Old 01-14-2009, 08:51 AM   #166
Mike Haynes's Avatar
Originally Posted by Kregger View Post
Just out of curiosity does any using the 21.5 actually hit the FDR of 4.2 when they race?
Nope, 4.39
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 01-14-2009, 01:48 PM   #167
CREWMAN's Avatar
Trader Rating: 19 (100%+)
Originally Posted by k_bojar View Post
that would be correct
where you planning on running trans am at??
not really sure yet I have this 007 lieing around and i am weighing out my option of what i can do with it. shoot me a pm if you have any recomendations
D&K HOBBIES!!!!
Losi 8ight-T 2.0 Race Roller/Losi 350/JR 9100 Servos/Spektrum DX3R
BMI Copperhead 12/Thunder Power Lipo/Futaba Servo/Express 17.5/Spektrum DX3R
CREWMAN is offline   Reply With Quote
Old 01-14-2009, 04:45 PM   #168
CREWMAN's Avatar
Got another question guys
Is there a big difference in performance between the 21.5+lipo combo verses the 27t brushed and 4 cell combo? the reason i ask is because i have a tekin fx pro esc and a trinity co27 motor. If i run that combo will i be getting blown away by the lipo brushless guys?
D&K HOBBIES!!!!
Old 01-14-2009, 04:52 PM   #169
reenmachine's Avatar
Trader Rating: 26 (100%+)
oh no.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 01-14-2009, 04:54 PM   #170
CREWMAN's Avatar
Oh no i wont be blown away or oh no not thi type of question????
D&K HOBBIES!!!!
Old 01-14-2009, 04:55 PM   #171
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Has anyone else noticed that the search feature seems to work better since the update? lol. Reen I hear ya!
Old 01-14-2009, 05:04 PM   #172
TwoTone's Avatar
It's an oh no not again.
Plain and simple, if you know what you're doing with motors and have good packs yes you'll be fine.
All the 21.5/lipo does is allow guys like me to keep up with the guys that know what their doing with 27t/NiMh as long as the driving was equal.
TwoTone is offline   Reply With Quote
Old 01-14-2009, 05:06 PM   #173
CREWMAN's Avatar
Thank you that is exactly what i need to hear I run 1/12 scale and its the same arguement. Guys that now what they are doing will make the 27t work, i just didn't know for this class if it was different
D&K HOBBIES!!!!
Old 01-19-2009, 11:06 AM   #174
Trader Rating: 112 (100%+)
Have to bump this back up to the top for the setup questions.
Dave
dragracer72nova is offline   Reply With Quote
Old 01-20-2009, 03:31 PM   #175
Guys....Noobie....Here whats the difference between uptravel and droop? and how is it I read about guys setting there droop above ride height? does that mean if my ride hieght is 5 my droop is 6.5 if my droop is 1.5....Does that mean I use droop blocks and set my arm at hub on my droop guage and it should be at the 6.5 mark? I am alittle confused......What is a good amount of droop? Also if my car is loose or lifting a tire in fast corners can droop fix this? any help is appericiated.....By the way I have a setup book on order...
RugRunner is offline   Reply With Quote
Old 01-20-2009, 08:30 PM   #176
robk's Avatar
Trader Rating: 22 (100%+)
Your droop is 1.5 if the tires lift off at 6.5mm and you run 5mm ride ht.
You need to confirm your settings on droop blocks after you use the "over ride height" method. So after you are done with the above, take the tires off and put it on blocks to see what it measures. Then you have a reference point. 1.5mm droop = 7 or whatever.
Droop can help the things you mentioned but not in all cases. Sometimes it will be hinge pin heights or springs or camber. Too little droop can make the car spin out or push. If your lifting a tire, it's probably other things.
Old 01-22-2009, 08:50 PM   #177
What was everyone running (setups) and the NOVAK race at Trackside a few weeks ago. Alot of those cars handled really well just curious to see what set ups were used
Cheers
G_Anders is offline   Reply With Quote
Old 01-22-2009, 09:25 PM   #178
myrxseven's Avatar
Im looking for some help on gearing a Losi Type R running a 17.5. Any and all help will be greatly appreciated. Also if there is anything else I should know setting a Type R for Trans Am!
Tried doing a search, but could'nt find.
myrxseven is offline   Reply With Quote
Old 01-23-2009, 03:35 AM   #179
Trader Rating: 21 (100%+)
Default Setup
http://www.rctech.net/forum/5019268-post22.html
Also TA is run with 21.5 not 17.5.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 01-23-2009, 05:48 AM   #180
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
ummm - not this again
VTA IS
4cell 27t
4cell 17.5
or
21.5/lipo
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
