Old 07-29-2009, 02:19 PM   #1411
johndayo101's Avatar
Trader Rating: 128 (100%+)
Default lipo mounting brace.
anyone using diggity design lipo mounting brace extended? any suggestion? pics if you have.
and how do you balance the car?. where do you put the weights?
johndayo101 is offline   Reply With Quote
Old 07-29-2009, 02:34 PM   #1412
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
What does moving the motor forward help with?
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 07-29-2009, 03:35 PM   #1413
Catalyst's Avatar
I use the TRF shocks on my 009. Love them. I had to space them right and use the Tamiya upper ball joints but the black springs work well on them and they are super smooth. (and running the special edition black ones looks nice).
Moving the motor forward shifts your Front/Rear weight balance forward which should add stability. I like a little more weight in the rear personally to suit my driving style.
I run the ECS with the spool and like them a lot. Design is nice and no more chatter for me.
Catalyst is offline   Reply With Quote
Old 07-29-2009, 03:47 PM   #1414
Catalyst - Thanks for the info. When you say space them right do you mean making sure that the length is equal to what the original length of the shocks were? I plan on running HPI springs on my car as well.
Chi
Old 07-29-2009, 05:01 PM   #1415
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Link to the shocks you are running?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-29-2009, 05:05 PM   #1416
Catalyst's Avatar
In the rear, I used a 2mm shim between the ball and the a-arm on the lower shock mount (and a longer grub screw) and utilized the Xray lower spring perch and open ended joint. The top of the shocks I used the TRF fluorine coated balls that were a direct fit for the shock caps to fit (no spacing at the top). I didn't like the angle they were at before spacing...caused additional resistance in the shock stroke.
Old 07-29-2009, 05:06 PM   #1417
Catalyst's Avatar
Captain...I don't have a link...I had my LHS special order me the TRF Special Edition Damper kit.
Old 07-30-2009, 08:07 AM   #1418
Mr. MR4's Avatar
Are these the ones? #84008
Xray T4'16 HobbyWing Xerun 120A V3.1
Xray X1'16 HobbyWing Justock
Yokomo R12C3 HobbyWing Xerun V3.1
Mr. MR4 is offline   Reply With Quote
Old 07-30-2009, 04:38 PM   #1419
Catalyst's Avatar
Yes those are them...also another note this reminded me of. The black oring that goes on the shaft inside the TRF shock doesn't allow enough travel so remove it - otherwise you won't hit your downstops on the arms for droop adjustment. Another note - the Xray open eyelet for the bottom mount will not thread on completely to the TRF shaft. I have about 1.5 threads showing but they are consistent between shocks and I've had no issues running them this way.
Old 08-01-2009, 01:27 AM   #1420
FK05 lover's Avatar
Trader Rating: 147 (99%+)
+ 1
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 08-02-2009, 09:16 AM   #1421
Trader Rating: 198 (100%+)
Why would you guys go with the TRF dampers when Xray makes a great set of alloy shocks? The price is a about the same.
The TRF price is $86
http://www.tamiyausa.com/product/ite...oduct-id=49355
The Xray from Nexus for the 009
http://www.nexusracing.com/product_i...oducts_id=2463
for the 008
http://www.nexusracing.com/product_i...oducts_id=2009
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 08-02-2009, 10:16 AM   #1422
#88driver's Avatar
for the 008
Even just the plastic ones that come with the kit are great IMO.
Colton Jaynes
*RC America*Hudy*Xray*Jaco*KO Propo*SMC*EA Motorsports*
rchobbiesstore.com
#88driver is offline   Reply With Quote
Old 08-02-2009, 04:11 PM   #1423
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
True plastic ones are great if you manage to make them without bleeding or the need to rebuild them VERY OFTEN.
I don't say it's not my problem on how I build them but i do same things with tamiya or the xray aluminum and those don't bleed!!
Since Xray has aluminum I would go (and did) for those
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 08-02-2009, 04:24 PM   #1424
syndr0me's Avatar
Trader Rating: 32 (100%+)
for the 008
That's full retail. The TRF dampers can be had much cheaper than that, especially overseas.
http://rcmarket.com.hk/product_info....oducts_id=2472
syndr0me is offline   Reply With Quote
Old 08-02-2009, 08:08 PM   #1425
Suspended
Trader Rating: 28 (100%+)
Yeah but good luck with setup help with that.Justin,run the Xray shocks.There is no reason to use Tamiya shocks over even the Plastic 009 shocks.They work great and no guessing on how to mount the TRF stuff.
racenut123 is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
