Old 05-30-2010, 12:55 AM   #256
cyclone speed's Avatar
Hello, what gearing is best for a 13.5t x12 motor, eunning with the lrp tc spec and SP GT 2.0 .
Could anyone post a range of gearing i.e 5.8 - 7
Il be runnning indoor on medium grip medium sized track .
Thank you
cyclone speed is offline   Reply With Quote
Old 05-30-2010, 03:20 AM   #257
bigz's Avatar
my 13.5 looses brakes after running 2 mins. but at the start of the race, brakes are very strong. what can be causing this?
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 05-30-2010, 04:49 AM   #258
What gearing you using for your 13.5 ? And what esc you use ?
Old 05-30-2010, 05:48 PM   #259
Default X12 10.5 1cell lipo 1/12
Hi
Has anyone played around with one with a black diamond v2 in a 1/12 just like to know at present i am on 50
mpr 2 on esc and -10 on insert
if i go up on programs i dump as it is just to thirsty on battery
What is the 0 dot on the motor is it 0 degrees or somthing else just like to know
thanks
Quietman is offline   Reply With Quote
Old 05-30-2010, 11:06 PM   #260
bigz's Avatar
fdr at 6.8 using a tekin rs pro v203.
Old 05-31-2010, 01:41 AM   #261
FK05 lover's Avatar
Trader Rating: 147 (99%+)
If you can, try changing your rotor
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 05-31-2010, 10:23 PM   #262
bigz's Avatar
will do though a buddy of mine also has the same problem. sheeesshhhh.. the motor is good though, problem is the brakes.
Old 05-31-2010, 10:31 PM   #263
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
What settings are you running in your Tekin?
Run Barry Baker's 13.5 setup and run somewhere around 8.3-8.6. I think your gearing is overheating the motor.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 06-01-2010, 11:00 PM   #264
bigz's Avatar
will try that. thanks.
Old 06-02-2010, 12:17 AM   #265
Aint 8.3 a litle high , dont most people run between 5.9 to 7 fdr ?
Old 06-25-2010, 08:56 PM   #266
ChadB.'s Avatar
Trader Rating: 21 (100%+)
I feel like an idiot asking this question, but I am having trouble figuring out how to adjust the timing. I have followed the directions but the plastic end cover seems to keep it in one position. I am running a 13.5 X12 with a Tekin speedo with 203 software. Any help would be great.
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*Daves RC Track*
ChadB. is offline   Reply With Quote
Old 06-25-2010, 09:04 PM   #267
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
The cover will remain in the same position.
Timing inserts rotate the internal sensor plate only.
With the cover off you can rotate the sensor plate to see how that works.
hth
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-25-2010, 09:18 PM   #268
ChadB.'s Avatar
hth
So the only way to change the timing is to change the rectangular piece that sits on the sensor plate? I can't pivot the endcover like a Duo?
Chad Burdick
Old 06-25-2010, 09:24 PM   #269
Trader Rating: 5 (86%+)
Default x12
chad r u running in kenner tommorow ...
obi wun is offline   Reply With Quote
Old 06-25-2010, 09:32 PM   #270
ChadB.'s Avatar
No I am racing in battleground, Wa tomorrow.
Chad Burdick
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
LRP VECTOR 8 1/8 SCALE SYSTEM B.A. Racer Electric Off-Road 25 09-27-2010 10:12 PM
Hacker Brushless Motors 4.5, 6.5, 7.5, 17.5, 10.5, Tekin 10.5 hemi4me R/C Items: For Sale/Trade 15 06-22-2009 08:43 PM
Futaba Servos (BLS451, S9351, S9451) and Hacker, Novak and Tekin Motors hemi4me R/C Items: For Sale/Trade 10 06-13-2009 05:49 PM
