Old 11-06-2008, 11:11 AM   #1
TFR
TFR's Avatar
Default Solvent to dissolve colour springs?
Any idea what I can use to dissolve a set of colour springs? Are the springs powder coated?
Thanks.
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 11-06-2008, 11:19 AM   #2
BobbyS's Avatar
Am assuming you mean the color coating, if so then brake fluid will do it.
"After the third flip, I lost control............"
BobbyS is offline   Reply With Quote
Old 11-06-2008, 01:36 PM   #3
94eg!'s Avatar
Trader Rating: 17 (100%+)
You could buy the sets of Tamiya springs that come in all white or all light blue. They have a tiny color dot near the bottom so people can't tell what rate your using...
94eg! is offline   Reply With Quote
Old 11-06-2008, 01:50 PM   #4
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
just Dye them black with Rit Dye, much easier and alot less clean up
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 11-06-2008, 07:05 PM   #5
Drifting101's Avatar
The paint is also taken into consideration with doing tension ratings
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 11-06-2008, 07:26 PM   #6
as in, different color paint makes the spring rate change?
different color paint used as to distinguish spring rates......yes.
z-man280 is offline   Reply With Quote
Old 11-06-2008, 07:28 PM   #7
As in the paint makes them harder or softer to a bear spring
Schumacher
Old 11-06-2008, 08:19 PM   #8
I12PonU's Avatar
Trader Rating: 10 (92%+)
probably negligible. what's next? layer of CA on the edge of base plate will make the chassis stiffer?
I12PonU is offline   Reply With Quote
Old 11-06-2008, 08:24 PM   #9
RC_Dan's Avatar
Send a message via MSN to RC_Dan Send a message via Yahoo to RC_Dan
You could prob use aircraft stripper, graffiti remover, or easy-off oven cleaner.
All of which are nasty, use gloves.
AE TC6 B4 & 18T, Kyosho Lazer ZX-5
CRC Gen XL & Battle Axe, Hot Bodies Ve8
460whp CRX on E85
RC_Dan is offline   Reply With Quote
Old 11-06-2008, 08:44 PM   #10
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
aircraft stripper....deadly, but holy jesus it works like a charm. Just dip your spring in there and in seconds the paint will vanish!
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 11-06-2008, 09:07 PM   #11
Kevin CBR's Avatar
Krylon paint stripper from your local auto parts store is what I used.
Kevin CBR is offline   Reply With Quote
