Old 10-02-2003, 04:10 PM   #16
ajg
Registered User
ajg's Avatar
Would it be worth it to get the metal gear servo.
ajg is offline   Reply With Quote
Old 10-02-2003, 04:14 PM   #17
Intelligentsia's Avatar
Definitely purchase the metal gear version.
Intelligentsia is offline   Reply With Quote
Old 10-02-2003, 04:15 PM   #18
ajg
Registered User
ajg's Avatar
Thanks!
Old 10-02-2003, 04:16 PM   #19
Anytime
If you have anything else that you want to know just ask.
Old 10-04-2003, 12:11 PM   #20
ajg
Registered User
ajg's Avatar
Would my car be just as fast with 6 of these aa cells?
Would I be able to charge them with my duratrax digital peak charger? If I assembled them into a pack.
Also how long would my run time be using the stock motor?
http://www2.towerhobbies.com/cgi-bin...?&I=LXCXE8&P=7
Assembled onto the car like this:
http://one18th.com/showtoy.php?id=1067
Thanks.
Old 10-04-2003, 12:24 PM   #21
Those will work just fine. Your run times will be extremely long with a stock motor. I wouldn't recommend those cells for a Big Block but for any other application they will work great.
Charge them around 1 amp with your Intellipeak charger. If they get hot charge them at around .5 although 1 amp should be just fine for those cells.
Old 10-04-2003, 12:30 PM   #22
ajg
Registered User
ajg's Avatar
So they would be fine to use them for the 5min. mains and practice, just so I let my motor cool down between runs?
Also how would I assemble them?
Would the speed be just as fast as with 6 2/3 cells?
Old 10-04-2003, 12:42 PM   #23
The speed would be about the same but the acceleration may suffer a bit.
I would recommend the 2/3a cells simply because they are smaller and lighter than those cells. Since you are only running five minutes and all. Weight with these small cars is important. If you want, I can build you a four cell pack of 2/3a cells in whatever configuration you like for $15 shipped. If you need a connector, they are extra. We can work something out. Let me know.
Old 10-04-2003, 12:47 PM   #24
ajg
Registered User
ajg's Avatar
I already have a 5-cell 2/3 battery pack, but thanks anyway.
I would just want the longer run time so I wouldn't have to buy as many packs.
How long would the run time be with stock motor and 1800mah cells?
Are there any other good AA rechargable cells that have about the same mah?
Old 10-04-2003, 12:51 PM   #25
It is always good to have more than one pack regardless of the milliamp rating. I have about ten packs right now.
I would expect your run time to be at least a half hour with an 1800 pack. Most likely you will probably have runtimes of 40 minutes to an hour +
Old 10-04-2003, 12:53 PM   #26
ajg
Registered User
ajg's Avatar
Thanks!
I was thinking of getting two (for racing), and use my 5-cell pack just for messing around.
Old 10-04-2003, 01:09 PM   #27
Fire's Avatar
the speed difference between 5 cells and 6 cells is very noticable!!!
but it is very very boring to run a micro with a stock motor on a 1/10 touring track, and the run time with 1100mAh 2/3A cells is longer than you want
Fire is offline   Reply With Quote
Old 10-04-2003, 01:29 PM   #28
ajg
Registered User
ajg's Avatar
That's what I was thinking too.
So I was going to ask why they don't go to mod or something faster, because I've seen that they have all the different types of motors in their tool boxes.
How fast and how long would the run times be for mod motors?
Old 10-19-2003, 07:38 PM   #29
ajg
Registered User
ajg's Avatar
Can I use the plastic pinions with a 6 cell pack?
Or will they not hold up?
Also is the titanium antenna worth the money?
Where would I mount the antenna on the penguin chassis?
Old 10-19-2003, 09:34 PM   #30
Hey,
I would recommend the HPI steel. The plastic ones don't hold up very well especially with mod racing.
downsizing! (micro-t, alum micro desert, fx10, t-spec) superhornetrace R/C Items: For Sale/Trade 20 06-20-2008 10:14 PM
FS: LRP Quantum Micro (w/ reverse) and Team Orion Micro Big Block WeatherB R/C Items: For Sale/Trade 1 06-26-2005 10:19 AM
selling kinwald xxx,team B3, custom hpi micro and 540 hybrid micro conversion, cheap romster R/C Items: For Sale/Trade 15 09-18-2003 04:32 PM
Team Orion Micro Elite Modified Motor for Micro RS4 Supra66 R/C Items: For Sale/Trade 1 12-02-2002 05:43 PM
MICRO RS4, MICRO RS4 HOPUPS, XXXS PARTS, INTEGY 16x5, MOTORS, TIRES HarshGuy R/C Items: For Sale/Trade 0 03-10-2002 10:06 AM
