Old 10-02-2003, 02:18 AM   #16
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
i too had problems getting the Kr to run well for me when i first got them. But these motors do have a sweetspot that once you get them (which i admit is the challenging part), they have wicked speed.
here are what works:
1. the stock copper springs are way too soft! you can either bend them to 180 deg (slightly less in the neg) or go with trinity purples on both ends. if you go with the trinity, slightly bend the neg side softer as well. too soft a spring causes excessive arching which promotes premature brush wear.
2. do not go more than 15 degs timing in this motor. for some reason it does not seem to like a lot of timing (like a Ti would normally run best at 20 degs). the Kr has tons of top end as it is and i think putting too much timing just takes away torque and power. too much timing will also wear out your brushes quickly as you're making the motor rev excessively. with high timing the motor will run fast .... but for 2 maybe 3 runs max and then its pig! ... and yes, you will dump faster.
3. start to gear this motor 2 teeth down (assuming you use 64 pitch gears, maybe 1 tooth down if 48 pitch) from how you would gear other motors of the same wind.
4. use higher silver brushes rather than the 766s that come with the motor. i use 767s, they just simply give more power but aren't too abrrasive compared to other higher silver content brushes (ie. putnams, 4499s)
5. use good comm drops. i use tribo. just a drop every 3-5 runs.
note this set up works for me in 6-cell TC. for 4 cell, you can go back to the softer copper springs ang maybe less timing.
hope this helps.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 10-02-2003, 10:34 AM   #17
Windtalkers's Avatar
Send a message via ICQ to Windtalkers
track length is about 160m.....
Originally posted by highwayman
1. 8.65 to 9.35 (approximately) what's the size of the track you run on?
2. stock timing to 20 degrees, although, i went as high as 30 degree on mine, but could never make run time... (5 mins) but the power was AWESOME!
Windtalkers is offline   Reply With Quote
Old 10-06-2003, 04:35 PM   #18
Any knows about Reedy PT series?
ksrcracing is offline   Reply With Quote
Old 10-06-2003, 06:31 PM   #19
Ad Far as I know its a small comm quad magnet Reedy.
Sort of a Ti/KR. I also THINK it was made for 4 cell, but now the Kr will run 4 cell with some tweaking.
David Root
David Root is offline   Reply With Quote
Old 10-06-2003, 06:40 PM   #20
ROBORAT's Avatar
ksrcracing: it should be a higher rpm motor compared to the Kr. to add to what David mentioned, the can is from the older Reedy motors (Sonic/Fury) which has bigger vents. should be interesting. cant wait to try one out.
Old 10-06-2003, 08:08 PM   #21
I bought one Reedy PT 12*2 . I test it in track and feel very high rpm and more run time , can over gear then the KR a little bit.
Loman is offline   Reply With Quote
Futaba MC800, Reedy Neo One 6.5, Reedy Ti Mods convikt R/C Items: For Sale/Trade 6 10-08-2007 06:38 AM
Comm Lathe, NIB Reedy 19T Armature, Reedy 766 or 767 brushes, Sonic Fiddlestick Cain R/C Items: Wanted to Buy 4 06-12-2007 07:43 AM
Airtronics Synthesized-stuff,FM rec's,REEDY BRUSHESS,REEDY MOD MOTORS,etc,etc, nobike R/C Items: For Sale/Trade 89 03-22-2007 10:33 AM
Reedy Quasar Pro (No Problems!) DOMOisCOOL R/C Items: For Sale/Trade 30 05-23-2004 11:40 AM
MR-4TCSD, Reedy X-Cell 3300, Reedy Kr Randy Caster R/C Items: For Sale/Trade 9 07-03-2003 08:27 PM
