Old 07-13-2009, 12:03 PM   #1366
MTX
MTX's Avatar
Hi guys,... I'm new for the carpet racing. Can anyone give me some tips for carpet racing set up.
Iam using T2'009 with 23T stock motor, Sorex 40 rubber tyre, we are allowed to use paragon addictive in this race
1. What sort of sorex tyre should I use?
2. Should I tyre warmed the tyre before race to what degree of temp?
3. Should I apply paragon addictive then tyre warmed my sorex?
4. What kind of setting should i adjust for carpet racing?
Cheers....
MTX is offline   Reply With Quote
Old 07-15-2009, 09:45 PM   #1367
Originally Posted by MACH55 View Post
I'm just running 17.5 with an LRP SPX, I'm looking at sub 4's or what is the norm for med size indoor asphalt. Currently I'm at 4.33 should I be lower than this for 17.5 FD?
I use a 92 64pitch at the" C". Go with Rcterp he's a factory driver with many connections
M3dreamin2008 is offline   Reply With Quote
Old 07-16-2009, 02:49 AM   #1368
Benzaah's Avatar
Trader Rating: 21 (96%+)
For those who have been asking about the SMC lipos and the Xray lipo weights.
It is a really tight but it does fit!
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 07-16-2009, 08:49 AM   #1369
RFALLON's Avatar
Send a message via AIM to RFALLON
Cheers....
Try Sorex 28's, i dont use tire warmers, try all in back and the inside half in front, the stock setup is pretty close. Just put your own little things on it to adjust to your driving style.
XRAY T2'009
Nexus Racing
KO PROPO
Novak
JR racing
RFALLON is offline   Reply With Quote
Old 07-16-2009, 11:00 AM   #1370
pakk's Avatar
Trader Rating: 79 (100%+)
What is the difference between the t2 pro and the 009? Is it like the cyclone S and TC?
--pakk
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 07-16-2009, 11:23 AM   #1371
bigdadracing's Avatar
yes it's like the difference between the two cyclone's . it's a good entry level car some of the differences is that the 009 has carbon fiber chassis where the t2 r has fiber glass chassis from what i understand . definitely a better car than the hot bodys car
rcamerica/xray/ team powers/bsr tires/ slapmaster tools/ bigdads garage/cheep beer/ mykeart paint works / team pop a top
suport your local hobby shop because ebays track is hard to find !!!!!!!!
Russ Jacobson
bigdadracing is offline   Reply With Quote
Old 07-16-2009, 12:08 PM   #1372
RFALLON's Avatar
--pakk
The 009 basically has all the bells and whistles. Carbon Fiber which makes it an overall lighter car, the orange anodizing, and the Hudy spring steel (i dont know if the t2 pro has this or not)
XRAY T2'009
Nexus Racing
KO PROPO
Novak
JR racing
Old 07-16-2009, 01:29 PM   #1373
RFALLON's Avatar
I have a problem. Im running carpet on rubber tires with basically the stock setup (shocks are layed pretty much all the way down). Yesterday when i was running i had a really bad push, but then figured it out. After figuring that out, my back end was so loose i could barely make it through the sweeper without spinning out. Its loose in the infield also, but i really need it stable in the sweeper. I tried to take the rear sway bar off to make it lazier and give it more traction, and it worked a little, but its still pretty loose. I dont really know where to go from here. Maybe a stiffer sway bar in the front. Any suggestions?
XRAY T2'009
Nexus Racing
KO PROPO
Novak
JR racing
Old 07-16-2009, 02:59 PM   #1374
bigkoitat's Avatar
Trader Rating: 6 (88%+)
--pakk
ALOT!!! I bought thr T2R-PRO and ordered it with the Lunsford Turnbuckles, because it comes with NON-adjustable buckles. also the diff in the rear is plasric, nothing wrong with it it's butter smooth it's just theres no external diff adjustments. This was also upgraded to the oo8-009 diff.
Now if you plan on running on low-bite asphalt the T2RPRO is the way to go, nothing I mean NOTHING can touch this car on low traction asphalt/parking lot tracks. When others are fighting for traction this car is stuck!
I ran the car on carpet and busted the front aluminum axles at the CVDS. I would get the steel axles especially for a front spool.
But I would recomend the 009 whisch is what I converted the T2R-PRO into, except for all the Orange anodizing. It will be cheaper to buy the 009 than to upgrade from the t2r. my $.02
JAWS
TRF-416WE & 416-X / DHW / TEAMRCR.NET
bigkoitat is offline   Reply With Quote
Old 07-18-2009, 06:17 PM   #1375
mickrcarver's Avatar
Trader Rating: 98 (99%+)
ok guys I have a question,when running the 007 multi diff in my 009 ,its kinda tight and does not really spin freely,I did not notice this until the mains,Iknew the car felt kinda slow, but was in a hurry as I boke a cup on my 009 composite spool,I checked the bearings they are very free, does anyone know if the 007 is capable of being run in a 009? also notice that my clickers get stuck alot and the droop gets stuck ,def going to regular pistons!!
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 07-18-2009, 06:26 PM   #1376
Trader Rating: 31 (100%+)
Just finished building my 009 and felt a bit ripped off. I'm guessing it's just a newer production run, but my layshaft, servo mounts, and rear diff are anodised black not gold/orange (yes I realise the diff was never orange but hudy/xray grey). Don't get me wrong it still looks good, in fact I'm thinking about having my 008 anodised completely black, just doesn't look like the box. Anyone else notice this?
$$$... is offline   Reply With Quote
Old 07-18-2009, 06:41 PM   #1377
Regional Moderator
CarbonJoe's Avatar
According to the parts cross-reference, no.
http://www.teamxray.com/teamxray/sho...p?file_id=3202
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 07-18-2009, 06:44 PM   #1378
Alex C's Avatar
Trader Rating: 50 (100%+)
Thumbs up
You are correct in noticing the subtle changes and yes they are just production changes, although please keep in mind Xray products are amongst the best in the industry!!!
Have fun running your new car ..........and best regards!!!!
Alex
Alex Cortez
Thank You to all My Sponsors
Ko Propo USA / RC America - Xray - Hudy / Max Power Engines / VP PowerMaster Fuel / Team Espo - "Lay it down Prop"!!!!
Alex C is offline   Reply With Quote
Old 07-18-2009, 07:36 PM   #1379
you mean black like this?? lol I had both my 009 eu and 009 us anodized black, just could not handle that orange lol pics at link
http://www.flickr.com/photos/3399333...7621534816973/
www.ovrccc.com
Old 07-18-2009, 07:39 PM   #1380
found out the only difference in the 008/009 multi diff and the 007 is the outdrives on the multi the 008/009 have a wider spade slot than the 007 but I just used the 007 narrower spades
www.ovrccc.com
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
RaceCraft TC Challenge Kylelim Singapore R/C Racers 119 07-03-2009 09:08 AM
Brushless touring car Salt Air Electric On-Road 9 04-20-2009 04:45 AM
Mana nak beli Xrayt2'009 tq9911 Malaysian R/C Racers 131 04-14-2009 11:10 PM
Wanna start elec this year, need help gentleman81 Electric On-Road 20 02-21-2009 02:15 PM
