Tire Warmer Machine "Muchmore"
Worth it, or Over-rated?
Good for getting rubber to hook up on both asphalt and carpet, or just asphalt?
opinions please
opinions please
If the tyre hooks up from cold on the track within a lap, tyre warming will only save a few tenths. If it takes a few laps or even a couple of minutes to get to operating temperature, it can save a few seconds, which depending on your level of competition can mean quite a few places. Of course, on the first lap of a final, any grip disadvantage can mean 2 or three places.
Depends how quick you are, and depends on how suited the tyre is to the surface.
I assume you mean these;
I used to own the Eagle wrap around warmers, but these are much better, no guessing the temp and you know that the warmers hold the temp constant right up until you take them off.
Skiddins
Skiddins
I ordered some black ones a couple weeks ago, from rcmarket. They are great, but not sure if it is worth buying them now with the Aussie dollar so low, and postage is also a lot. They are pretty heavy. I think if you looked around that you could get them for a similar price from the LHS.
Yeah, the one in the pic is the exact model and color I was looking at. It also dubs as a car stand. I think I'll go ahead and add it to the Christmas list. Hell it wouldn't hurt having it, and when its time to gain an extra edge by having warmer tires, this is definitely the animal to have.
dug up this thread...looking for some help. Looking at this unit and the cheaper cups & controller also. I'm fairly new to rubber tires and when looking at the cups only, not the IC unit.... they list different cup sizes... much more's web states these fit sorex...these fit Rp, takeoff, tamayi's slicks.
We are running spec tires.. jaco blues. which are approx. 62mm diameter. I can't find any info on the other brand tires diameter. I'm concerned the cups may be too large or too small and either not fit or be loose and not heat evenly.
Does anyone know the inner diameter of the cups for the MM IC control unit? Are all the cups (black, purple, blue model) all the same ID? Or can tell me how the jaco fit on the IC unit's cups?
Thanks for any help.
Linky to the choices
i use the Much More cheep ones with the controller
awsome kit
saves me a few 10ths and its good to cook the adative into the tyre
awsome kit
do you know which cups? and what tires are you using and their diameter?
Thanks.
Thanks.
Thanks.
sauce a problem w/ the alumium cups? Hum....didn't think that would be an issue w/ the alum. I know what I use just degrades plastic easily...but haven't see any issues w/ any type of metals. Simple enough to remedy if I see it causing damage...I saw the tissue thread! LOL.
Thanks again. think I'll order it.
Thanks.
i just use kitchen tissue folded in half and cut , does 2 tyres nicely
toilet roll is a bit too small
