Old 11-01-2008, 10:43 AM   #1
sickjamminracer's Avatar
Trader Rating: 23 (100%+)
Default team losi jrxs HELP PLEASE!!!
ok i was working on my jrxs today getting ready for racing tomarrow and noticed the diff pulley wobbles when i push it back and forth im new to on road and dont know if this is bad the car has one run on it so its not worn i was wondering if the tension you put on the diff itself would fix this meaning the reagular screw the adjust the stiffness please help i want to race tomarrow !!!!!!! thanks alot in advanced cody
www.myspace.com/krystallinemusic
W.P.A.C crawlers
The Raceway
sickjamminracer is offline   Reply With Quote
Old 11-01-2008, 06:25 PM   #2
Jeff Crosson's Avatar
Your diffs may be too lose. Once you get to the track to tighten and adjust them, they should be fine.
Jeff Crosson is offline   Reply With Quote
Old 11-01-2008, 06:48 PM   #3
In any ball diff there will be some wobble because the gear essentially floats on the diff balls. How much wobble will depend on how close the thickness of the gear is compared to the diameter of the diff balls.
Old 11-01-2008, 06:50 PM   #4
RCSteve93's Avatar
Maybe the bearing that supports the pulley is shot?
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 11-01-2008, 07:58 PM   #5
yep thats what it is i will tighten them when i get to the track thanks for your help
W.P.A.C crawlers
The Raceway
