Old 11-22-2009, 09:22 PM   #211
lbckevin's Avatar
Trader Rating: 91 (99%+)
could not find one on tower...do you have a link ?
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 11-22-2009, 09:26 PM   #212
syndr0me's Avatar
Trader Rating: 32 (100%+)
http://www3.omnimodels.com/cgi-bin/w...I=ASCC0562&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXYTF9&P=7
If you can get the order over $100, omnimodels will ship it for free. Motor is $95 on its own. Omnimodels is Tower with free shipping and slightly different coupons.
syndr0me is offline   Reply With Quote
Old 11-22-2009, 09:35 PM   #213
lbckevin's Avatar
Thanks...I tried a search and nothing came up...
Kevin Smith
Old 12-07-2009, 07:20 PM   #214
Trader Rating: 114 (100%+)
Just picked one up and can't wait to try it on Sunday!
Now.. question about the timing piece... i'm assuming -5 deg is 3 dots that you can see on the outside of the motor? Not the inside?
Chris Furman is offline   Reply With Quote
Old 12-07-2009, 07:37 PM   #215
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
There 90 at nexus
http://www.nexusracing.com/product_i...4378509c221360
Been thinking about trying one. They seem like there a really different motor though? Dont like alot of esc timing?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 12-07-2009, 08:56 PM   #216
ShaunMac's Avatar
Since you're not supposed to use Profiles 7 & 8 on the SPX with the X12 motors. You lose the ability to gear for the infield and let the timing boost work its magic on the straightaway. Looks like the new SXX Stock Spec ESC will be a better choice for the X12 Spec motors since you will be able to adjust the Profile and Boost settings independently. That way you can have a linear profile with mad boost for the straightaway instead of having to use a really aggressive map to get any boost at all like with the current SPX.
ShaunMac is offline   Reply With Quote
Old 12-07-2009, 09:20 PM   #217
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
i got 1 that i used for 4 packs. motor is very fast i just dont like how much drag brake it has. motor ran 150-160 for temp. i will let it go for 75 shipped if you are looking for 1. pm or email me. jeremy
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 12-17-2009, 04:51 AM   #218
swimbikerun's Avatar
Trader Rating: 100 (100%+)
Default LRP X12 17.5 & 13.5
I'm interested in switching over to the X12 for 17.5 and 13.5 but have some questions about not adding timing on th speedo. I'm currently using a Tekin RS Pro/Trinity Duo combo in both my TC and 1/12 scale. What is the consensus on using the X12on these speedos and what type of settings are people running (ie no additional timing?).
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 12-17-2009, 01:07 PM   #219
Joey4875's Avatar
What FDR is a good starting point with the -5 degree timing. I run the LRP SPX and with the duo I run full timing and 5.49 fdr now
Joey4875 is offline   Reply With Quote
Old 12-21-2009, 04:22 AM   #220
jammincrtjames's Avatar
For those who ran the 17.5 this weekend, did anybody have problems gearing this motor to get it not to fade mid way through the race?
NEXUS RACING www.nexusracing.com | FANTOM RACING www.fantomracing.com
ORCA www.orcarc.com | TURTLE TRAX / www.turtletraxraceway.com
"If you're not first...you're last!"
jammincrtjames is offline   Reply With Quote
Old 12-21-2009, 09:55 AM   #221
masterhit's Avatar
Trader Rating: 15 (100%+)
Yes, I ran into the same problem. By the end of the day I ended up at -10 timing (4 dot) with an FDR of 5.57 with 2/7/1/1 on my SPX. It was about 160 at the end of the run with one high speed 25mm fan. This set-up stayed strong for the full run.
I know your not supposed to use profile 7 or 8..... But I'm a sucker for it.
It was slightly faster than another competitive driver running a ballistic (I believe) and Tekin with Vegas 200, and good out of the turns. There is also the caveat that I was running a shaftie (Evo V MS).
I still don't feel this is the "best" set-up, but it should be a good start. This was rubber tire TC on carpet.
Mike Slaughter
masterhit is online now   Reply With Quote
Old 12-21-2009, 10:17 AM   #222
LOW ET's Avatar
Trader Rating: 97 (100%+)
Mike Slaughter
maybe try -5 on the motor and profile 6 on the esc???
LOW ET is offline   Reply With Quote
Old 12-21-2009, 10:28 AM   #223
masterhit's Avatar
I almost mentioned that possible combination, I just ran out of time to try it (great minds think alike?!?!? ).
Mike Slaughter
Old 12-28-2009, 07:22 AM   #224
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
watched a friend nearly sell his car b/c of 1 of these x12 motors. any1 have an issue where regardless of prgm'g, speedo, radio settings trim, load/noload....where on the gas lil or a lot when the motor slowed down to a very slow 'idle' (if we were talking bout our daily drivers) lock as if it had full brake? every time no matter what we thru at it, this motor would do it. 3rd offroad race on it. did it in a 2w and 4w as well. poor guy. gave em a losi 10.5 to get outta dodge and make the day.
R
UltegraSTI is offline   Reply With Quote
Old 12-28-2009, 07:31 AM   #225
syndr0me's Avatar
I've noticed the motor has a lot of natural cog, and made the car transfer a lot of weight forward off-power, and sometimes swap ends. Adding some throttle trim ("creep") seemed to counteract this nicely. That said, the motor is slower than my DUO. :-\ And I'd love nothing more than to be rid of Trinity motors.
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
LRP VECTOR 8 1/8 SCALE SYSTEM B.A. Racer Electric Off-Road 25 09-27-2010 10:12 PM
Hacker Brushless Motors 4.5, 6.5, 7.5, 17.5, 10.5, Tekin 10.5 hemi4me R/C Items: For Sale/Trade 15 06-22-2009 08:43 PM
Futaba Servos (BLS451, S9351, S9451) and Hacker, Novak and Tekin Motors hemi4me R/C Items: For Sale/Trade 10 06-13-2009 05:49 PM
