Old 10-18-2010, 11:43 AM   #316
morgy's Avatar
i'm also after some info for a 13.5, i'm running mine with an spx stock spec but just can't get the gearing right and profile. i'm running it in a touring car on a tight technical indoor carpet track wot FDR should i aim for and in which profile
morgy is offline   Reply With Quote
Old 10-19-2010, 10:22 AM   #317
rendcool's Avatar
Originally Posted by CarbonJoe View Post
The lower the number, the faster the motor. 17.5, 13.5, and 10.5 are considered "Spec" motors (17.5 being slower than 10.5), and all of the lower number motors are considered "Modified" motors. The "turns" refers to the number of times the wire is wound around the core of the stator. Usually, higher turn motors use thinner gauge wire, so they carry less current. Lower turn motors use thicker gauge wire, and carry a lot more current.
I see,,, thanks for the info ..
rendcool is offline   Reply With Quote
Old 10-22-2010, 07:28 AM   #318
morgy's Avatar
don't worry folks had a evening ove trying different profiles and gearing and ended up on profile8 with an FDR of 7.0, plenty ove punch outta the tight corners and kicks in 2 a missile bout half way down the straight
Old 10-24-2010, 07:18 PM   #319
Need info as to what maybe causing my new 3-4 lap 17.5 motor to start off fine them slowed down.I pulled it off and spun the motor up, it started fine then the motor starts to lose RPM with in 2-3 seconds?
Friulimotosport is offline   Reply With Quote
Old 10-24-2010, 07:44 PM   #320
Xpress's Avatar
I'm looking for a starting fdr for an 8.5 running touring carpet on a 40 x 80 track.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 10-26-2010, 09:59 PM   #321
brian cox's Avatar
Trader Rating: 58 (100%+)
looking for some gearing help with a 17.5 rubber tire sedan on carpet-after reading thru some pages can i assume i need to run the 4 dot timing on the motor,profile 7 on the sxx, and a fdr around 5.5 to 5.75?
Thanks!
Team Orion---Bradley Fine Line Design---AKA
brian cox is offline   Reply With Quote
Old 10-28-2010, 11:53 AM   #322
brian cox's Avatar
anyone have any advice?
Old 10-28-2010, 12:09 PM   #323
masterhit's Avatar
Trader Rating: 15 (100%+)
Which SXX? The Stock Spec? If so...
4 dot, 4-6 (depending on the MK) on boost, 6.2-6.5 FDR.
Mike Slaughter
masterhit is offline   Reply With Quote
Old 10-28-2010, 03:32 PM   #324
brian cox's Avatar
Mike Slaughter
It is the straight up sxx origional version..
Old 10-28-2010, 06:07 PM   #325
Trader Rating: 22 (100%+)
Default X-12 10.5 WGT with 12.25mm 1s lipo rotor
im running WGT X-12 10.5 4 dot timing and 12.25 1s lipo rotor with a tekin rs speedo with no timing or boost. I have 88/33 gearing. car is ok speed but should i go down in pinion to get more torq? would that lower gear end up giving me more speed on the streight?
D-Bizzle is offline   Reply With Quote
Old 11-01-2010, 08:13 PM   #326
Anyone???????
Old 11-03-2010, 04:59 PM   #327
rc pete's Avatar
Anyone???????
Weird things like that call for the process of elimination.
Assuming that your solder joints are ok and nothing is dragging in the driveline, and your speedo is setup right.... maybe check that over and redo the speedo setup to be sure.
Try another sensor wire. Try another motor, to make sure it is in fact the motor.
Then try replacing motor parts if you have spares: another sensor then another rotor, check the bearings. Hopefully some of that will be it. Otherwise it leaves only the motor windings which you can't do much about.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 11-03-2010, 05:06 PM   #328
Trader Rating: 20 (95%+)
What kind of final drive and motor timing is everyone running in no boost 17.5 TC? Just want know where to start for a 80X36 technical carpet track.
Stlfc is offline   Reply With Quote
Old 11-03-2010, 05:28 PM   #329
Rockpyle's Avatar
Trader Rating: 23 (100%+)
I'm running a 4.33 ratio with 1 dot (5 degree insert)
(Tekin Rs 208 no timing profile) on 100x50ish? track comes off at 165-170 every time with a heat sink and a fan (17.5 rubber TC)
I tried more gear but it seemed to get soft at 3-4 min and got near 200.
Rocky
Rockpyle is offline   Reply With Quote
Old 11-03-2010, 08:50 PM   #330
I'm running a 4.15 with the 2 dot insert (no advance, I believe) and the motor temps 165 deg with a fan/heatsink. The car is very good in the infield and pretty good on the straights although I'm going to experiment with more timing and shorter gearing.
Cheers,
Mike
Mike
Hyper_Mike is offline   Reply With Quote
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
LRP VECTOR 8 1/8 SCALE SYSTEM B.A. Racer Electric Off-Road 25 09-27-2010 10:12 PM
Hacker Brushless Motors 4.5, 6.5, 7.5, 17.5, 10.5, Tekin 10.5 hemi4me R/C Items: For Sale/Trade 15 06-22-2009 08:43 PM
Futaba Servos (BLS451, S9351, S9451) and Hacker, Novak and Tekin Motors hemi4me R/C Items: For Sale/Trade 10 06-13-2009 05:49 PM
