Old 11-06-2008, 10:14 AM   #1
Fabricio's Avatar
Send a message via MSN to Fabricio Send a message via Skype™ to Fabricio
Default Parma Foam Tires
bought some tires on the ebay.
they are the cyan 28mm
the box states to use them on the front, did someone have used them on the rear, if i try what sort of problem can i have.
ARC R10 - ORCA - SANWA - EPIC
Fabricio is offline   Reply With Quote
Old 11-06-2008, 10:25 AM   #2
Regional Moderator
CarbonJoe's Avatar
Try e-mailing [email protected]
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-06-2008, 11:12 AM   #3
CypressMidWest's Avatar
The Cyan is a dual compound tire made specifically for the front-end, with a harder ring on the outside. If used on the rear the car will be unstable and prone to spinning out. They work very well on the front if the car is tending to traction roll due to the side wall of the tire deflecting.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 11-06-2008, 11:21 AM   #4
Fabricio's Avatar
thanks for the help guys
what should be a great choice for the rear them?
Old 11-06-2008, 11:26 AM   #5
Like others have said the cyan has a harder outer foam. The inner foam is the same as a parma magenta. So run a parma magenta in the back and a parma cyan in the front.
JoelV is offline   Reply With Quote
MSRA Classifieds Modena AL MSRA (Memphis, TN) 1863 03-28-2013 01:24 PM
Parma Foam Tires CRASH R/C Items: For Sale/Trade 22 02-28-2008 06:40 AM
2007 International Indoor Championship @ South Point Hotel & Casino in Las Vegas Big Daddy Boomer Electric On-Road 1551 01-19-2008 04:20 PM
Parma 1/10 Cyan & Indigo foam tires $10 NIB rraden R/C Items: For Sale/Trade 31 08-29-2007 05:23 AM
Parma foam tires? WheelNut Electric On-Road 55 09-29-2006 10:22 PM
Parma PSE Foam Tires are here!! rayhuang Electric On-Road 92 02-08-2005 01:38 PM
