VTA tuning Q&A
Old 11-24-2009, 08:42 PM
  #421
padailey's Avatar
Anyone new or just struggling some with handling or grip..... the first and IMO the most important thing to do in this class is keep your tires CLEAN. I've seen crappy setups work ok with good tires but a good setup with glazed tires just doesn't cut it. So first and foremost clean your tires!
padailey is offline
Old 11-24-2009, 09:01 PM
  #422
robk's Avatar
Trader Rating: 22 (100%+)
One way rule is only for the Hurricane All Star series. Otherwise, enjoy your oneway
robk is offline
Old 11-24-2009, 10:04 PM
  #423
wiscnitro's Avatar
Good thing you brought that up. I know its been covered in the past but is still a good subject to bring up. your right Tires are probly #1 when it comes to setups expecialy if the tires are new then forget handleing so to start tire prep and storage are huge. I like to clean my tires with WD-40 and for adding traction compound keep it consistant! if you cover the rears 100% and only 50% of the front then keep the routine the same as for storage at the end of a race clean and goop you tires and store in a air tight bag (Zpiloc) as for breaking in new tires the only way I know is to just run them but you can always Pre break in the tires. for me I clean them as soon as I take them out of the package then goop the rears and front 100% and store in a bag, after that each day pull them out,goop,and reseal lengh of time will depend on your pacience and your own methods. I try for 1 week then mount them. (a whole nother sublect) this is the method I try to use. anyone else have tips they wish to share
wiscnitro is offline
Old 11-25-2009, 01:02 PM
  #424
BadSign's Avatar
Trader Rating: 15 (100%+)
I clean my tires after every run with lighter fluid. Douse the rag and rub off the gunk, and keep going until the rag comes off the tire clean. The last pair of tires I broke in just by doping, then storing in a ziplock bag for a week or two. When I got tothe track they were ready to go.
BadSign is offline
Old 11-26-2009, 01:10 PM
  #425
Tech Legend
Cain's Avatar
Trader Rating: 250 (100%+)
Anyone ever try progressive springs on there sedan in this class?
Cain is offline
Old 11-26-2009, 04:02 PM
  #426
jrxsMike03's Avatar
Trader Rating: 14 (94%+)
Default vta final drive question
What final drive is everyone running? I have a 21.5 setup in a tc3. I know it might take some dremeling to get in the low 4 range. any experience with this?
jrxsMike03 is offline
Old 11-26-2009, 04:13 PM
  #427
trerc's Avatar
Trader Rating: 89 (100%+)
When I ran a TC3 I ran a Robinson 81t (64p) spur gear and 40 thru 46 pinions, and had good luck between 4.4 and 5.0 No mods needed and never temped over 140 degrees even when running outdoor on hot days.
trerc is offline
Old 11-26-2009, 04:17 PM
  #428
jrxsMike03's Avatar
nice I'm using 48p now and just under 5.0 how much of a diff does the 64p make?
Old 11-26-2009, 05:03 PM
  #429
trerc's Avatar
I like it basically because it's quieter, lol. I never had any issues running 64p in the tc3 even on asphalt. I would just tape the access hole in the bottom of the chassis to keep debris from entering there.
trerc is offline
Old 11-26-2009, 07:52 PM
  #430
Kregger's Avatar
I've used the HPI ones on a pro 2 I was using, they worked but they aren't worth getting.
Kregger is offline
Old 11-27-2009, 09:20 AM
  #431
Tech Legend
Cain's Avatar
what did you notice was different about the vehicle when using a progressive spring versus standard one?
Cain is offline
Old 11-27-2009, 12:49 PM
  #432
Kregger's Avatar
Under most conditions the car reacted like it had normal springs on, but every so often (on a hairpin after a long straight). The car would start off fine and about midway through the car would get squirrley (it would go from being neutral to wanting to dive in hard). Nothing drastic but it was slightly disconcerting when you weren'texpecting it.
Kregger is offline
Old 11-27-2009, 04:56 PM
  #433
Slotmachine's Avatar
what are you guys finding in general that does the best to increase rear grip?
Just use TIRE TWEAK traction compound.
Slotmachine is offline
Old 11-28-2009, 08:16 AM
  #434
jrxsMike03's Avatar
Thanks for the tips wiscnitro I had the Fastest car last night at the track. Had everyone lapped at least once. Unfortunately I traction rolled in the last 30sec of the main and my car sat for about 10sec on its roof still got second.
This car has never traction rolled before it was strange
Old 11-28-2009, 08:22 AM
  #435
wiscnitro's Avatar
It happens. I don't know what your track looks like but it could of been a few things. drove it into the turn too hard or did a good grove come up and you just hooked up too much. Now you know what it takes. Good Luck
