quote
Old 01-16-2011, 03:31 AM   #372
CraigM's Avatar
Trader Rating: 34 (100%+)
No it's about 20 deg
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-16-2011, 05:56 AM   #373
Is that -20 degrees or +20 degrees? I'm using an Orion motor and trying to set it similar to the 4dot setting on the x-12.
Old 01-16-2011, 07:24 AM   #374
Anyone please ?
Raced the car today, and compared to the others running 13.5, they were much faster, so i just want to know, whats a good fdr for indoor or outdoor .
Old 01-16-2011, 02:39 PM   #375
CraigM's Avatar
+20
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
LRP VECTOR 8 1/8 SCALE SYSTEM B.A. Racer Electric Off-Road 25 09-27-2010 10:12 PM
Hacker Brushless Motors 4.5, 6.5, 7.5, 17.5, 10.5, Tekin 10.5 hemi4me R/C Items: For Sale/Trade 15 06-22-2009 08:43 PM
Futaba Servos (BLS451, S9351, S9451) and Hacker, Novak and Tekin Motors hemi4me R/C Items: For Sale/Trade 10 06-13-2009 05:49 PM
