Old 11-05-2008, 04:05 AM   #16
Both seem to be good....
SP comes with the programer though which means you don't need to cart a computer to the track. Apart from that I haven't seen proof one is better than the other.
As for SP's frying? I have yet to see that.. Or a tekin RS for that matter... Seen plenty of other "top" speedies go up in smoke though.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 11-05-2008, 04:51 AM   #17
Knights Cross's Avatar
Me and my friends got the SP 9.5T DriftMaster Combo Set, 2 of them has got their attached fan unit fail.... The motor would jerk during very slight throttle from standstill but then the power is fantastic and easy to set using the programme card. Have not tried the Tekin yet
Knights Cross is offline   Reply With Quote
Old 11-05-2008, 06:30 AM   #18
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Originally Posted by jubilee View Post
Anyone know if the Tekin Hotwire is compatible with Apple/Mac computers?
I'm using it on a Macbook Pro via BootCamp and Windows XP. Works flawlessly.
And as a side note for Mac geeks, BootCamp may be one of the best Apple software products ever made. You now have total freedon to use ALL software and hardware. My free time is now playing rFactor and VRC on a Mac.
Oh, and on topic, the RS from Tekin is a really fantastic speedo. Hotwire is wonderfully easy to use, and can adjust EVERYTHING in the speedo to your needs. I've run mine on a 90mph drag car, and this winter it will be going into my Vintage Trans Am car full time.
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 11-05-2008, 07:15 AM   #19
bigemike's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to bigemike
i went with the tekin rs 21.5 combo, hopefully down the road I can use the 21.5 tekin in t/a racing
ok, cancelled that order, I was reading the tekin thread and it doesn't make sense to me. the timing advance only works in sensoreless mode or hybrid and most of the guys are running full timing on the motor with the speedo not adding anything. So I don't think there are any benefits to this speedo for me outside of the size. I am going to hold off until I see something more concrete on these speedo's.
bigemike is offline   Reply With Quote
Old 11-05-2008, 09:06 AM   #20
I have the Tekin. I used also a LRP competicion TC.
I will choose a LRP competition TC above a Speedpassion.
I drive the Tekin RS PRO with 95% timing on the esc. on 80% it's as fast as a Speedpassion.
Also is the Tekin lighter and smaller.
All the guys that use full timing drive 13,5 or more turns.
that's normal. i dit it also on my LRP.
The speedpassion can not change the timing as far as a Tekin can.
You can also wait for the new LRP stock esc.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 11-05-2008, 10:25 AM   #21
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Our Tekin RS can change timing in dual mode with the current software. The team drivers are using some updated software as we speak that will allow a "boost" in sensored only mode to go with even more timing.
In sensored only mode the motors mechanical timing can be used to change the total timing.
Give us a try, you won't be dissapointed.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-05-2008, 10:40 AM   #22
Send a message via AIM to Joaf
Well, I've only used the SP. I currently have 2 that i use in off-road. One has always worked flawlessly. The other got smoked when two of my motor tabs bent together and touched. The guys at SP were super cool about it and sent me a new one in less than 2 weeks. Customer service wise they were impressive.
Joaf is offline   Reply With Quote
Old 11-05-2008, 10:45 AM   #23
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
The reason you see that is because the mechanical timing gives more total timing than what you can get in hybrid mode. After playing with my Tekin 17.5, it really is fast when using the mechanical timing. Having the choice is the benefit! The Tekin RS is a GREAT ESC. I was looking at the SP ESC also, but Tekin hit the market at the right time and I haven't looked back.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 11-05-2008, 11:55 AM   #24
Trader Rating: 42 (100%+)
Default Tekin
Another nice feature to the Tekin is even if you have it set in sensored only mode and anything happens to the sensor wire...it will automatically switch to sensored mode and keep running.
I run 13.5 or smaller motors in sensored only mode..but I always set the defalt timing to full just incase it would switch to sensorless during a race.
You only need the PC to change the sensorless timing, everything else can be changed right on the ESC.
miket3 is offline   Reply With Quote
The Speed Passion Thread memix Electric On-Road 13377 11-28-2017 11:06 PM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Caster Racing 748 electric buggy hakmazter Electric Off-Road 112 12-09-2009 09:44 PM
Novak Voltage Booster Cpt.America Electric On-Road 16 07-21-2009 07:14 PM
Best ESC Drifting101 Electric On-Road 58 06-09-2009 09:39 AM
speedpassion v1.1 or tekin RS (non pro?) Valentin.H R/C Items: Wanted to Buy 9 12-31-2008 08:30 PM
