Old 08-04-2009, 09:08 AM   #1441
Catalyst's Avatar
Originally Posted by cpatel529 View Post
Yes That is what I am speaking of. The turnbuckle is not parallel with the chassis. The side that connects to the servo arm is higher than the side that connects to the servo saver system. Is this ok or will it cause problems? I can put spacers in the servo saver system assembly to lift the turnbuckle up but not sure if this is recommended and/or necessary.
You want the servo horn to be at a 90* angle from the steering link which means it is at an angle when compared to the chassis - this is in the manual and you will get full throw each direction. I'm running the BLS 451 until I can get the BLS 551 and it's a great servo
Catalyst is offline   Reply With Quote
Old 08-04-2009, 10:12 AM   #1442
Suspended
Trader Rating: 28 (100%+)
I know TRF shocks are very good.One of the best.Its just a thing about setup.If you never run others setups,the Tamiya shocks are fine.But that really limits the cars quick-tune ability because even with similar shock setups,it will never feel the same.With guys like Kevin Woods around here,it would be hard to duplicate his setup.Thats just a simple example.I am building my 009 with the Aluminum 009 shock set.I start today!See you at the track fast guy and congrats on your bump to the big boy class!
Originally Posted by Catalyst View Post
I get what your saying. I just didn't like the way the Xray shocks built and the Tamiya ones are so smooth and a simple build and to get rebound and length precise between shocks. If I ever get to the point I am trying to match someones setup I've got the Xray composite shocks on hand. I may go back to the Xray ones for weight savings at some point with the newer TC ROAR weight limit. The composite shocks are considerably lighter
racenut123 is offline   Reply With Quote
Old 08-04-2009, 11:55 AM   #1443
cyanyde's Avatar
Anyone know an online store that sells the full range of parts for this car with reasonable prices and shipping to asia? Thanks in advance.
cyanyde is offline   Reply With Quote
Old 08-04-2009, 12:05 PM   #1444
Suspended
rcmarket.com.hk
Old 08-04-2009, 01:28 PM   #1445
Catalyst's Avatar
Glad to hear you are running the 009 John, hope it works out well for you. I am biting the bullet and going to do the Xray shocks for a while and just learn to accept how they build. That way maybe I can bug KW for his 13.5 setup. I'll be at the track this weekend prepping for the TOP Gun race...
Old 08-04-2009, 06:14 PM   #1446
cyanyde's Avatar
Originally Posted by racenut123 View Post
rcmarket.com.hk
Thanks for the link. But $21 for a pair of plastic shock bodies... LOL!!
Old 08-04-2009, 08:17 PM   #1447
Catalyst's Avatar
Xray parts are some of the most expensive but it goes hand in hand with their quality. If you want cheap there are plenty of options. I think after initial sticker shock - once you know how well the stuff works and how durable it is you will realize that ongoing expenses are minimal. I went the "cheap" (AE) route with TCs before and spent more because I ended up replacing everything a few times over. Now it's an occasional knuckle.
Old 08-04-2009, 08:20 PM   #1448
bjs227's Avatar
Trader Rating: 16 (100%+)
XRAY's the way to go! Its not the cadillac of RC it's the Lexus/BMW!
Who wants a bail out car anyway!
Brandon J. Skewes A.K.A "Skittles"
genesisrcraceway.com - skewesjewelry.com - race-rewards.com
bjs227 is offline   Reply With Quote
Old 08-04-2009, 08:21 PM   #1449
bjs227's Avatar
by the way does anyone know of anybody who has these in stock? The rubber tire version that is.
Old 08-04-2009, 09:06 PM   #1450
Trader Rating: 33 (100%+)
Didn't see that, but I did see Aluminum complete shocks for $29.60 a pair.
Plastic shock bodies are $5.60 a pair.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 08-04-2009, 09:18 PM   #1451
bjs227's Avatar
i found alu shock bodies for the t2 for 22.00 a pair.
Old 08-04-2009, 09:27 PM   #1452
Regional Moderator
CarbonJoe's Avatar
Looks like the Xray XSHOP does:
http://www.teamxray.com/xshop/produc...p?prod_id=2835
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 08-05-2009, 03:47 AM   #1453
GWH74's Avatar
Back to the servo horn at 90* to the steering link comment has anyone managed to achieve this using the servo saver in the "rubber setup" position?
Mine is not 90* using a standard Futaba servo. I think to easiest way to get it to 90* is to shorten the servo link turnbuckle and plastic ball joint. It cannot be made any shorter using the standard parts.
AE 12R5.1 - Custom chassis
For Sale BMI DB12RR, Tire Warmers and lots of other stuff.
GWH74 is offline   Reply With Quote
Old 08-05-2009, 04:04 AM   #1454
Ryan Maker's Avatar
Send a message via MSN to Ryan Maker
Hey, Yeah. The Solve for this is to Cut about 2mm Off each turnbuckle and screw it in, leaving about 3mm for the turnbuckle wrench in between.
I have found it is best when your servo horn is at 90 Degrees with your Link, and at about a 30 Degree angle to the chassis, this gives the most consistent steering feel. And it's how the Xray Manual says to do it
Ryan.
Awesomatix - Muchmore - Protoform - Silverback - Radtec - LeeSpeed - Hiro Seiko - SG PitDesign - Plaig
RC MAKER - www.rcmaker.com.au
AWESOMATIX - R1 WURKS - VOLANTE
Ryan Maker is offline   Reply With Quote
Old 08-05-2009, 04:50 AM   #1455
Skiddins's Avatar
As Ryna mentions, just cut some plastic away from the rod end to shorten it, this will allow the turnbuckle to travel further into the rod end.
It is difficult to get it exact as you have to allow for the servo spline as well, but with the steering in the center my servo horn does lean forward slightly.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
