VTA tuning Q&A
Old 12-02-2009, 07:48 AM
  #451
gacjr0's Avatar
Trader Rating: 15 (100%+)
Originally Posted by lowcel View Post
For those running T2's on carpet any advice on setup? I am running 17.5 lb springs in the front with 45 wt oil and 15 lb springs with 30 oil in the rear. My car is doing okay but not great. I'm just kind of curious as to what springs and oil others are running.
I'm at Xray 30wt all around with 1 less hole open in front compared to rear. T2R kit springs 17.5/14 lb fr/rr. I went to the xray site and looked at rubber setups to get an idea of what range of adjustments to use and ended up with a set up I like a lot.
gacjr0 is offline
Old 12-03-2009, 05:50 PM
  #452
lowcel's Avatar
Trader Rating: 80 (100%+)
Thanks for the reply. I made a couple of changes so hopefully it will help. Also by typing them here it will help me remember what I did.
Added 2mm spacers under rear turnbuckles.
Changed shock fluid to 45/35
Added front anti-roll bar
Hopefully these changes will help me get a little more traction in the rear.
lowcel is offline
Old 12-15-2009, 08:05 AM
  #453
Tech Legend
Cain's Avatar
Trader Rating: 249 (100%+)
here is a general question. I got my car to hook up MUCH better than last time. was great to drive and still had lots of steering.
I am wanting to tweak it alittle more, and i am thinking of trying some sway bars from and rear to cut down a bit on body roll.
So here is my question in regards to swaybars, when you add swaybars, I have read it reduces traction, do you compensate for this by say using slightly lighter springs, oil, etc.?
Thanks for any info before hand!
Cain is offline
Old 12-22-2009, 02:42 PM
  #454
What do you guys do to keep your tires from gumming up
BIGBOT is offline
Old 12-22-2009, 02:48 PM
  #455
trerc's Avatar
Trader Rating: 89 (100%+)
Clean the tires with lighter fluid, some use simple green also. I prefer lighter fluid myself.
trerc is offline
Old 12-22-2009, 03:25 PM
  #456
robk's Avatar
Trader Rating: 22 (100%+)
Swaybars are weird. On tracks with a lot of 180 turns with just a "finger" board sticking out, adding swaybars will take away the rotation and kill the cornerspeed. If the track has carousel type turns, it can help a lot. Body roll is good if it's a really tight track and has a lot of 180s. Lay the shocks down on the rear and let it rotate.
robk is offline
Old 12-22-2009, 04:21 PM
  #457
Tech Legend
Cain's Avatar
well i tried the swaybars, and boy did that make a difference. I had both vehicles setup, one with, one without, basically same setups, though the car without swaybars was using a slightly lighter rear spring, and also lightweight diffs but heavier center drive shaft.
Anyway, the vehicle changed direction much faster with the swaybars, but traction was not reduced. it really felt "right". The other car without would bite more into the turns.
This is with an STR4 Pro II sedan.
Another driver using a TC5 also liked going with the sway bars.
I managed to TQ, but had motor issues.
Cain is offline
Old 12-31-2009, 08:01 PM
  #458
TwoTone's Avatar
Ok, I've never been good at setting up a car. Today I ran my new/used 415 on our track.
Using a front one way I need a lot more steering, it's pushing like crazy.
Now I have the XRay set up book downloaded and have read though it.
Here's my problem, making a change to 1/2 a dozen settings can increase front steering, but how do you choose which on to start with? Why?
TwoTone is offline
Old 01-01-2010, 05:46 AM
  #459
volracer's Avatar
Default TC4 27T Gearing
I have a TC4 and want to run 4 cell 27 turn stock and wonder what gearing I should start with. I am just bashing around a parking lot. I prefer 48 pitch gears.
Thanks.
volracer is offline
Old 01-01-2010, 09:51 AM
  #460
gacjr0's Avatar
what has worked for me in 4 cell/27t is 5.88 fdr on a smallish indoor track.
on tc3/4 I think the stock spur is 72, so a 32 would get you to 5.625. That is a starting point. Your results may vary.
gacjr0 is offline
Old 04-26-2010, 09:19 AM
  #461
That's funny, I have the opposite prob. with my 415.....way too loose, i think i'm gonna ditch the one-way for a spool...
whtltning00 is offline
Old 08-31-2010, 07:43 AM
  #462
DARKSIDE's Avatar
looking for a setup for the Sprint 2 Sport for VTA...
http://www.hpiracing.com/kitinfo/708/
DARKSIDE is offline
Old 08-31-2010, 08:28 AM
  #463
2xs
When I get home tonight I will post up my S2S VTA setup.
2xs is offline
Old 08-31-2010, 10:43 AM
  #464
Tech Legend
Cain's Avatar
looks like its getting close to that time again. I wonder what we will be doing out here for VTA rules since some use USVTA others VTA.
End of season last year was getting traction roll issues again.
I wonder if I am over saucing the tires. sort of like running too soft a compound in my pan cars LOL.
Cain is offline
Old 08-31-2010, 10:54 AM
  #465
Regional Moderator
CarbonJoe's Avatar
Try softer springs and/or leaning your shocks in.
CarbonJoe is offline
