tc5 gearing question
hey guys, if im running a 96 tooth 64pitch spur 10.5 brushless motor on a tc5-then what should be the best pinion to start with?
thanks! |
what motor and how big is the track?
10.5 motor-the track has about a 140ft back straight--i say about a medium size normal all around track.
go to ... gearchart.com .... get yourself a gearchart then gear to around 4.5 fdr to start with and go from there check your temps and stay around or below 160 degrees.
Originally Posted by poochy
(Post 5021834)
thanks! |
