Old 10-13-2010, 12:38 PM   #301
AE-Reedy
Originally Posted by JayL View Post
What is the easiest way to lube the rear bearing?
Unplug the sensor harness from the motor. Remove the the screw holding on the plastic cover. Pop off the cover, remove the sensors. It might require a little twisting action to get them out. You will then be able to oil the bearing. Just add a little oil, too much can just cause contamination of the sensor board.
While you have the sensors out now would be a good time to clean them before reinstalling. Spray the 3 legs with a little electronic safe spray. Then gently wipe them off with a clean rag. When you put the cover back on make sure that you install the timing insert in the correct position.
Reconnect the sensor harness.
Sean Cochran is offline   Reply With Quote
Old 10-14-2010, 09:13 AM   #302
RCaddict0's Avatar
Trader Rating: 85 (99%+)
Send a message via AIM to RCaddict0
I just recieved an almost new 6.5 5300kv in a trade. And this is a smooth operator paired with 2.4 and Novak GTB Spec ESC on 2s. Ranit in my Modified Slash 2wd and in the Tc3. Very nice. This is my first sensored set up and Im impressed with the difference from sensorless. Next system will be a Novak. Anyone have a cheap one with the LVC for sale??!! Im short one. Keep movin it around. Goin through my servo tape to quickly thou
E Maxx Brushless ~ Rustler VXL ~ Rally VXL 1/16
Ruckus Brushless ~ Stampede VXL
* Hobbywing Powered *
RCaddict0 is offline   Reply With Quote
Old 10-14-2010, 09:20 AM   #303
Trader Rating: 27 (100%+)
I have a motor that got a lil hot. Motor is still running but not at peak. Does lrp not make a replacement stator for this motor like the duo's?
Alex B
Kyosho America/Byron Fuels/J concepts
For all your painting needs!
Elite Paint Workz
[email protected]
mist467 is offline   Reply With Quote
Old 10-14-2010, 11:55 AM   #304
AE-Reedy
I would try replacing the rotor they are effected by the heat most. If the stator is not shorted then there should be no issue with it.
Old 10-14-2010, 01:50 PM   #305
rendcool's Avatar
may I know what are the differents between turn 3.5, 6.5, 10.5 and etc ???
what is that turn for ?
rendcool is offline   Reply With Quote
Old 10-14-2010, 03:30 PM   #306
fullout's Avatar
Send a message via MSN to fullout
last weekend my 17.5 lrp x12 came off at 250F, with visible smoke, i forgot to turn down my tekin after switching from a different brand motor. Anyway the motor still runs strong. I have heard that lrp's can take lots of heat, but now i am sure they can.
fullout is offline   Reply With Quote
Old 10-14-2010, 04:15 PM   #307
Trader Rating: 55 (100%+)
get the 3.5
Jamison R is offline   Reply With Quote
Old 10-14-2010, 04:16 PM   #308
rendcool's Avatar
Originally Posted by KingKarate757 View Post
get the 3.5
is that the good one ??
what's the different ?
Old 10-14-2010, 05:11 PM   #309
avs
avs's Avatar
Hi Sean,
what endbell timming for 13.5 X-12 would you suggest for WGT with 0timing (going to TQ this weekend?)
i tried the 3dot and torque was ok, but speed was down, and now realize i should have left in the 2dot?
So should i try to tune rollout with 2dot or get more timing to work?
thanks for any help on this,
tony
Tony Shimko
avs is offline   Reply With Quote
Old 10-14-2010, 06:37 PM   #310
AE-Reedy
Originally Posted by avs View Post
Hi Sean,
tony
That's hard to say as I have not run any 0 timing. I would think you would want to use 2 dot or maybe even 1 dot timing and then find the right gear.
Old 10-14-2010, 09:57 PM   #311
avs
avs's Avatar
sounds reasonable, thanks Sean.
Tony Shimko
Old 10-14-2010, 11:10 PM   #312
pakk's Avatar
Trader Rating: 79 (100%+)
I know this is the x12 forum, but can anyone tell me what size bearings the x11 takes and are they the same size as the x12?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 10-15-2010, 10:30 AM   #313
JayL's Avatar
can I put my x12 mod in a stock spec can for the bigger bearings?
JayL is offline   Reply With Quote
Old 10-15-2010, 10:49 AM   #314
Regional Moderator
CarbonJoe's Avatar
The lower the number, the faster the motor. 17.5, 13.5, and 10.5 are considered "Spec" motors (17.5 being slower than 10.5), and all of the lower number motors are considered "Modified" motors. The "turns" refers to the number of times the wire is wound around the core of the stator. Usually, higher turn motors use thinner gauge wire, so they carry less current. Lower turn motors use thicker gauge wire, and carry a lot more current.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 10-15-2010, 11:01 AM   #315
avs
avs's Avatar
i am trying to gather info for an 13.5 zerotiming WGT class.
it looks like people are using the 4dot insert in a similiar way to a duo2 or tekin at 0 endbell timing.
so a duo2 at 20degrees would suggest trying a 1dot or 0dot insert?
has anybody tried this?
Tony Shimko
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
LRP VECTOR 8 1/8 SCALE SYSTEM B.A. Racer Electric Off-Road 25 09-27-2010 10:12 PM
Hacker Brushless Motors 4.5, 6.5, 7.5, 17.5, 10.5, Tekin 10.5 hemi4me R/C Items: For Sale/Trade 15 06-22-2009 08:43 PM
Futaba Servos (BLS451, S9351, S9451) and Hacker, Novak and Tekin Motors hemi4me R/C Items: For Sale/Trade 10 06-13-2009 05:49 PM
