Old 09-15-2009, 03:02 AM   #166
CraigM's Avatar
Trader Rating: 34 (100%+)
@burito: do you know what timing hupo runs his 6.5 with for offroad?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 09-15-2009, 04:39 AM   #167
burito's Avatar
@CraigM: he hardly ever runs 6.5t in his 4wd actually, normally he's on a 7.5t in 4wd... Anyway, he runs both with the lowest timing (oooo insert).
Reto Koenig
burito is offline   Reply With Quote
Old 09-17-2009, 04:55 PM   #168
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Verndog View Post
Update on LRP X12 5.5T. After having issues with shaft length, got that resolved by changing to 008 chassis...today at around run #15 on this motor, the end bell side bearing siezed, blew the rotor, then torched the windings. The bearing can be seen frozen on the end of the shaft.
The motor ran great, had great power, and gave no signs of failure until the melt down. I've had it about 40 days....am I SOL or will they replace my motor for me?? If so, contact info appreciated.
Wanted to report back that LRP did warrantee the motor and sent me a free replacement. I took the 8.5T since the 5.5 was out of stock and I had already replaced it with the new Balistic. I'll try that in offroad this fall, and will be ordering some ceramic bearings to be on the safe side.
Took a while, but they did what was right, and I'll continue to support their products. This is the first real issue I've had with LRP products, and I have 4 various LRP speed controls and 1 other X11 motor with no issues in a couple of years.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 09-18-2009, 09:30 AM   #169
jonest's Avatar
Great to hear that and LRP oso replacing my motor which has some slight issue. Great company indeed. It's right to have bought their product after all.
jonest is offline   Reply With Quote
Old 09-19-2009, 12:10 PM   #170
Default Supposed to run with 'oooo' timing insert?
Hi. Just bought my X-12 today. Its a 5.0turn and came with the 'oooo' timing inserts installed. My question is whether we are recommended to run with this -10 deg timing ?
And whether it will somewhat reduce the heat issues related to the X-12?
Finally are there are other difference between the 1st and 2nd batches of motors (ie different rotor design or better bearings)?
Thanks in advance for any inputs given.
radwerx is offline   Reply With Quote
Old 09-19-2009, 12:31 PM   #171
jonest's Avatar
It's best to start off at -10deg timing and the gear ratio follow manual. Then do check the motor temp. I've compared older batch v new batch motors are slightly bigger vent holes on the new motor, old - 4mm; new - 5mm.
have fun.
Old 09-19-2009, 11:09 PM   #172
have fun.
Thanks. Can anyone provide the ID/OD/thickness of the X-12 bearings so I may be able to source for some ceramic ones? Don't seem to be able to find this piece of info in the thread.
Old 09-20-2009, 01:10 AM   #173
dameetz's Avatar
I think its 4mm x 10mm x 4mm. I ordered mine from BOCA but yet to received yet. Its been almost 3 weeks since they posted it but that is understandable coz I live in Asia, so shipping from the states to here maybe take a little while.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 09-20-2009, 09:02 AM   #174
Verndog's Avatar
Yep, I can confirm that. I checked bearing after getting motor and it 4 x 10 x 4.
---Team Hoarders---
Old 09-21-2009, 02:50 AM   #175
Cool. Thanks guys. Is the rotor hard to assemble back after striping the little bugger to change the bearings? I experienced quite a bit of difficulty with other makes when trying to slot the rotors into the bearings when assembling.
Old 09-21-2009, 10:14 AM   #176
Verndog's Avatar
Ya, it takes a few tries to get rotor back into end bearing but it's doable. I ended up using a set of pliers to hold the pinion end of rotor to help hold and guide it in and that helped.
---Team Hoarders---
Old 09-21-2009, 11:24 PM   #177
burito's Avatar
The easiest way to put-in a rotor is to remove endcover and sensor-system first (it's only 1 screw!) because then you can guide the rotor into the bearing by using a small allen wrench as the shaft has small holes from grinding on both ends.
Hard to explain, but you'll understand once you look at the shaft... then it's real easy and that's also how the process was intended.
Reto Koenig
Old 09-22-2009, 06:59 AM   #178
I shall look at it over the weekend. Haha. Nothing better than the wise words from the factory rep eh?
Old 09-22-2009, 07:18 AM   #179
jonest's Avatar
That's the best way to place the rotor back to the casing...
Old 09-23-2009, 04:05 AM   #180
hey guys was wondering what would be best gearing for a gas car track on my lrp sxx,40c lipo,lrp x12 4.0 motor
tamiya_008 is offline   Reply With Quote
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
LRP VECTOR 8 1/8 SCALE SYSTEM B.A. Racer Electric Off-Road 25 09-27-2010 10:12 PM
Hacker Brushless Motors 4.5, 6.5, 7.5, 17.5, 10.5, Tekin 10.5 hemi4me R/C Items: For Sale/Trade 15 06-22-2009 08:43 PM
Futaba Servos (BLS451, S9351, S9451) and Hacker, Novak and Tekin Motors hemi4me R/C Items: For Sale/Trade 10 06-13-2009 05:49 PM
