Old 09-24-2009, 10:32 AM   #181
Questions?? X-12 comes with 2 shims and 1 o-ring?
Hello guys, I have just received my x-12 motor. Very nice and smaller in size compare to other motors.
I dissambled the motor just to have a quick peek inside. I notice that my motor comes with 2 shims and 1 o-ring, whereas the diagram in the manual and LRP website show only 1 shim and 1 o-ring. Has the factory inadvertently inserted an extra shim on the rotor??
HCHL is offline   Reply With Quote
Old 09-24-2009, 11:16 PM   #182
burito's Avatar
We try to limit axial play to a minimum in production, therefore some motors have 1 shim while others have 2.
Reto Koenig
burito is offline   Reply With Quote
Old 10-05-2009, 04:19 AM   #183
Nuno Gancho's Avatar
Hi Burito, i am using speedo sxx with a 4.0 lrp x12 and lrp lipo, ather the race the motor was ate 126c, speedo 60C, battery 50C with the program 1,6,0,0, it was the only way to keep fast in the race, is that to much?
The problem is that i am racing with other drivers that are faster because using a faster motor, and i dont know if the speedo will support a 3.5 X12 with lipo in big tracks, but i would not like to destroy the speedo, lipo and motor. Thanks.
Nuno Gancho is offline   Reply With Quote
Old 10-05-2009, 06:14 AM   #184
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
the motor is way too hot max temp should be around 105c. And thats really hot Arent your lipo puffing up? If the motor is coming off at that temp mine have/would.... Change your speedie setting to 1,2,0,0 and put a fan on the motor to keep the temps down a bit. These motors are plenty fast. On a large track run a fdr between 8.4-9.0 i would say.
Hope this helps,
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 10-05-2009, 02:50 PM   #185
Hi, i have tried 8.7 and the motor came 111C and wasnt that fast almost a second slower, does not have power out of the corners, with 9.38 i was faster than 8,7 and the motor was cooler 105c with 1,4,0,0
Old 10-05-2009, 11:30 PM   #186
burito's Avatar
Holy cow... 126C??? Are you sure your IR meter is measuring fine?
Anything above 100C is unhealthy and normally an indication that something is not running or set well.
Can you please give me your full settings:
1. gearing
2. motor timing setting
3. rotor you used
4. track size (a link or picture of the track would help)
I can't believe an X12 4.0t is not fast enough with LiPo, that should be insane power on any track...
Reto Koenig
Old 10-06-2009, 12:40 AM   #187
jonest's Avatar
Motor temp more than 80 deg won't be good for ur lipo. I think u have overgeared it at 8.7, that's y ur slower becoz at that FDR, u gain top speed while u loose torque.
I'll gear my X12 4.5t at 9.2t (big track) while motor timing is -10 deg,
Gd luck.
jonest is offline   Reply With Quote
Old 10-06-2009, 05:06 AM   #188
track size (a link or picture of the track would help) -- http://1.bp.blogspot.com/_m1kL1mFooK...S240/pista.bmp
in the foto it starts in the red line, then follow the yellow line.
http://www.alojarfotos.com/images/nu...istasintra.jpg
Old 10-06-2009, 09:13 AM   #189
jonny123's Avatar
Default X12 4t gearing
Hi, i need some advise on gearing for the x12 4.0t with 5cell on a medium sized indoor track. The highest gearing i can get is 8.85 will i be ok at that. Its in between the sugested gearings in the manual so im guessing it'll be ok, i just dont want to cook the motor on it first run haha.
-Jonny
Xray-Hudy-Ko Propo-RC DisCo Uk-Ardent Racing-Boultspeed
jonny123 is offline   Reply With Quote
Old 10-06-2009, 09:34 AM   #190
Mr.Che's Avatar
Indoor 9.0-9.6 most of the time ... timing -10
for 5 cells.
Mr.Che is offline   Reply With Quote
Old 10-13-2009, 01:03 AM   #191
PaPeRo's Avatar
Any updates on whether or not these motors have been fixed of whatever issues they've been having? I'm trying to decide whether or not I should get this motor or something else. Are the X12 much better than the X11? What other motors from other brands are as fast as these but reliable? Since the new batches have the timing retarded does it mean the max rpm is decreased?
One last question, does anybody know what the ABEC rating is for the ball bearings that come with these motors?
PaPeRo is offline   Reply With Quote
Old 10-13-2009, 01:51 AM   #192
get an x11, i am using my x11 for 2 seasons and without any maintenance it runs perfectly. even i didn't clean the bearings.
but x12 is a problem source, all my friends had many problems with x12 in the nationals, i had an x12 also too, i didn't have bearing problem but mine lost its power, no punch, no top speed.
khaledome is offline   Reply With Quote
Old 10-13-2009, 02:28 AM   #193
PaPeRo's Avatar
Ok I trust your experience and judgement, I will go with x11, thanks.
Old 10-27-2009, 07:34 PM   #194
LOW ET's Avatar
Trader Rating: 97 (100%+)
anyone know how much an x12 3.5t motor weighs?
LOW ET is online now   Reply With Quote
Old 10-28-2009, 09:19 AM   #195
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
i'd weigh mine, but the endbell bearing collapsed and its in pieces...
that being said, you'd expect the weight to be very close to all the other ROAR approved motors, being 168gms (from memory so please correct if i'm wrong)
-Mark
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
FWR Racing Season FWR Northwest Racers 11302 08-23-2015 07:38 PM
LRP VECTOR 8 1/8 SCALE SYSTEM B.A. Racer Electric Off-Road 25 09-27-2010 10:12 PM
Hacker Brushless Motors 4.5, 6.5, 7.5, 17.5, 10.5, Tekin 10.5 hemi4me R/C Items: For Sale/Trade 15 06-22-2009 08:43 PM
Futaba Servos (BLS451, S9351, S9451) and Hacker, Novak and Tekin Motors hemi4me R/C Items: For Sale/Trade 10 06-13-2009 05:49 PM
